Question about Magellan RoadMate 700 GPS Receiver
Why won't my GPS shut off when I press the on off button?
Why won't my GPSD (Nextar) shut off when I press the on off button?
  • thesearchcom Jan 24, 2009
    please i tried updating my roadmate 700 all it does now is start up says loading goes half way across the bar and stops anything i can do, no maps no sound
  • Anonymous Mar 12, 2009
    my gps stays lit up when disconnected and the shut off button doesn't do anything. just stays lit up with where to? and view map
    Novelist:
    Scholar:
  • 86 Answers
Bkyro,
Alot of the times the place where the button should be making contact with the contacts on the circuit board, don't. I would open the unit up and ensure the ends of the plastic power button aren't broke. ie. you can feel them press in when you press them manually without the plastic button.
Another way to turn your unit off is to press the Repeat button (on top) + Enter + Cancel at the same time.
-Daniel
Posted on Nov 21, 2008
How do I update my Nextar x3-08 gps so the new roads will show up ?
visit Nextar.com to order your desired maps update and Check the overview description to see which SD card lists your GPS model number and serial number. Order the matching card.
Remove the existing SD card. This is usually found in a thin, rectangular slot on the side of the Nextar GPS.
Insert the SD card with the maps update into the empty SD card slot. Press until it clicks into place.
Reset the unit by pressing the "Reset" or pushing a pin into the "Reset" hole.
Click the "Navigation" button to have the maps automatically update on the GPS.
May 06, 2015 | Nextar X3-08 Car GPS Receiver
Screen is froze
you may need to press and hold the power button down for many seconds try a count of 15 one thousands , it is called a hard reset
Nov 11, 2011 | Nextar M3-03 3.5 in. Car GPS Receiver
I want to reset my nextar gps passscode.
You simply need to locate the little reset button and press that for a few seconds, this will reset the unit back to factory fresh. Your user manual is below.
http://www.nextar.com/frontend/proddetail.asp?pn=X3-03&co=10000312
http://www.manualowl.com/p/Nextar/X3-03/Manual/28073
Jul 05, 2011 | Nextar X3-03 Car GPS Receiver
Need download drive for nextar x3-08
There is not a driver available to download for this gps. You may try a hard reset which involves pressing the reset button located on the back or bottom with the tip of a paperclip for ten seconds. Otherwise the hardware or software may be corrupted and you will either need to return the unit for exchange or repair to the retail location from which you purchased it or contack nextar customer service to see how they can help you.
Mar 10, 2011 | Nextar X3 GPS Receiver
Q 4 series GPS has performed an illegal operation and wiull be shut down Program Adeona;exe Exception 0xC0000005 Address;00023380
this seam like a memory failure to me ..and it is the equivalent of a blue screen on computers..Note that these kinda gps have a reset hole with a hidden button ..and you can default it if you press it with a stylus or a sharp object ...if after that is still the same ..you have to reload the software for the program it causes issues..(probably to get the firmware updates..)
Here is the site for support
http://www.nextar.com/frontend/gps_navigation_systems.asp?MODEL=MN2607
Jan 07, 2011 | Nextar GPS
Reseting nextar gps
Press the "Reset" button or push the stylus into the "Reset" hole, to see if the navigation software can load successfully.
Jul 19, 2010 | Nextar X3-03 Car GPS Receiver
Gps lost sound, the voice is gone. nextar #p3 auto navigation sys
You should first try the reset procedure to see if this resolves the sound problem for you. To do this press the "Reset" button or push the stylus into the "Reset" hole.
For technical support for your Nextar GPS see http://www.nextar.com/frontend/support.asp or you can phone them on 888-849-0846
Please remember to rate my answer. Many thanks.
Jun 24, 2009 | Nextar X3-02 GPS Receiver
How to reset gps
Hold the power button for 20 seconds plus, to reset it
or press the stylus in the reset hole.
Hope this helps.
Regards
Jun 21, 2009 | Nextar Q3 GPS Receiver
The screen won't light up on my nextar #P3 GPS
press the reset button on the back. i had the same prob.
Jun 09, 2009 | Nextar P3 GPS Navigation System
Restting nextar q4-4
resetting the Q4-04 , direct from Nextar FAQ's >
press the "Reset" button or push the stylus into the "Reset" hole, to see if the navigation software can load successfully.
nextar q4-04 manuals and faq's
see if that works for you , straight from the manufacturer .
if you need more help , just ask .
J5
Jan 19, 2009 | Nextar Q4-04 Car GPS Receiver
Magellan RoadMate 700 GPS Receiver Logo
55 people viewed this question
Top Magellan GPS Experts
Will Halftowaite
Are you a Magellan GPS Expert? Answer questions, earn points and help others
