Question about Verona 34 in. CTG536S Gas Cooktop
Corning cooktop burner outage
I have an 30" electric Corning smooth cooktop. Two (2) of the four (4) burners have quit working. Have you seen similar problem? Do you know if the unit is repairable, or am I more likely going to have to replace it? I know nothing about the guts/mechanics. Thanks.
The cooktop has to be examined for failure of the element or the switch. Some of the switches & some of the elements are still around. Have the elements checked for continunity. You will have to take it out of the counter and take the unit apart to do this.
Posted on Nov 21, 2008
Amana Glass cooktop 2 out of 4 burners not working
it is not a fuse. as if it shorted it may blow it and then nothing .. the sw to either one burner is at fault replace the sw 's ( both and the cook top should be ok . sw cost around 25 to 40 ea ..
Jul 13, 2010 | Amana AKT3040 Electric Cooktop
Viking professional induction cooktop large burners defective
Throw your circuit breaker that leads to this unit for a few seconds, then reset the breaker This unit is very sensitive to power fluctuations.
Mar 07, 2009 | Viking 37 in. VECU165 Electric Cooktop
Burners of electric cooktop not getting red hot
Hello
Welcome,
Sounds like you have a bad surface heat controller.
Nothing to do but call a hands on tech to replace a part.
please remember to leave a rating before you sign off
Dec 11, 2008 | GE 30 in. JP340 Electric Cooktop
Burners on JP326 electric not heating
Sounds like breaker tripped so no 220 to unit. Reset breaker. The burner switch you first turned on probably blew out and needs replacing, so don't turn it on again. If all else works ok, then that is it. Unless you are handy you may want to call the repair man.
Nov 30, 2008 | GE 30 in. JP326 Electric Cooktop
Burner temperature is always on high heat even at low setting
not related any further then sounds as if you have 2 burner switches gone bad,and actually the front right burner is controlled by a electronic control circuit board part retails for about $160-$200 part number 12002723, and left rear switch about $30 part number 74007841 . uint needs to be uninstalled from counter and parts changed by removing the bottom panel
Nov 04, 2008 | Jenn-Air JEC9530 Electric Cooktop
All 4 burners stopped working - circuit breaker ok
How old is this cook top stove? Does it require replacement?
Jun 11, 2017 | GE 30 in. JP385 Electric Cooktop
Smooth surface frigidaire electric cooktop
hi there,
you will need to replace the elements. it's quite common for them to stop functioning.
Sep 30, 2008 | Frigidaire 31 in. GLEC30S9E Electric...
Jenn-Air 30 in. JGD8130 Gas Cooktop
Yes. Buy a burner module. Sears sells them also most appliance part stores. (I am assuming you have the model with 2 knobs on the grill side) The electric version of burner modules is around $100 Gas should be similar price.
Jun 08, 2008 | Jenn-Air JGD8130 Gas Cooktop
Corning smoothtop electric range
You MUST use flat bottom pans on three of the four burners, the back right burner is the multi-pan burner and accepts any type pan. You'll notice the other burners have a circle in the center, that is the thermostat that reads the temp of the pan, that burner type needs the flat bottom pan to work correctly. The multi-pan has no thermostat and it will boil water in any pan.
Good luck
Jan 18, 2008 | Verona 34 in. CTG536S Gas Cooktop
Knob not working and some burners not heating
The switch under that knob is bad.  It's called an infinite switch.  As far as the elements go, first thing to check is for proper voltage (220) to the cooktop.  Let me know what you find.
Oct 19, 2007 | Jenn-Air JED8430 Electric Cooktop
Verona 34 in. CTG536S Gas Cooktop Logo
757 people viewed this question
Top Verona Cooktops Experts
Bosse Photos
Pierre Legault
Brian Coughlan
Are you a Verona Cooktop Expert? Answer questions, earn points and help others
