Question about Frigidaire 24 in. FDB1050REC Stainless Steel Built-in Dishwasher
Model fdb1050reb unresponsive
I bought this dishwasher used, wired and plumbed it correctly and ran one wash cycle. Now it won't do anything. The breaker is on and there is power at the main wires. but i have no lights on the control panel.
SOURCE: dishwasher will not turn on/ start cycle
Slam the door shut. What i did. I am guessing the switches in the door arent making good enough contact. When i slammed the door, it fired right up and ran fine
Posted on Mar 14, 2008
  • 89 Answers
SOURCE: frigidaire dishwasher
Next thing to look at--considering all the power is good--although that's what I'd check on again, would be the door switch. May have to remove the control panel cover or the door interior.
Try www.repairclinic.com if you need parts.
Posted on Oct 28, 2008
SOURCE: Frigidare Gallery Pro Dishwasher Control Panel Power
It can be the problem with the transformer. Try replacing it with another one.
Posted on Dec 15, 2008
SOURCE: dishwasher is "tripping" the breaker & not draining.
I had the same problem with a Hobart AM8 passthru dishwasher. The electrician determined that some of the wires had become exposed and were wet, thus shorting things out and tripping the breaker.
Posted on Jan 09, 2009
rylee_smith
  • 8619 Answers
SOURCE: Frigidaire dishwasher
Hi!
The timer switch i was talking about was the selector switch/cycle selector switch. And in your case the timer is embedded in the control panel, so you need to get it replaced.
If you have found this information to be valid and useful, a "FixYa" ratings would be appreciated. That is the only reward I get for the help I offer here.
Thanks
Rylee
Posted on Jan 29, 2009
Model KUDS30FXSS1 Kitchenaid dishwasher control panel stopped working at the end of a cycle.
I had a similar problem: unresponsive buttons, then the 1 hour wash button led was on but the other buttons weren't working at all.
I power off for more than 30 seconds and after that everything return to normal.
Thank you for the hint!
Nov 03, 2012 | KitchenAid Dishwashers
My dishwasher (model # DU81ODWGU1) is leaking water and suds during the wash cycle. I ran out of dishwasher powder so I had used regular dish soap for this cycle. Did this cause the problem? My...
MOST DEFINITLY You can put regular dish washing liquid in a dishwasher will do that every time take a few washings to stop run 2-3 times empty it will stop.
May 06, 2011 | Whirlpool Dishwashers
.After running my dishwasher on eco/fast cycle,
If the dishwasher is completing the wash cycle without any problem then the suds can occur either because you not using correct detergent. This model does not tolerate the tablets. You have to use the powder.
Water remaining in the bottom of drawer is linked to drain hose either blocked or not looped high enough under the kitchen sink.
I would suggest check this document for correct installation.
Nov 18, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
Hi, I have a 10yr old Neff s5543 built-in dishwasher, it is has been working fine but recently has stopped fully draining. I have removed it from the housing and checked all pipe work is unblocked and...
Hello there and thank you for choosing fixya
Ok there are acouple of things that can be checked on this along with what you have already checked
Drain solenoid Beneath some dishwashers, there's a timer-activated drain solenoid (an electro-magnetic coil) that opens a drain valve, to drain the wash water through a hose and out to the house's plumbing waste system. If this is failing it will not allow the water to drain from the machine fully
Timer Dishwashers have a timer behind the main control panel at the front top of the dishwasher, or behind the lower access panel. It is either a mechanical device like a simple clock, or it's completely electronic with just a digital readout. The timer runs the dishwasher in a pre-determined pattern. It provides the electricity to all of the dishwasher components at the correct time, for the correct length of time.
Oct 16, 2010 | Neff 24 in. S5543X2 Built-in Dishwasher
My dishwasher will not drain
could be a blocked drain or faulty drain pump or faulty controller.
Do you have a model no.
Also confirm if the wash cycle did start correctly and it ran through it according to the time. Does the dishwasher stop in the middle of the cycle or it completes the cycle with lights turning off but water still inside.
Did the drain pump actually run?
Sep 06, 2010 | Frigidaire Dishwashers
Only bottom rack cleans. Re-plumb or replace?
Do you have a garbage disposal? If I run mine while the dishwasher is running, dishes do NOT get clean!
Jan 09, 2010 | GE 24 in. Profile PDW7800 Built-in...
Dishwasher won't drain
It is fairly easy to pull the unit out and clean the hose out with some pressure.
If you ever have need any plumbing advice from a professional, please feel free to view my website any time:
http://www.superplumbersonline.com
Jan 11, 2009 | Whirlpool 24 in. DP840D Free-standing...
Dishwasher filling correctly?
john, the dishwasher has a timed fill, make sure you are using 3/8 inch line. If you are using 1/4 inch, that would be your problem. The fill should be just below the heating element. If you are using the 3/8 inch line, the next suspect would be the fill valve itself. Make sure nothing is kinked, Catriver.
Jun 17, 2007 | Whirlpool GU2700XTSS / GU2700XTSY Built-in...
Open Questions:
See all Frigidaire 24 in. FDB1050REC Stainless Steel Questions
Frigidaire 24 in. FDB1050REC Stainless Steel Built-in Dishwasher Logo
114 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
