Question about Motorola Mobility W315 Cellular Phone
Side keys going off all the time in my pocket
Key tones sounding off while in my pocket
    Problem Solver:
  • 7 Answers
From the main menu, select "Setting" then "Security" then "Lock Side Keys"
If you don't know the unlock code, try the last 4 digits of you phone number, or 1234, or 0000. If you need to reset you unlock code (to the last 4 digits of your phone number) call *228 and wait about a minute for it to reprogram/reset you phone code.
good Luck!
Posted on Nov 02, 2008
7 dings and a beep when starting 2000 ford explorer? what does that mean
NOTE: The generic electronic module/central timer module (GEM/CTM) is connected to the ISO link and is diagnosed through the data link connector (DLC) with a scan tool.
There are five warning chimes and lamps the GEM/CTM controls: headlamps operating without the ignition on (chime only), door ajar (chime and lamp), key-in-ignition (chime only), driver seat belt warning (chime and lamp), and message center.
Audible Warnings Warning Condition Lamp Duration Audible Duration Audible Output Safety Belt 60 Seconds 6 Seconds Chime, 60/Min. 740 Hz Key In Ignition - Continuous Chime, 120/Min. 740 Hz Headlamps On - Continuous Chime, 240/Min. 740 Hz Door Ajar Continuous 1 Second Single Tone, 1000 Hz Message Center (Tone Request) - 1 Second Single Tone, 1000 Hz
When the is turned to RUN or START from OFF or ACC, the chime will sound for six seconds or until the safety belt is buckled.
The will turn on for 60 seconds or until the driver safety belt is fastened. Both the chime and the lamp turn on at the same time.
If the safety belt is buckled before the ignition switch is turned to RUN or START, from OFF or ACC, neither the chime nor lamp will be activated.
Anytime the is changed to RUN from START while the safety belt warning indicator is activated, the safety belt warning indicator will remain activated until either the timing sequence has been executed or the safety belt is buckled.
When at least one door is ajar and the key is in the RUN position, the door ajar cluster lamp is activated and remains on until all doors are closed. A warning tone will sound once any time the key is in the ignition switch and any door is open.
The key-in-ignition warning will sound when the driver side is opened with the key in the and the in OFF or ACC. It will continue to sound until the key is removed, the is closed, or the is in RUN or START.
The headlamp-on reminder chime will be activated if the headlamps or parking lamps are on, the key is not in the ignition switch, and the driver door is opened.
A single tone will be provided each time a ground signal is received from the message center. A one-second tone will sound for warning indications from the message center. A 100 milli-second tone will sound for each message center button depressed.
Feb 12, 2015 | 2000 Ford Explorer Eddie Bauer
My samsung monte slide makes a beep when i send a text, how do i stop this from happening
Choose settings for profiles info.png 1 Find "Profiles"
  • Press Menu.
  • Scroll to Settings and press the Navigation key.
  • Scroll to Profiles and press the Navigation key.
2 Select profile
  • Highlight the required profile and press Options.
  • Scroll to Edit and press the Navigation key.
3 info.png Select settings for incoming calls
  • Highlight one of the following options:
  • Call alert type, go to 3a.
  • Call ringtone, go to 3b.
  • Message alert type, go to 3c.
  • Message alert tone, go to 3d.
  • Keypad tone, go to 3e.
  • Volume, go to 3f.
  • Press the Navigation key.
3a "Call alert type"
  • Highlight the required incoming call alert and press the Navigation key.
3b "Call ringtone"
  • Highlight one of the following folders:
  • Default melodies
  • Sounds
  • Music
  • If you select Default melodies:
  • Highlight the required ring tone and press the Navigation key.
  • If you select Sounds or Music:
  • If required, highlight a folder and press the Navigation key.
  • Highlight the required ring tone and press Select.
3c "Message alert type"
  • Highlight the required message alert and press the Navigation key.
3d "Message alert tone"
  • Highlight the required message tone and press the Navigation key.
3e "Keypad tone"
  • Highlight Mute or the required key sound and press the Navigation key.
3f "Volume"
  • Highlight the required category and press Navigation key right or Navigation key left to select the required volume.
  • Press the Navigation key to save.
4 Exit
  • Press Disconnect to return to stand-by mode.
Jun 25, 2011 | Cell Phones
How do I turn off the key tones on a Samsung S5510T mobile phone?
Go to settings, "profiles" when you are in profiles go to options and edit, it should bring up all the different alert tones and the key tones volume.Adjust them according to your needs.
You can also use the volume key at the side of your phone and adjust the level!
Mar 12, 2011 | Cell Phones
How do i stop the key pad tones from beeping every time i use the touch screen?
Go into the setting menu and go to sound then keytones and turn off the key tones.
Jan 31, 2010 | LG KU990 Viewty
How do i turn off keypad volume
My service provider couldn't even help me with this! So in case no one has answered this yet ,,, to turn off the key pad tones (very annoying sound) select menu>settings>profiles, then with 'normal' selected, hit the 'options' key (upper left soft key), then 'customize'- set up your audio profile the way you want it - go down the list til you come to 'key volume' and turn that all the way down with either the side control or the navigator dial. That will turn off those annoying key tones so you will bother other less while you use your phone in public.
Hope that helps.
Jan 28, 2010 | Pantech C470 Matrix Smartphone
How do i turn the keypad sound of on samsung tocco
Go to settings,
select phone settings,
volume key function,
select silence
then save
Now you can turn the volume of your keys up and down with the button on the side of your phone
JonnieC
Oct 06, 2009 | Samsung Tocco F480 - Pay Monthly Cellular...
Turn off key pad tone
In the main screen, press the volume button on the side. It will open up the volume control on the screen. Set it to zero and thats it. It will turn off the keypad tone.
Sep 23, 2009 | Samsung Tocco F480 - Pay Monthly Cellular...
Can't turn the texting key sounds off!!
Okay go into your menu and go to your Fourth option which is a little silver wheel which has the options call date&time all that.Go to sound which is your third option. It will have an option that says volume. Go into that and it will say keypad you can shut the noise off that way hope it helped if you need more clarification let me know.
Aug 22, 2009 | Samsung Tocco F480 - Pay Monthly Cellular...
I have a Samsung U900 and cannot turn off the key sounds without
to solve this at the main screen press volume down and u will get a pop up saying key tone volume keep pressing unil it reaches 0 and there will be no key pad sound but music etc will still work fine
Dec 07, 2008 | Samsung U900 Soul Cellular Phone
Keypad tones - D900i
Change the dialing font style to Normal and then set off keypad tones on setting menu.
Oct 07, 2007 | Samsung SGH-D900 Cellular Phone
Motorola Mobility W315 Cellular Phone Logo
66 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
