Question about Philips DECT 2252S Cordless Phone
DECT 225 - Ring tone etc. no longer works on 1 phone
The speaker side of one of the handsets has packed up completely, no speaker phone, no ring tone, no sound when pressing keys. Have put in new batteries and have checked to see if I have got it on mute. The handset still works fine but has no speaker sound. Thanks.
  • vanbeet Jan 23, 2009
    Thanks very much for replying. Tried removing two screws in battery compartment but phone didn't want to come apart and couldn't see any more screws, and seeing as the phone still works didn't want to risk damaging the handset. The fault seems to be intermittent, sometimes if I give it a shake the tones return but seem distorted, even with volume down, then next time I use it they have disappeared. Again, thanks for trying, much appreciated.
  • 71 Answers
Use your screw driver, open the handset, maybe the speaker wire is broken. Or use multimeter to check the dc resistance of speaker. Generally ,it is 8ohm or 4 ohm.
Posted on Jan 21, 2009
  • Richard Liao
    Richard Liao Jan 23, 2009
    Actually, it is not difficult to open it. Just need a little bit force. use some plasic knife ,it won't break the plastic hanset. If you shake a little bit, sometime the tone return ,it much like speaker wire or speaker. Anyway , you make your decision. Good luck.
How do I make the phone ring/ Also how do I delete number's/
Activating Personal Ring
You can assign special ringer tones to anyone in your phonebook. When your phone gets a call, it looks up the Caller ID information in your phonebook. If you've assigned a personal ringer to that number, the phone uses it so you know who is calling. To turn the personal ringing on or off, follow these steps:
  1. Press [Menu/Select]. Select the HANDSET SETUP menu, and then the PERSONAL RING submenu.
  2. Move the cursor to select ON or OFF.
  3. Press [Menu/Select]. You will hear a confirmation tone.
Selecting a Ring Tone (Handset only)
You may choose from four melodies or three tones for your phone's primary ring tone. Each handset can use a different ring tone or melody. The available ring tones are as listed:
  1. Press [Menu/Select]. Select the HANDSET SETUP menu, and then the RINGER TONES submenu.
  2. Move the cursor to select a ring tone. As each ring tone is highlighted, you will hear a sample.
  3. When you hear the tone you want to use, press [Menu/Select]. You will hear a confirmation tone.
Adjusting the Speaker Volume
Handset Speakerphone: You can choose from six volume levels for the handset speakerphone. To adjust the speaker volume while on a speakerphone call, press the UP Arrow button (to make it louder) or the Down Arrow button (to make it softer).
Base Speaker: You can choose from ten volume levels for the base speaker. To adjust the speaker volume while call screening or playing messages, press [volume +] (to make it louder) or [volume -] (to make it softer).
Adjusting the Audio Tone
If you aren't satisfied with the audio quality of your phone, you can adjust the Audio Tone of the earpiece while on a call. Your phone gives you three audio tone options: low, natural and high; the default setting, Natural Tone, is recommended for hearing aid users. Audio tone adjustments only apply to the earpiece, not the speakerphone.
To adjust the audio tone:
  1. While on a call, press [Menu/Select].
  2. Move the cursor to select AUDIO TONE, and then press [Menu/Select].
  3. Move the cursor to select desired option (HIGH TONE, NATURAL TONE, or LOW TONE), and then press [Menu/Select]. Selected option appears in the display for two seconds, and then the display returns to normal.
Deleting Phonebook Entries
You can delete a single phonebook entry at a time or all phonebook entries at once:
To delete a single phonebook entry:
  1. When the phone is in standby, press the phonebook key.
  2. Find the entry that you want to delete and press [Menu/Select].
  3. Select DELETE. DELETE ENTRY? appears in the display.
  4. Move the cursor to select YES.
  5. Press [Menu/Select]. You will hear a confirmation tone, and DELETED! appears in the display.
Deleting Caller ID Numbers
  1. To delete only one Caller ID number, press the Caller ID button when the phone is in standby, and then find the number you want to delete.
  2. Press [Menu/Select] and select DELETE ENTRY.
  3. When the phone asks you to confirm, select YES.
  1. To delete all the Caller ID numbers, press the Caller ID button when the phone is in standby, and then press [Menu/Select].
  2. When the phone asks you to confirm, select YES.
Note: When you delete a Caller ID number, you delete it permanently.
Deleting a Redial Record
If you want to delete a phone number from the handset's redial list, follow the steps below:
  1. When the phone is in standby, press [Redial/Pause].
  2. Use the UP Arrow button and the Down Arrow button to scroll through the redial list.
  3. When you find the redial number you want to delete, press [Menu/Select] and select DELETE ENTRY.
  4. When the phone asks you to confirm, select YES. The redial number is deleted.
Resetting the Voice Message Waiting Indicator
  1. When you receive a new voice mail message, the new message LED on the top of the handset flashes and VM appears in the handset display.
  2. In the event your message alert tone gets out of sync with your phone company's voice messaging system, you can reset back to its original "no messages waiting" state.
  3. To reset, press and hold [find hs] on the base for five seconds.
  4. A beep sounds and the message alert tone is reset.
Mar 22, 2011 | Uniden DECT 2080-5 Quint Phone
The DECT telephone is linked to our mainline phone - however it does not pick up the dialling tone or the ring tone. The battery is okay, the signal is good, but you cannot speak on the phone. ...
Re-Register a Handset to the Base
1. Remove Handset Battery.
2. Reconnect battery while holding down "*" and "#" key.
3. Then press the right upper key under the LCD.
4. Press the "End" key.
5. Wait a few seconds and then the phone will be ready to register to the base.
Mar 09, 2011 | Uniden DECT 6.0 Cordless Telephone...
Ring tone - need to set ring tone above two rings. need to set it at 5.
Since you neglected to specify the model of your Uniden DECT 6.0 system I can only suggest you select it from the list beginning here to download a copy of the manual.
Sep 08, 2010 | Uniden DECT 6.0 Cordless Telephone...
Ring tone
In most cases the ringer has been inadvertently turned off or too low. You can turn it back on from the system menu and can also try by increasing the volume control while the phone is idle.
May 01, 2010 | Uniden DECT 6.0 Cordless Telephone...
No dial tone. Base will ring. Handset has no
Check the Battery on the Handset. remove the pwr frm the base unit n connect aft 30 sec. aft this if it still says the same msg, then the handset needs to be replaced.
Mar 03, 2010 | Vtech DECT 6.0 Cordless Phone with Digital...
One handset doesnt ring
There should be a ringer tone and volume control on the second handset. Sometimes there is a ringer on/off switch on the side of the handset.
If that doesn't work, then there is a possibility that the speaker is broken.
May 26, 2009 | Uniden Cordless Phone
GE dECT 6.0 Cordless Model 28112 Series
On the base is a button next to the GE logo that says "Do Not Disturb". Pushing that button will enable and disable that feature
Dec 08, 2007 | GE 28112EE2 Cordless Phone
Dect225
Press "lock" key for several seconds. Untill you hear the confirmation tone.
Jul 12, 2007 | Philips DECT 2252S Cordless Phone
Philips DECT 2252S Cordless Phone Logo
364 people viewed this question
Top Philips Lands Phones Experts
Are you a Philips Lands Phone Expert? Answer questions, earn points and help others
