Question about Tascam DP01 All-In-One Recording Package Microphone
Can't Get My Music Off My Tascam. I have a DP-01 portastudio and it has a usb connection but it's not being recognized by my computer. At first it just wasn't compatible with Vista now I have windows xp and it won't connect at all
How to export your recorded tracks to WAV:
- Activate the Menu
- Scroll down to WAVE
- Press the right cursor key
- Go to Export Track
- Select the tracks using the Insert and cursor up and/or down keys
- Press Yes/Enter
- When the DP-01 is done repeat pressing Exit until the menu is closed.
Tascam USB mode:
- Press Menu
- Go to Disk
- Scroll down to USB OPN/CLS
- Press Yes/Enter
- Press Enter again to execute
- Press Yes/Enter again for the "Are you sure?" message
Now you will be in USB mode and you will be able to access the DP-01's hard drive and download the exported WAVE file(s).
Remember: the DP-01 will stay in USB mode until you remove the deviceusing the Safely Remove Hardware option in Vista and then press Exit onthe Tascam!
Posted on Oct 21, 2008
Cant transfer the master from tascam to computer
I'm assuming this is a Tascam recorder you're refurring to. What model is it, and what operating system are you using on your computer. First off, don't connect the usb cable to the computer until your Tascam Recorder in in USB Mode. I have the Tascam DP-01. With it, after making the master recording, make sure the master light is off, and not flashing. In the menu under WAVE, select Export Master and press enter. If anything is running, or the master light is lit, you will get an error. After the song is saved to the FAT partition, select DISK in the menu and scroll down to USB Open/Close and press YES/Enter. You'll be asked if you are sure. press Enter/Yes again to go into USB mode. Now plug in the USB cable. Use Windows Explorer, or what ever file navigation program is on your computer. (Not Internet exploere, but windows exploere.) Your Tascam will be seen as Removable Media when viewed from your computer. I have a DP-01, and it shows on my computer as DP-01. You'll find a few folders viewable on your recorder. One of them is called WAVE. You'll find your Exported Master in this folder. Copy it to a folder on your computer. When finished, if you're using windows, then use the Safely Remove Media function in the system tray where the clock is to disconnect from the Tascam safely. Then unplug the USB cable and press NO/Exit on your Tascam recorder to exit USB mode. I hope this helps. Have a wonderful day.
Jan 08, 2015 | Tascam Audio Players & Recorders
Is there a driver for tascam dp-01 for windows7 operating system
Unfortunately no such driver is available, because tascam have discontinued that particular model.
Here is a way to get your recordings off the device
On the Tascam main menu, select "Wave." 2) On the Wave menu, select "Export Master." This saves your mastered song to the correct folder. 3) Connect the Tascam DP-01 to your computer. You will get a message telling you your USB device has malfunctioned. 4) On the Tascam menu, select "Disk." 5) On the Disk menu, select "USB OPN/CLS." Your computer should detect the DP-01 as a hard drive & be visible in "My Computer" on Windows.
Apr 03, 2011 | Computers & Internet
My computer won't recognize my DP-01 Tascam recorder.
open the usb port on your dp-01 by going to "disk" in the "menu" select "usb opn/clse" press enter twice.
if your pc is connected to ur dp-01 it should reconize it, open the files by going into my computer as you would with a memory stick or card.
Mar 25, 2009 | Tascam DP01 All-In-One Recording Package...
Software compatability
windows doesnt recognize your mainboard and usb? or it doesnt recognize the tascom mainboard?
thanks,
Nate
Aug 16, 2008 | Tascam DP01 All-In-One Recording Package...
TASCAM 2448 xp drivers
I have a tascam 2488mk11 whit no driver cd also .Tascam is pulling a scam
Jul 30, 2008 | Tascam 2488 Portastudio Multitrack...
What kind of driver does my tascam dp 01 cd take.
No CD comes with the DP-01. The Tascam relys on your computers USB drivers to work.
You should probably try the DP-01 on someones else's computer first to se if it works there.
This is usually some kind of incompatiblity between the usb cable or the use hub and the usb speed (1.1 or 2.0). I would try bypassing any usb hub you might have in use first. If that doesn't work you might want to try another usb cable.
Good luck.
bd.
Jul 23, 2008 | Tascam DP01 All-In-One Recording Package...
Hooking my tascam dp01 to the pc
hey i had the same problem u need u.s.b 2 or something like that because some computers have u.s.b. 1.5 or something wierd along those lines i fixed mine by plugging mine into the back of the computer in the usb port there.
Sep 25, 2007 | Tascam DP01 All-In-One Recording Package...
Tascam DP01 All-In-One Recording Package Microphone Logo
217 people viewed this question
Top Tascam Audio Players & Recorders Experts
Sam Palermo
Sam Palermo
Michial Gueffroy
John
John
Are you a Tascam Audio Player and Recorder Expert? Answer questions, earn points and help others
