Question about Philips 60P8342 60" Rear Projection Television
SSB Module Where can I buy a SSB Module for my TV?
    President:
  • 3,130 Answers
Try http://ptscorp.com and get there # and call them or look up the part # but you wont find it as ssb. your gonna need the # off the module. You are aware of the hi voltage dangers inside these sets??? As these sets have a very high voltage inside them even when they are tuned off and unplugged. Good Luck
Posted on Jun 09, 2006
SOURCE:
My Phillips Big Screen TV is having audio problems I cannot hear anything but the picture is still great. Do you have an solution to resolve my issue?.
I would certainly challenge the fact that your SSB is bad. This SSB is known as the the small signal board. This board is a little larger than a credit card and is seated on top of the signal module( The board with all the RCA jacks and RF connections). It is located inside the TV on the left side of the rear of the TV. I must caution you, the replacement board will exceed any expectations you may have for repair. The cost of this SSB will be near $300 dollars. Then you will need a TV tech to enter the software to correct geometry. This SSB controls the screen size and colors (gray scale) and sound, etc. Sorry to lay the hard core facts. But it will not be feasible to repair this aging TV. I have seen and repaired many of these when they were under warranty! Thanks for asking and show all hands of support.
May 13, 2011 | Philips 60PW9363 60" Rear Projection...
Hi, I have Philips Plasma 44 inch TV . I have used it for around 4 years . My family was watching it and it goes all blank suddnly no power coming nothing we sent it to Philips Service centre they say its...
Search the websites of used TV parts dealers for your model number. (The model number will be on a label on the back of the TV.) Two such dealers in the USA are ShopJimmy and Tri-State Module. (Links below) Keep in mind that North America uses a different power line voltage and frequency, so your model may not show up on those sites. If the set was designed with a universal input power supply, there is a chance it will be listed.
TV Parts Universal TV Stands DLP Chips ShopJimmy TV Parts TV Repair TV Lamps Light Engines Tri State Module
Jul 08, 2017 | Televison & Video
Magnavox rear projection tv - sound cuts off when
Problem with SSB module and will burn out a resistor on SSM board eventually and will have no sound at all.
Apr 12, 2010 | Philips Televison & Video
Look for a part SSB board
Try it on ebay. How it will be there
good luck
Jan 27, 2010 | Dell W2606C 26 in. HD-Ready LCD Television
I have a phillips 42'' lcd tv and was told that i need to replace my ssb board and it would cost 500 dollars. how can i fix this myself if i buy the part
ssb board should be available thru tristate module or pts electronics-if you give them the model number they can give you the price
Sep 04, 2009 | Televison & Video
I have a Philips Projection TV Model 55PP241761 from label but 55PP241/76 seems to be the number recognized. The chassis # is PTV 918. After a few minutes the audio will shut down. Also the buttons on the...
Hi
Try to replace the sound board and please provide the no that appears on the back of the remote to find the replacement.You can also buy the remote from remotes-central.com or replacement remotes.com.
Mar 15, 2009 | Philips Televison & Video
TV doesn't come on
Your SSB Module is Bad Part # PH3912725881.
Jan 02, 2009 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Philips 42PF7320A blinks 3 times every time i hit the power button
The SSB is small self contained board that u connect your Antenna, and HDMI to. An error three is a communication error between the SSB and to Logic board ( located underneath the SSB on the back fo the plasma panel that is just below the power supply. U can check parts.com and see if u want to purchase a SSB for this TV. Is the 3blinking lights coming from the front of the TV. Also check the power supply and see how many times the green led blinks on the upper left of the power supply and let me know.
Apr 24, 2008 | Philips 42PF7320A 42 in. Plasma HDTV
Philips 60P8342 60" Rear Projection Television Logo
128 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
