Suzuki super carry 1.3 engine revs high low high low high low when clutch is put down engine revs very high
wow no year car stated nor a country x10 worse.
welcome to our USA forum!
the country with ZERO, carry cars. not a one. here
and due to that , no books here nor coverage at mitchells. either.
That is a G13 engine, (not m13) is my 1st guess.
Most Suzuki's with tiny engine and run a map sensors, not MAF
so is called SPeed Density system.
if yes, the that means ALL vacuum leaks cause fast idle.,
armed with that juicy fact, we know why it races.
you never said and actual RPM so no Tachometer?
only 2 causes. a huge vacuum leak
or unlikely the ISC stuck wide open with gunk inside, (clean it?)
ISC is idle speed control.
old suzuki's had man killler ISC software, my 91 did it.
and all others like it........
it would hunt idle like mad with any vacuum leak.(of any kind)
today this is very *******, this mode. (hunt)
toyata cost them $1billion in fines for this same deal.
but Clutch drivers have no problems with idle hunt, "skills"
what year/country.?
please showa photo of engine. ?
and win. a win/win
you win and I win not guessing all that.
fact 2 , is that that hunt tells me the ISC is moving fast.
so is not stuck. (99% says R3PO)
unplug ISC see the hunt end? sure.
the ECU has lost its wits. from..... this....
it sees a massive air leak (vacuum map readings ) and then (dumbblly ) hunts it like mad, (bad Firmware code) but real.
i can demo this is seconds hood up.
causes?
1: vacuum hose fell off.
2: same hose cracked.
3: brake booster diaphragm cracked, sucking air big time)
4: lots more,. even gunk under throttle plate blocking it open.
and more. lots more. can cause lots of vacuum leaks.
