Question about HP Compaq d530 PC Desktop
BIOS doesn't find SATA HDD
I bought a second-hand HP Compaq d530 PC with a PATA HDD already installed.
I pluged a SATA HDD as well, but it doesn't find it. I think I've enabled all necessary BIOS settings, but I tried different options nevertheless. I also tried to unplug the PATA HDD, tried with both SATA slots, but it still doesn't work.
Any suggestiongs?
Boot into BIOS and enable SATA
Posted on Aug 25, 2009
    Sergeant:
  • 352 Answers
Hi fallacy,
If you have the system disks and you can boot from CD, I would just follow the prompts to reload the operating system. If the computer cannot see the CD or HardDrive you need to reset the BIOS setting to factory default settings and that should restore the drives to be used. Note: Hard Drive should be Primary Master and CD-Rom, (not DVD-Rom if you have one) should be Secondary Master. If you have a DVD Rom drive I recommend unplugging both power and data cords from it and making sure the CD-ROM is set to Secondary Master, NOT Secondary Slave.
This should allow you to boot to a CD and reload the operating system. Unfortunately your files are lost.
anaanymous
Rate Me Please! Hate it? Rate it…Like it, try it!
Thank you for submitting your question to FixYa.com
Would you please take a moment and show your appreciation by rating my performance.
All ratings and comments are welcome. Thank you - anaanymous
Posted on Oct 18, 2008
Compaq Mini 700EL hdd not recognised
If you are installing Windows XP then -
The problem is that XP installation CD does not have a SATA driver, unless you have a SATA drive on a disk etc. and can install the driver when XP asks for a hard drive driver then, XP cannot detect the hard disk and therefore won't install XP. The FIX. Go into the BIOS and disable the SATA drive (enable IDE emulation), this will make XP think it is a IDE/PATA hard disk. Then you can install XP normally. When Windows has been installed then install all the device drivers (including the SATA driver), then shut down and boot up and got into the BIOS and enable the SATA drive.
Oct 08, 2012 | Computers & Internet
XP installation problem - HP Cpmpaq 6720s Laptop [HDD detection error]
The hard disk is not detected because this model notebook has a SATA hard drive installed and the XP installation CD does not have a SATA driver, unless you have a SATA drive on a disk etc. and can install the driver when XP asks for a hard drive driver then, XP cannot detect the hard disk and therefore won't install XP. The FIX.
Aug 12, 2011 | HP Compaq 6720s Notebook
Hello, My my motherborad is ASUS p5rd1-vm;RAM1GB and hard disk is PATA 80 GB but the HDD is having some kind of problem and the windows have shown a warning about it several times. Now i want to buy a...
Yes, it's compatible with the motherboard, no, it's not compatible with the XP install disk because it doesn't have SATA support. And since Asus doesn't provides it special driver needed (one that must be put on a floppy) it means that you simply cannot install XP on this disk.
All you can do is to obtain another PATA hdd what ever its size and install XP in it. Then put the new SATA disk in and use it to store all the installed programs and all your files on it. As a bonus you won't lose them if the new PATA disk fails or XP gets corrupted.
Or install Vista or 7 instead of XP, the have support for SATA disks
Jul 28, 2011 | ASUS P5RD1-VM Motherboard
I have HP Comaq Presario SR1617CL Desktop PC, part number ED870AA with a Samsung SpinPoint P80 SP1604N - hard drive - 160 GB - ATA-133, I would like to upgrade to a 500GB hard drive. I have a ASUS A8AE-LE...
XP cannot be installed natively on an SATA disk without the appropriate driver which must be loaded during the install - an extremely complicated maneuver. The best way to deal with that is to just add the new SATA hard disk: install XP on the PATA and use the new SATA for your files as a separate partition. The adapter cable can be bought for about $5 from the same shop as the hdd.
All the other modifications are just fine - just remember , the RAM will not be fully recognized and used because of the limitations of the 32bit XP.
Mar 11, 2011 | HP Compaq Presario SR1617CL PC Desktop
I want to install a sata hdd to compaq d530 sff
You will need to purchase a sata cable if id does not come with the drive.
When you boot your computer press F2 to enter the BIOS, look in the Drives settings and be sure the SATA0 is enable.
Install the drive, connect Data and Power.
Boot to your CD media to install your OS.
That should do.
Please comment and rate if this was useful.
Thanks,
Oz
Feb 12, 2010 | HP Compaq d530 SFF PC Desktop
Gigabyte 945 gzm s2 doesn`t recognize HDD Western Digital 320 GB
You might need to change your bios settings from ide to sata. Have you already checked the bios settings? If everything is in order you might have a bad board. What have you tried so far?
Nov 20, 2009 | Gigabyte GA-945GZM-S2 Motherboard
I have a hp d530 and by mistake I added a second hard drive and now my bios it's scrwed up, how can I fix it?
check the second hdd you just installed and see if the pin is set to master. make sure its set to slave that sounds like your problem both hdd are trying to boot at start up.
Oct 24, 2009 | HP Compaq d530 PC Desktop
ATA HDD on IDE connector with a SATA drive on a SATA connector?
Yes. You can leave the ATA-IDE and add SATAsCan you not still buy a 150?
Dec 31, 2008 | HP Compaq d530 PC Desktop
Does my d530 CMT have a SATA connector?
Answers to your questions:
1. Yes
2. Very likely
3. a Google search should show you what the connectors look like.
4 HP/Compaq do a good job of providing documentation. Go to hp.com and put in your system information. You should be able to locate motherboard diagrams there. If you can't let me know and I'll try to locate them.
Dec 29, 2008 | HP Compaq d530 PC Desktop
What new HDD will match my Maxtor DiamondMax Plus 8?
Mark,
You can use any size HDD in your computer as a slave and it does not have to be an exact match for the maxtor. You will however need the make sure that the connections on the new drive match. For example SATA drives will not attache to an IDE cable and vice versa. The drive that you mentioned is an IDE style drive so unless your MOBO has SATA connectors on it you will need to buy an IDE/EIDE drive.
HP Compaq d530 PC Desktop Logo
343 people viewed this question
Top HP Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
