No white color on my hp lcd monitor
My 17'' hp lcd monitor stopped working so i changed the 3 capacitors and luckily it is ok except for the color which is a bit yellowish (there is no white ..) any suggestion thanx.
  • Fran Bednar
    Fran Bednar May 11, 2010
    How many capacitors were left on on the board that you didn't change ?
    Did you try the brightness and contast adjustments ?
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 191 Answers
Check the output of your power pack .you are having voltage drop in your output supply
Posted on Oct 19, 2008
Sound ok white screen no picture
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
Take it to a repair shop.
Jul 28, 2014 | Sony KLV-37S400A 37 inch Multi-System HDTV...
17" flatron crt monitor only green led blinking and tick tick sound .No display
- Flickering screen
- Dim screen
- Slow start
Apr 21, 2014 | LG Flatron F700P 17" CRT Monitor
Delayed reaction and white colors
- Flickering screen
- Dim screen
- Slow start
Apr 08, 2014 | Acer V193w LCD Monitor
My HP Lcd L1740 Monitor works fine except I can't get the usb ports to work. Please Help.
hi i have hp lcd 1740 have power but skin is white pls pls ane body give me soletion
pls pls
Jan 15, 2011 | HP L1740 17" LCD Monitor
Monitor is changing color when power on:- red, green, yellow, violet, white, blue etc......repeating continuously ...... more tha ten times switch off monitor but the problem remain the same... VGA...
1706,
the monitor is bad if OSD , menu shows bad colors
try the reset in the OSD menus,,
google, HP L1706 manual, read it.?
some newer hp monitors even have test pattern in the OSD pages. (on screen display) try that.
Oct 04, 2017 | HP L1706 17" LCD Monitor
Color Problem
all of you mentioned are correct. if they cannot work on color setting of your monitor and for the setting of your resolutions it could be the monitor. the monitor cannot support the color bit mode which required for the windows vista it could be a 16bit color mode which only display for not more than 63herts for the Hi color vsynch compare for the 256color if you have a Hi color settings for about more than 63herst vsynch. it cannot display properly. thanks
May 10, 2009 | SVA-USA VR 17 17" Flat Panel LCD Monitor
I replaced the 3 capacitors now there's just bright white screen
Open your monitor back up and look for unplugged connectors, especially the one to the back of the LCD. I had this same problem with a HP F1703. The owner whacked it so hard when the backlight stopped that they dislodged the connector.
Feb 27, 2009 | HP Pavilion F1903 19" Flat Panel LCD...
Dark picture
you probably have a bad capacitor on the invertor board. try shining a flashlight into it to see if you can see anything. if capacitors are good, you might have some burnt out backlight bulbs. i just had the same problem, replaced the capacitors but messed something else up on the way i guess cause now all i have is a bright white screen with a few colors here and there.
Aug 30, 2008 | HP Vs17 17" LCD Flat Panel Monitor
Dell lcd monitor with vertical lines
You have a filter problem, check power supply for bad capacitors.
Mar 24, 2007 | Dell E173FP 17" Flat Panel LCD Monitor
Computers & Internet Logo
445 people viewed this question
David Payne
David Payne
