Sharp XL-HP535 Hi! Have the problem. The system can not read any CD, writes "Read TOC", then "No disk". Lens clean, mechanics working well. I think the problem with the laser itself. How do I check?
  • 1 more comment
  • arlekino Oct 18, 2008
    I run CD realignment process (FOF, TOF, TBAL, TGAN, FGAN, RFLS), but  test stops at  TBAL. When I turn off the system - CD drive motor continues to work...
  • Anonymous Oct 31, 2008
    same as previous
  • dehowletts
    dehowletts Dec 17, 2008
    i have the exact same problem if i eject then re-insert the CD sometimes it'll play....
    but it won't play anymore than 3-5 minutes of an mp3 disc....?
    Problem Solver:
  • 14 Answers
Hi try this.....
Put the system in standby (ie off but plugged in) then whilst pressing down the record button and the X-BASS/DEMO button, press the PRESET DOWN (i.e.left hand one) button until "CLEAR ALL" appears, then power on your system.
This gave me some functionality back i.e. i can play normal wave CD's but not mp3 ones....
Hope this helps
Posted on Dec 17, 2008
Sharp XL-HP515 CD Player won't play. Displays "toc read"
take it apart and clean len with a qtip an rubbing achol on face and mirror sides(top and under
Oct 09, 2009 | Philips CDR770 CD Recorder
The problem is i cant play mp3 or DVD s in my philips dvd player when i insert sometimes it plays but sometimes it says LOAD but doesn't play.product code is philips dvd dvp3268
When the unit does not load any disk, that is usually because of a problem with the optical laser lens that is dirty, faulty or opaque, and will start operating on certain disks better than others.
In that case you will hear disk spinning, whirring and clicking, but the TOC (table of content track at start of CD/DVD will not be read, therefore the error.
Whe this problem is starting you may be able to read only CD, DVD or Blue ray, or for example only DVD-R and not +R , or only to read and not to write and so on. After more prolonged usage , often the unit goes losing the rest of functions, and ends up not reading anything at all.
If instead there is no noise, and disk does not spin at all , then there is a faulty motor, or the motor micro-switch is bad. This situation is far less common than the lens problem.
Try first using a CD/DVD or Blue ray lens cleaner disk to clean the lens. If that does not work you will need to disassemble the drive , and clean lens directly with q tips and isopropyl alcohol, or to replace the CD/DVD lens, or the whole drive unit.
Jul 21, 2009 | Philips DVD625 DVD Player
Not reading DVD and CD's :-(
When you get no disk error, that is usually because of a problem with the optical laser lens that is dirty, faulty or opaque, and will start operating on certain disks better than others.
May 01, 2009 | Philips HTS3450 System
My dvd-rom model gdr-8163b won't play or read . it spin once and stop
Apr 26, 2009 | Computers & Internet
My cd rom not reading any cds
In that case you will hear disk spinning, whirring and clicking, but the TOC (table of content track at start of CD will not be read, therefore the error.
When this problem is beginning you may be able to read only CD, DVD or Blue ray, or for example only DVD-R and not +R , or only to read and not to write and so on. After more prolonged usage , often the unit goes losing the rest of functions, and ends up not reading anything at all.
Try first using a CD lens cleaner disk to clean the lens. If that does not work you will need to disassemble the drive , and clean lens directly with cotton tips and isopropyl alcohol, or to replace the CD drive unit.
Apr 13, 2009 | LG CRN 8245B (CRN-8245B) Internal 24x...
CD ROM not working
When the CD does not read any disk, that is usually because of a problem with the optical laser lens that is dirty, faulty or opaque, and will start operating on certain disks better than others.
Mar 05, 2009 | Candy CDC266 Dryer
Cd not reading
Try first using a CD/DVD lens cleaner disk to clean the lens. If that does not work you will need to disassemble the drive , and clean lens directly with q tips and isopropyl alcohol, or to replace the CD/DVD RW drive unit.
Feb 24, 2009 | Samsung (SHM522CBEWN) CD-RW/DVD-ROM Combo...
Wont play disk has error code
It is a lens problem, the laser lens is either dirty or the lens pickup is faulty.
Oct 01, 2008 | Sony DAV-DX250 System
Errors out on blank cd only
use disk cleaner lens cleaner cd ok and only use hi end memreox in it or better not cheap shit i own this one i love mine -12 dbu for live band -8 craniks out clean live recordings from mon out on mixer use a cleaner cd with brushes on it fiber ones clean lens for u ok run few times 20 bucks at store get one use clean cd s onlow clean it off nice blow it out nice blower ok
Jan 19, 2008 | Tascam CD-RW750 CD Recorder
Xl-hp515
wait a bit... it will happen with all the other decks, too. we had this happen and the first time the suggestion from the Sharp folks worked. We left the unit unplugged overnight to reset the electronics (and of course all the station presets, etc.) now, we have it happening again and all 5 drawers are out. the "read TOC" then report "no disk". i will try the lens cleaner but if that doesn't work, we will take it to a repair shop. our unit is actually almost 3 years old so it is past the extended two year warranty, but still it is too soon for it to be acting up. i hate cheaply made stuff like this! good luck.
Apr 12, 2007 | Sharp XL-HP515 CD Shelf System
473 people viewed this question
 Grubhead
Grubhead
