Question about GE 30 in. JGP336 Gas Cooktop
GE ZGU650 EM1BG Gas Cooktop
The ignitors usually stay on after the flame has started. do the ignitor electrodes need to be replaced or what?
How do I access the parts - through the burners or from the bottom? How?
the stove is 15 years old but this has beengoing on for years and I am finally tired of listening to the continuous clickkkkkkkking.
Thanks!
  • 2 more comments
  • JaneTrades Oct 22, 2008
    thanks for trying. Re your first comment the spark always initiates when a burner is turned to high, however, often once the flame starts the ignitor continues to spark. if the burner is turned off at any time the spark will cease as well.
    the ignitors never run or spark when the burners are off...thank God for that!
    I do not understand what is meant by "a contact not opening". what would be the solution for that, i.e. what coule be done to make sure the contact is opening once the flame starts? I may have since stumbled onto a solution by pushing the electrodes down as far as they can go (the electrodes can be pulled up or pushed down a little ways).
    Can the burner be removed from the top to take a look by loosening the brass nut where the gas comes up from?
    Thanks again for trying. looking at the prices of new cooktops I hope this one does not need to be replaced any time soon,
    JaneTrades
  • Norm W Oct 28, 2008
    I have GE Gas cooktop with 5 stove, my problem is very similar to Jane. The ignitors making clicking noise after the flame has started, turning the knob from low to high or high to low sometimes stop the noise. Another way that I found out was to use a screw driver by touching or moving the internal wire under the knob would stop the clicking noise too. The cooktop is about 5 years old. Is the problem fixable or I need to look for a new cooktop?
    Norm
  • Steve Allison
    Steve Allison Jul 23, 2014
    It looks like someone has dealt with this and it may apply to your cooktops as well:
  • Steve Allison
    Guess I'll just post the link:http://www.fixya.com/support/r9980195-ga...
  • GE Master
  • 5,568 Answers
On any range I've seen with electronic ignitors, the valves have a position that closes a contact to turn on the ignitor and manually moving the dial to the 'Hi' setting opens the contact again and the ignitor ceases to spark.
You don't mean the ignitors run even when the burners are off, do you?
I'm surprised to read that this has been happening for 'years,' the transformer for the ignitors must be really tough to withstand that and it doesn't sound like an electrode or transformer problem but rather a contact not opening as it should or you not advancing the control past the ignite point.
Posted on Oct 18, 2008
  • 1 more comment
  • Steve Allison
    Steve Allison Oct 22, 2008
    The ranges with which I am familiar, use a cam on the control shaft for each burner that presses against a stationary switch that turns on the ignitor. The cam usually presses on a switch via a leaf spring or directly on a button then release it once you have rotated the control further.
    Since it seems everyone re-invents the wheel, the location of the cam is not predictable but it must be along the length of each burner shaft.
    There is typically one high voltage supply that services all burners; you can see if that is the case with yours by observing the spark gap at each burner, if they all spark together, then it is a single voltage source.
    If only one of them sparks, then you have separate sources for each burner. Since that costs a little more, most manufacturers use only one.
    If they are all sparking together, then you need have only one bad (or not properly adjusted) switch causing the problem.
    Increasing the spark gap may stop it from clicking at you but many types of high voltage take offense to not being able to release the energy where it should be done and will discharge the spark internally; something that can be fatal to them over time.
    I'm not familiar with your particular range so can't offer much guidance for gaining access to its innards but in any case, be certain you have shut off any valve related to the range before doing any kind of removal of anything.
    It pays to be a little paranoid when dealing with gas.
    I wish I could help you more then your problem may be caused by an old spill that has mechanically interfered with the switch operation or just the need for a simple adjustment but I don't know personally of a source for repair info on your range that I can access.
  • Paul
    Paul Jul 21, 2014
    I have a GE ZGU650 Gas Cooktop that I have successfully repaired.
  • Paul
    Paul Jul 21, 2014
    Adding to the above. I found the ignitors would keep sparking after the gas had lit on some of the burners. By adjusting the flame, the ignitors would stop sparking. Hmmm. Strange. Here is what I discovered. The ignitor electrodes are fed by a module that is activated by a switch closed by a cam on the gas control knob. If the gas is on, the switch is closed. This tells the spark ignitor module to start sprarking. When the gas is ignited, the flame (a plasma) can conduct electricity. This conduction is from the electrode to the burner cover (the removal thing with all the holes). The conduction is through the burner cover to the burner frame it sits on. I found that because of cleaning, the burner cover bottom was rusted, hence, restricting the conductivity. Ran the covers over a piece of sand paper so the covers made good bare metal contact with the frame below..problem solved. In addition, I found I had several burners where the spark wouldn't go at all. Removed the knobs. Stuck a pencil in to trip the switch lever to activate the spark. However, the plastic cam wouldn't trip the switch. I put some foam tape on the cam. Now the cam tripped the switch. Problem solved. Tape and sandpaper is the only cost.
I have ge jgp337 . My gas stove started ingniting without turning the burners on and all flame started coming out from all 4 burners. i switched off the electric switch now even after 2...
I've seen this problem before. It happens when spillage get's into the ignitor switches. The switches are mounted on top of the gas turn-on valves. You have to replace all the ignitor switches because they are connected into wire harness. Rich
Aug 15, 2010 | GE 30 in. JGP337 Gas Cooktop
I have a GE model jgp940 gas cooktop one of the four burner electrodes will not spark.
You have to determine if it is the electrode or the ignitor module and replace the component. A simple test is to swap the wires on the spark module for the non working one and see if the other electrode still works. If not the electrode is bad, if it does than the module is bad.
Eric
Dec 24, 2009 | GE 30 in. JGP336 Gas Cooktop
The electrodes are ticking when we turn on the burners
THAT IS THE IGNITOR FOR THE GAS. TURN THE KNOB JUST BEYOND THE START POSITION AND IT SHOULD STOP. IF NOT UNPLUG THE STOVE AND FIND THE IGNITOR ON THE BURNER HEAD AND CLEAN IT WITH A SOFT TOOTHBRUSH. PLUG THE STOVE IN AND IT SHOULD STOP CLICKING
Aug 22, 2009 | GE JGP975SEKSS Stainless Steel Gas Cooktop
Ge jgp337 ignitors continue to click after gas ignites
You have a bad ignitor which will have to be replaced. Unplug one ignitor at a time until you find the faulty one.
Jul 24, 2009 | GE 30 in. JGP337 Gas Cooktop
Ignitors are igniting on their own
they are not lighting they are sparking on there own right? No actual flame? if they are sparking on there own you need a new spark module.
May 30, 2009 | GE Cooktops
Gas Burner ignitor is not working
Yes it should be an easy fix.
Ignitors simply go bad from time to time.
If you have a meter you can check to see if you have voltage going to the ignitor. If you do, and it isnt trying to ignite, replace the ignitor.
If you have no meter, ignitors are usually less than 30 bucks so you will not be to much in the hole by just replacing it.
If you lift the cover to access the ignitor, it should be held in by two crews, the gas tube, and a wire to the flame sensor.
Make sure you turn off all gas and electric before disassembling.
You can find ignitors at your local appliance parts supply house.
All you need is the model and serial numbers.
Dec 27, 2008 | Cooktops
Viking Gas Cooktop - Ignition sparks continuously when in 'on' position
This is likely caused by either a dirty ignition electrode, a cracked ignition electrode, or a bad spark re-ignition module.
Clean and inspect the six electrodes for cracks, If that doesn't solve it order a new
Ignition module from an internet appliance dealer that carries Viking parts like Appliance Zone.
If you replace the Ignition module yourself, make sure to turn off the circuit breaker to the range/cooktop before you work on it. Also, make a drawing of where the different color leads are plugged into the ignition module before you unplug the wires and plug them into the new re-ignitor. If the unit is under one year, this should be covered under the warranty.
Viking had a recall a few years back on their ignitor modules.
Jun 03, 2008 | Cooktops
Ignitor not working
Yes, electrode is also called as ignitor. Both are same.
May 15, 2008 | Amana AKS3040 Gas Cooktop
Igniters are not working right
when you turn any burner control to lite all ignitors should click this is normal industry wide. the ignitors are controlled by switches that are placed over the valve shafts they are wired up together so thats why they all click when you only operate one valve don't worry about it. the ignitor stays on untill you back the valve off a tad this is also normal.
Apr 15, 2008 | Cooktops
GE 30 in. JGP336 Gas Cooktop Logo
1,011 people viewed this question
Top GE Cooktops Experts
Dan Webster
Dan Webster
Dave Harrison
Are you a GE Cooktop Expert? Answer questions, earn points and help others
