Question about Hitachi 60EX01B 60" Rear Projection Television
Main color is it true you can blow out the color converters by adjusting it to much ...on the matrix
    President:
  • 3,130 Answers
The Matrix?? Color converters. Ok Lets assume you mean the screen controls that adjust each color of the Picture tubes?? No you can not. Oh maybe your taking about the convergence? Its only necassary to adjust the lines on the GRID or CROSSHATCH if they are drifting and out of alighnment. You certainly can, if your tweeking the controls all the time, wear them out but that would take alot of tweeking. If your set needs tweeking all the time then there is a problem in the convergence and should be addressed asap or the problem will get worse. ou should never go into a set as theres high voltage even when the set is unplugged for a while and will hurt you bad. Always seek a pro in case you need any internal alighments or tweeking. Good Luck
Posted on Jun 09, 2006
How do i convert a decimal answer to fraction format on a TI 89 titanium.... prefferably with matrixes
It is just a matter of being in EXACT mode. To set your calculator in EXACT mode here's the key sequence. Press [MODE] [F3] [Up Arrow] [Up Arrow] [Right Arrow] [2] [ENTER]. Now when your in the Matrix Editor you can input your numbers in decimal form and, they will be automatically be converted to a fractional format. Pictured below is a matrix that was entered using decimal numbers and, was converted into factional form. Notice at the bottom of the screen the calculator is in EXACT mode.
Here's the same matrix in the HOME screen.
Next is the same matrix converted back to decimal numbers. Notice at the bottom of the screen the calculator is in APPROX mode.
And of course when I turn the calculator back to EXACT mode and, Re-ENTER the decimal formatted matrix in the HOME screen the fractional formatted matrix reappears.
You can use the propFrac( command but, having in the EXACT mode setting works better.
Dec 06, 2010 | Texas Instruments TI-89 Calculator
I have no heat inside the car 825 rover checked the pipes there is heat going in but the outlet pipe is cold is it possible the thermostat is not opening to allow the flow thru the heater matrix
no the water should bypass thermostat, its is more likly that either your heater matrix has an air traped or is blocked from sediment, i would opt to first try the blocked test . undo both pipes that go to the matrix , using a hose pipe connect to bottom pipe on matrix and turn hose on to flush out matrix, continue running until water runs clear not rusty colored, then connect to top pipe and repeat, repeat several times until your happy it is clean, reattach bottom pipe and fill from expansion bottle until water flows from matrix then re attche the other hose, you can also try this on your main radiater . hand book states it should be flushed every 2 years .
Jan 04, 2010 | 1996 Land Rover Discovery
Color is off in Sony KP-53HS10 Rear Projector TV
http://office.manualsonline.com/manuals/mfg/sony/kp-61hs10.html
May 15, 2009 | Sony KP-53HS10 TV
Screen sizing
Your problem is that the correct video driver is not installed and therefore cannot use all the video RAM.(the XP version of the video driver won't work with Win98).
When you adjust to True color at a higher resolution it drops to a lower resolution because it has insufficent video RAM, but you will get a higher screen resolution at a 16 bit color because it requires less memory (video RAM).
Install the Win98 driver for the graphics card and then it can use the full video RAM at a higher screen resolution with 32 bit color.
May 01, 2009 | Computers & Internet
How to convert the color printer to Black?
No,sorry. Even if the print looks like it should use black toner only,it uses a little of color toner depending on the shade .
This is also true for other laserjets and inkjets
Hope this helps
Mar 31, 2008 | HP Color LaserJet 3500 Printer
Recommended best settings for the TH-50PZ700U Plasma TV
Try this one and see if you like it!
Normal: No
Picture mode: Custom
Picture: +22
Brightness: +9
Color: -3
Tint: 0
Sharpness: 0
Color temp.: Warm
Color mgmt.: Off
C.A.T.S.: Off
Zoom adjust: (grayed out)
PC adjust: (grayed out)
-- Other adjust menu
Video NR: Off
3D Y/C filter: Off (grayed out)
Color matrix: HD (grayed out)
Block NR: Off (grayed out)
Mosquito NR: Off
Black Level Light
3:2 pull-down: On
HD size: Size 2
Dec 26, 2007 | Televison & Video
Convergence settings
7 8 9 to select R G B, 4 to select moving part a line, full line or the whole matrix. S.mode to save your setting. Adjusting using arrow keys.
Nov 08, 2007 | Samsung SP42P2S Television
Hitachi 60EX01B 60" Rear Projection Television Logo
27 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
