Question about Gigabyte 8VM533M-RZ (GA-8VM533M-RZ) Motherboard
No Display my mother board model gigabyte GA-945PL-S3, i try to up date the Flash Bios, during i reboot the pc no more displat on monitor but all component are work speacialy the Processor, i try to change VGA Card but still the same also Memory pls help me how can i return to original set up Ty
    Problem Solver:
  • 5 Answers
Try to remove the motherboard (BIOS) battery in order to return to it's manufacturer's default settings....
Posted on Jan 31, 2009
My Gigabyte Mother Board shows some time Load Optimized Defaults then boot / Load Optimized Defaults then reboot / enter BIOS. How to fix it?
Two things come to mind first. Number one would be making sure you have the most up to date bios. Number two would be that maybe the motherboard battery is dying/dead and isn't holding enough charge to after being shut down to save the option you selected.
Apr 11, 2014 | Gigabyte Technology Gigabyte GA-H61M-S1...
Multimedia driver
This is the manufacturer webpage support, you can get the driver from there.
http://www.gigabyte.com/products/product-page.aspx?pid=2536&dl=1#driver
Good luck.
Remember to rate my posible solution. Thanks.
Jul 12, 2011 | Gigabyte GA-945PL-S3 Core 2 Duo/ 945PL/...
Just installed seagate barracuda 250gb 6gb internal hard drive with a gigabyte ga-945pl-s3 mother board and it will only recognise 130Gig! been through the bios but nothing stands out to say enable larger...
The maximum hard drive you can install depends upon the BIOS. You MAY BE able to install a larger hard drive if the BIOS upgrade will allow it. I suggest you go to the Gigagyte WEB site to check on this possibility.
http://www.gigabyte.com/support-downloads/support-downloads.aspx
May 19, 2011 | Seagate Barracuda 7200.9 (ST3250824A) 250...
I dont have mother cd with me and i need to install the mother board cd in my computer becoz display are not working properly
Your board has Socket 754, VIA K8m800 and KIA VT8237 chipsets With Realtek sound. S3 Graphics Unichrome. This is Gigabytes link to downloads. I ahve entered your info but will outline for you.;
http://www.gigabyte.us/support-downloads/download-center.aspx
Option 1
1 Select Product catagory Motherboard
2 By socket- socket 754
3 By chipset-VIA K8M800
4 Model Name- GA K8VM800M
Click search
New screen, scroll down and enter o/s
Drivers will show up Scroll down to VGA Driver and pick
"VIA K8M800 Driver. scroll to right and click on "America"
This will give you your most recent driver.
Mar 26, 2011 | Gigabyte GA-K8VM800M Motherboard
I have a intel dual core 3ghz cpu my mother board is Intel DG41RQ main board when on my computer the CPU fan is running but no display i check the CPU & ram and monitor that works fine on...
hello there
it seems that your on-board video card having trouble, try to put external video card to your system and power up your computer.
thanks.
Mar 01, 2011 | Gigabyte GA-M61P-S3 Motherboard
Can this mother board support hardware virtualization with amd processor athlon x2 64 3600+ what bios version that is not beta can i put it into my bios thanks
I think you can placed in this mother board.
Just follow socket no, and you need AM2 socket supported processor,here speed not the factor.
For more details follow the bellow link please.When your processeor suport AM2 socket no problem.But don't buy Am3 socket supported processor.It will be wrote down on processor box.
Details for click on link=http://reviews.cnet.com/motherboards/gigabyte-ga-m61p-s3/1707-3049_7-32330110.html#userOpinions
Click on this bellow link also.
http://www.gigabyte.com/products/product-page.aspx?pid=2434#ov
Hope it will help you.
Jan 01, 2011 | Gigabyte GA-M61P-S3 Motherboard
Dear Friends i have used in gigabyte mother board model no:GA-G41M-ES2L the problem is how i update my bios now is currently used in old version 1.0 but i have to update my bios pls tell me and solve...
you need to flash the bios .
download the new bios from gigabyte website and follow their instructions on how to update bios. be very carefull when doing this because if done incorrectly it would render your motherboard useless permanently .
in my experience if your m/b is working its best not to update the bios only time i would update the bios would be if the new bios update has new features that i really needed . if not i would not really flash the bios .
Aug 02, 2010 | Gigabyte GA-G41M-ES2L Motherboard
Gigabyte GA-945GCMX-S2 Motherboard having display..
At first I thought your screen went black during the start up process. After seeing the bios screen. In which case I would've said it was a bios setting for the display. Then I realized that I think you mean that their is no display at all. When you push the power button. Only the monitor led light. So, it may be a problem with your RAM stick/s. You should make sure that they are properly seated in the mother board. If they are new, make sure they are compatible with that motherboard. If you can you should swap them out with known good ram sticks. You could also try installing a video card and see if you can get display to work through that one. Make sure your main power supply wire connector is pushed in all the way. Swap the power supply with a known good one if you can. If still can't get it to work you may want to take the motherboard out and inspect it for burns, cracks, and anything that doesn't look right. Maybe contact the manufacturer of the motherboard and ask them what you can check. hope this helps.
Sep 17, 2009 | Gigabyte GA-945GCMX-S2 Motherboard
Gigabyte GA-945P-S3 short beep codes on cold boot. Tried reseating RAM, didn't help. system runs fine after beeping stops
Using the manual for the Gigabyte GA-945P-S3 MB. Go to page 71 & you'll see bios beep codes for your board: AWARD BIOS Beep Codes 1 short: System boots successfully 2 short: CMOS setting error 1 long 1 short: DRAM or M/B error 1 long 2 short: Monitor or display card error 1 long 3 short: Keyboard error 1 long 9 short: BIOS ROM error Continuous long beeps: DRAM error Continuous short beeps: Power error As you can see there isn't a code for three short beeps. When you boot your system try to pause your boot up screen. See if the bios is reporting the correct total of memory in your system. Bios codes from the link below. http://www.computerhope.com/beep.htm#05 3 beeps for the AMI bios code reports Base 64K RAM failure. You can test your memory. Go to memtest.org Scroll down the site to just under the three screen shots. Download Memtest86+ V2.11 You have a choice in making a bootable floppy disk or a bootable CD-ROM disk. Once completed you boot your system to the testing program. Memtest will check your system memory. This should help. Thanks for using FixYa! Mike
Jun 04, 2009 | Gigabyte GA-945P-S3 Motherboard
Gigabyte 8VM533M-RZ (GA-8VM533M-RZ) Motherboard Logo
128 people viewed this question
Top Gigabyte Computers & Internet Experts
David
David
Alun Cox
Tony
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
