Question about Samsung SlimFit TX-S2783 TV
Sound Distortion on Some Channels
I have had sound distortion on some channels, not all, on this TV since I purchased it - If you turn the volume up to try and hear the conversation over the distortion the louder the scratchy distortion gets - As I said, this only happens on some channels not all, but if this TV was only for certain channels, they should have put that on the box - I see (NOW) since I have had this problem that some other people have complained about it before in the reviews of this TV, but that doesn't help me now!!!
Does anyone have an solution for me, Please???
    Champion:
  • 252 Answers
You need to fine tune for the distortion channel or else try to auto program
Posted on Oct 18, 2008
What would I experience if my tone arm cartridge was starting to fail?
Loss of sound in one or both channels. Poor quality sound in both or one channel. Distortion in one or both channels.
Jun 11, 2015 | Audio Players & Recorders
Hi I have Denon 1910 7.1 avr, I bought last February 2010, the right front channel is producing some sort of sound distortion (hiss and popping sounds) when the receiver is turned on, I tried...
I SUSPECT THE CHANNEL IS BLOWN.YOU COULD TRY OPENING THE UNIT AND SEE IF THERE IS ANY GLASS FUSES.ONE MIGHT BE BLOWN.IF NO FUSES THEN TAKE IT TO A TECHNITION FOR REPAIR.THAT WILL BE YOUR ONLY OTHER OPTION.I KNOW,I HAVE HAD THIS HAPPEN TO ME.GOOD LUCK
Oct 18, 2010 | Audio Players & Recorders
I have just purchased a tandberg 15.22 its in v good cond, no apparent head wear, I've replaced the belt (slow rewind) capstan is fine, there is distortion on the amp, I've cleane the record/amp/playback...
Resistors are good at causing distortion, you might spot one that has burned or broken. If the distortion is in both channels, which by what you say it is, then you might be looking for something common to both channels. Perhaps an IC.
Jan 21, 2010 | Audio Players & Recorders
My amp has 2 channels, clean and distortion. distortion works, but the clean channel doesnt. When i hit the button, it switches the distortion off, but there is no sound. The distortion light stays on...
initially you want to think bad solder joint, but it think its a bad mosfet or rectifier or diode. it would be hard for an untrained person to identify your problem let alone an experienced tech. it may be time to move on to another amp. in my shop it would be at least 65 bucks for the repair. so where did the "heat"/energy go from that point and what parts were affected. there may be a domino affect. burn one part, not usually.
yostamplifier.com
Jan 17, 2010 | Marshall Mg50dfx 50-Watt Combo Guitar...
I just bought my 46'toshiba lcd tv and the sound is distored for some channels. Is this my cable converter or my TV or....?
I would think it is your cable converter. Try hooking the cable directly to the TV without the converter. Pick some channels in the lower range and see if they have the same distortion as the cable converter. Thanks. Let me know what you find.
Nov 11, 2009 | Computers & Internet
Ew100 g2 - getting a lot of distortion and must scream into mic to register any voice sound. Volume and channels for mics are all adequate
Add a DI box to clean up/boost the signal of that mic. If all the channels are doing this, get a bigger (more watts) amp so that you have more headroom.
Aug 25, 2009 | Sennheiser Audio Players & Recorders
I bought the magnavox and all my channels are
Check the converter box. Many have a volume setting that is usually set very low at the factory. On the remote control for the converter check to see if there are volume buttons. If so, change the converter box volume higher, to a level that makes the TV audio level "normal", then use the volume control on the TV for adjustment as you watch. If you set the volume on the converter box too high, you may get some distortion in the audio from your TV. So adjust the converter box to find the proper output from your TV without distortion.
Jun 20, 2009 | Insignia Digital-to-Analog Converter for...
LG 32LCD LCD TV Problem
It turn out to be a $10 diode on the mainboard, which cost me $100 to have troubleshot and repaired
Jan 19, 2009 | LG 32LC2D Television
Loud distortion on Front Channels
Well, the nice thing about the newer amps is that the actual amp circuitry is all contained in a module and you don't have to do much troubleshooting. Just replace the module for that pair of channels. Bad news of course is the modules can be pricey. Should say right on it the part number, order it from mcminone.com or whoever, solder it in, use new conductive grease (many times I think these modules fail because the grease gets old, the module overheats and toasts) and you should be fixya'd
Jan 12, 2008 | Marantz SR-5200 Receiver
Red distortion
it sounds like your IR board is going out, its easy to replace and is inexpensive usually about 10.00 plus tax and shipping, and very easy to install, its one of the few parts you can buy for these models outside of the 479.00 dollar control box.
Dec 11, 2007 | Polaroid FLM-3225 32 in. LCD Television
Samsung SlimFit TX-S2783 TV Logo
190 people viewed this question
Henry  Thomas
Henry Thomas
