Question about Philips E-Box FTR9965 DTV Receiver
Philips 42 FD9954 will not turn on
My Philips plasma 42FD9954 will not turn on (very similar problem reported by others). DOes any one know if replacing Caps 2663, 2664 and 2662 will resolve the issue?
Thanks
5 Suggested Answers
  • 395 Answers
SOURCE: any ideas?
1) Replace C2663 by 2020 021 91677 (100uF/50V, 105°C).
2) Place Schottky diode 9336 247 60133 on pin 7 (+) and 8 (-) of IC7650,
to avoid negative pulses, resulting in this bad startup behaviour.
Posted on Mar 25, 2008
pizzaguy3274
  • 4 Answers
SOURCE: 42fd9954
Not a fix, but it got my tv on.
I removed the back and tried the power switch.
I located the relay that was clicking.
I have two blue relays in the middle of my power board.
I placed a hair dryer over the relay for a few minutes.
After four tries of the power switch and it stays on!!!!!
Heat keeps the relay from just clicking off.
I don't know why.
This will at least get the tv on though.
Posted on Apr 12, 2008
  • 3 Answers
SOURCE: Philips FTR 9964 Receiver Problem
The problem is in your cable connection on the back of your monitor or Box. I had the same problem and solved it by reattaching the VGA cable that was loose.
Posted on Jul 19, 2008
SOURCE: 42FD9954 philips plasma TV flashing LED it wont come on
The problem is in the standby power supply. the standby power supply generates the 9 volts and the 5 volts requird by the tv. If you measure the 9 volts source, with only the red light on, the correct voltage is 9 volts. However if the 9 volt measures 6.5 to 7 volts it is too low and the startup relays cannot operate. My set is a model 42FR9954/17S. In this set if capicator, 2603, is heated the voltage climbs to 9 volts and the relays work. If cold air is applied to the capicator the relays fail to operate. Replace capacitor 2503 and the problen is fixed. This capicator is: 47 Ufd, rated @ 450 volts, and is 20%.
Posted on Nov 15, 2008
  • 80 Answers
SOURCE: Power cannot start red led blinking
Check the power board for caps with the tops bulged up. 3300uf 10v.
Posted on Jun 01, 2009
My Plasma 42FD9954 42 TV doesnt work
Familiar problem on Philips Plasma units. PSU or Sustain board failing.
Jan 16, 2013 | Philips 42FD9954 42 in. Plasma HDTV
May 17, 2009 | Philips 42FD9954 42 in. Plasma HDTV
42FD9954
I have a philips 42fd9954 and it has a bad scavio board. are interested in selling your for parts?
tinske_J_M@vzw.blackberry.net
Nov 03, 2008 | Philips 42FD9954 42 in. Plasma HDTV
42" Philips plasma screen goes black
You have a Ysus problem. Sounds like a cold solder joint or loss connections on ysus main board.
Jun 03, 2008 | Philips 42FD9954 42 in. Plasma HDTV
Any ideas?
Mar 25, 2008 | Philips 42FD9954 42 in. Plasma HDTV
Philips E-Box FTR9965 DTV Receiver Logo
56 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
