Philco N1042X i have a philco N1042X washing maching and the handle have broke i have a new on but dont know where the spring goes
  • 4 Answers
SOURCE: not sure how the spring
http://laundry.manualsonline.com/manuals/mfg/lg/lg_washer_product_list.html Go to this sight and find your manual and the directions should be there
Posted on May 07, 2011
dontbother10
  • 2220 Answers
SOURCE: Husqvarna 136 chain brake handle spring.
You can get an IPL here:
HusqvarnaUSA.com
http://www.husqvarna.com/us/homeowner/support/download-manuals/
I don't think this has the detail you need.
If it were me I'd visit my friendly neighborhood Husky chainsaw seller (not Big Box Store) and ask to look at the clutch cover with the brake installed (take a camera). I'd probably ask for a quote for their repair too. HTH
Lou
Your model is no longer sold. The seller will know what model replaced it and may be willing to explain the repair procedure for your saw you. Take the cover and loose parts with you.
Posted on Sep 07, 2009
SOURCE: My son dropped the Hoover Floormate hard floor
I agree that it is the wheel assembly that's broken. However, my wheel assembly broke in a different place, so I bought a replacement part for $20 or so. I have never figured out how to swap it out...
After a few attempts, I believe it will require some major dismantling and not just a simple part-swap.
Posted on Oct 14, 2009
  • 240 Answers
SOURCE: the wheels with the spring broke off and I'm
This spring can be very confusing to install. It slides onto the wheel assembly near where the attaching pin is longer ( there are flat protrusions on both sides of the wheel assembly). One end of the spring pushes up on the assembly when it is in place, and the free end must be pulled down and inserted into the small slot in the bottom of the base. Pull down on the shorter end of the spring, holding the longer end, and slide it onto the round area on the wheel assembly. As you put the wheels back on, pull on the longer end and insert it into the slot in the base.
Posted on Jan 24, 2011
oldTech2332
  • 2341 Answers
SOURCE: Need to find a door handle for a Philco
There are a few places that specilize in restoring vintage places i have included a google search link for some of them and perhaps they can help ya find that handle
http://www.antiqueappliances.com/parts.htm
http://store.antiqueappliances.com/Refrigerator-Parts_c_1.html
http://www.denisbyrne.com/fridge.html
http://www.davesrepair.com/vintageparts.htm
Many others could be found by searching either vintage or antique appliance parts
Good luck i hope this helps ya,
GENE
Posted on Sep 18, 2011
How do i replace 2 3" springs on stratford recliner.
Get Recliner-Handles Sofa Spring Repair Kit for La-Z-Boy ...
? 1:37
www.youtube.com/watch?v=_hHUNVAQsk0
May 28, 2015 - Uploaded by Faith Rogers
Recliner-Handles Brand Replacement Sofa, Sectional, Couch, Love Seat, Recliner, ... This sofa seat spring ...
Replacement Recliner Release Handle For Stratford and ...
www.recliner-handles.com/replacement-recliner-release-handle-for-stratf...
This flapper handle will fit Stratford and Stratolounger recliners and others that ... 3 3/4 X 3 INCH INEXPENSIVE EASY WAY TO REPAIR YOUR RECLINING ...
Oct 31, 2015 | Washing Machines
Amana top loader washing maching permanently tilted drum & loud banging during spin cycle
I guess you washed some curtains and blankets in it that it spun unbalanced. There are 2 things. One is the one of the suspension springs broke off. Another is the center post is already bent. You may have to check inside. If you are handy, you can take off the cover and check. Suspension springs are dangerous when being replaced. You may have to wear a pair of goggles. With the centerpost, it is difficult to replace. I suggest you call a technician for this.
Jan 17, 2014 | Washing Machines
Door handle broke
This is not an identical one but is another LG that has the same latch setup. Hope these pics help.
Mar 07, 2012 | LG WD-16115FD Front Load Washer
How do I install a new Handle/Latch assembly on the door of a Whirlpool LHW0050PQ 4 Wash Machine...have to remove present one as broken---pull handle door catch does not release---have to release putting a...
I had to replace part No 8182408 - the washing machine door handle. There is a plastic bar in the middle of the assembly that broke because the door was opened too hard.
There are two springs, the latch, and the plastic piece that brings it all together. The smaller spring is the key, call it the L spring. It is shaped like an L and goes around the ends of the latch. The other spring is the larger and straight and goes around the tops of the plastic piece. The straight spring goes in with the crossbar facing on the outside of the washer. The latch with the L spring fits in between the plastic crossbar with the U shaped end pressing against the latches inside bar. The antenna of the L spring needs to wrap around the plastic bar and fit inside the straight spring bar. This applies pressure on the latch to stay closed. When the handle is pulled, it releases the pressure and allows you to open the door. The Metal bar is used to hold all the pieces together and once you have the alignment right, put it back into the door with the straight spring antenna tucked in the spots on the door, as well as the metal bar ends. Screw in the two spots that holds the assembly in place and you will be set. The door should open and shut easily.
Apr 22, 2011 | Whirlpool Washing Machines
How to put on new handle on indesit washing machine w133s
the spring will go so that it pushes the latch part in towards the outside edge of the door. the pin goes through the door frame, then through the spring's 'holes', through the latch, and back into the frame of the door. the spring ends should sit in a couple of grooves in the door part which may be marked/scratched by the previous one.
Feb 05, 2009 | Indesit W 123 Front Load Washer
BROKEN SPRING
Hi, check under your seat. at the frame there should be a bracket that the rod and spring goes thru and right to the pedal.
Nov 14, 2008 | Garden
Fixing the broken door.
the hook part points to the right because it has to engage the electric lock which is the right, in inside of the machine.
Dec 25, 2007 | Splendide 6200
Washing Machines Logo
139 people viewed this question
Top Washing Machines Experts
