Question about HP Officejet 6310 All-In-One InkJet Printer
When I scan ,refer to device doc to troubleshoot .! light flashes
6313 hp all in one no fax used will still photocopy .tried to use the disconect & move carrage & hold # & 6 still the same .Printer is only connected to laptop & has worked previously
  • Anonymous Oct 27, 2008
    when I scan it stops working
  • 234 Answers
Is it giving you a message as NO SCAN OPTIONS in the front panel of your All-In-One...?
If yes and if the software is insatlled sucessfully in you computer then try the steps mentioned bellow.
If the software is not installed then you will have to install the software for your All-In-One First.
And If the software is successfully installed in your computer, then you should have a icon in your desktop as HP Solution /HP Director (if not got to Start> All Programs>
HP> HP Solution Center)/HP Director Then try scanning from there, if you are able to scan from there then try the steps bellow.
Open solution center> Settings> Scan settings> Scan to setup> Then in this window click on Restore defaults> Then apply or ok and close all the windows and try to scan from the
All-In-One printer.
If it still does not work then try the bellow steps:
Go to:
My computer>C:windows>system32
Copy hpzipm12
minimize this window
Right click on Start button on the computer>Explore>Programs>Startup>edit>paste
minimize this window.
Go back to My computer>C:>windows>system32
Copy hpzinw12
Now you will see two new files in Startup
Now go to My Computer>C:Program Files>HP>Digital Imaging>bin>
Copy hpqtra08
close this window
Restart the computer
Open Hp Solution Center> Settings>Scan settings and preferences> Scan to button>
check destination list> if available applications are not in the destination list then add them in the front panel destination
Tried to scan.
Good Luck
Posted on Oct 18, 2008
How to reset hp 6213 office jet
take all the cable
press an hold the power button for 60sec and power it on
or u can try a semi ful reset by pressing and holding the # and 6 button togehther disconect the power cable and connect the power cable and while the printer is turning on release the #and 6
Feb 23, 2010 | HP Officejet 6200 All-In-One InkJet...
You might have to do a system reset for your printer. To do this:
1) Unplug power cord.
2) Press hold button "6" and "#".
3) while holding buttons 6 and #, return the power cord, then release buttons.
You may now setup your faxing using the new number you have.
Hope this helps. Thanks for using Fixya.
Jan 13, 2010 | HP OfficeJet G85 All-In-One InkJet Printer
Hp printer 6313 all in have problem for fax. error number 351
The machine has a ECM (Error Correction)error.
Could be:
  1. The remote machine has failed to respond.
  2. The remote user has oressed the Stop button.
  3. Incompatability between two machines may cause the remote machine to abandon the call.
Try turning off ECM in the Fax Settings Menu.
Nov 24, 2009 | HP FAX 1250 Fax Machine (Black)
Manual fax answering won't work
For receiving a fax, its not necessary that you should have a dedicated fax line. But in case you are using a voice mail over the same phone line in which you receive faxes, it may interrupt it.  So its recommended to use a Distinctive Ring Pattern, which will be provided by your phone vendor. However before trying it try to  do   a power drain in printer. To do a power drain, you need to dixconnect the printer for power connection, leave it for few minutes than replug it. Else  try a reset on the printer, try to unplug the power cable, press and hold # and 6 on the pritner while power cable is unplugged , and than while holding the # and 6 button replug the power cable back to unit. It will reset the printer to factory defaults. This should work....
Jan 22, 2009 | HP Officejet Pro L7680 All-In-One Printer
HP 7310xi all-in one office copier carrage jam how ever nothing i
Hi ffitz,
 unplug the power cord, open the access printer door move the carriage manually and press and hold the ON button for 1 min and release the button and plug the power cord, it should resolve the issue.
Regards,  raj_p5983
Jan 19, 2009 | HP OfficeJet 7310 All-In-One InkJet...
Cartridge jam won't clear HP 5610v
I had the same problem and just got it to work. go to
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00577763&lc=en&dlc=en&cc=us&lang=en&rule=22243&product=441125
go to the section "Moving the carriage" turn on printer and then unplug power. If you still cant move the carrage then remove both toner cartridge and all the trays. Then completely disconnect printer and stand it upright (so paper feed and cartridge tray is on top) Look thru the paper feed area to the left side of toner carrage and you will see a little plastic tab around the bottom back of the carrage. That tab is suppose to be inside a track on the bottom of the carrage. I think that when we put in or took out toner we must have pushed it to hard and that piece jumped out of the track and has "locked" the carrage. I just pushed the carrage up carefully and used a letter opener to move the plastic tab back into place (tab is spring loaded) print working fine now. Hope this solves your problem
Jan 03, 2009 | HP Officejet 5610 All-In-One InkJet...
Hp oficejet 5610
This might be a bit unusual but did you connect the USB cable? You should have 2 wires connected to your computer.
Jul 24, 2008 | HP Officejet 5610 Color All-in-One Printer
HP Officejet 5610 Fax Failure
You can try resetting the printer.
Step 1. Unplug the power cord at the back of the printer while the printer is still on
Step 2. Press and hold the # and 6 button on the printer while the power cord is disconnected. And keep holdig the two buttons until you plug in the power back again.
Note : do not release the # and 6 when you plug the power cord back in. keep holding the two buttons until the printer would turn on then turn off or the printer would say anything about "reset"
Step 3. Try sending a fax after the successful reset of the printer
Jun 21, 2008 | HP Officejet 5610 All-In-One InkJet...
Hp 2115
issue with carrage , try cleaning ink carrage .
first
*unplug the power cable and press and hold power button for 1 min
*press and hold # and 6 , while holding # and 6 plug the power cable back in
*release the button after 10 sec
*wait for some time
*open carrage access door
*cleane printer carrage see for any dust in carrage
*pull the carrage to left
*turn off printer and turn it on
then try pressing OK and cancel at the same time
check for test page
Feb 17, 2008 | HP OfficeJet 6110 All-In-One InkJet...
HP Officejet 6310 All-In-One InkJet Printer Logo
102 people viewed this question
Seeker5211
Seeker5211
