Question about Dell Optiplex 755 Desktop Desktop Computer
Dell loud fan noise
When i power the pc has steady green light but a very loud fan noise and nothing shows on the screen
  • sandeep_c007
    sandeep_c007 Jan 26, 2012
    hey dude its due to virus!! click ctrl+alt+delete ul get TASK-MANAGER. select new task. RUN window pops up. type explorer.exe n u shd get ur screen. install an antivirus scan ur PC.
  • leo_mart Jan 26, 2012
    First of all thanks for responding. Second of all I am unable to see anything on my screen upon turning on the PC. Last but not least I am unable to get to task manager without seeing nothing on the monitor. Plus the monitor works since I've plugged it into another PC. The in front of the chasis is very loud and again lights in the front of power button steady green no blinking amber just steady green but nothing on screen.
  • 669 Answers
Is the computer completing post? This is indicated normally by a single beep after the power button is turned on. On most computers the beep is proceeded by a post screen with the manufactures logo. If the computer is not getting this far, unplug everything but the memory and video. This should cause the computer to give a no hard drive or OS error. If not pull all the memory, this should cause the computer to give a series of beeps (because there is no memory installed). If this does not work either, you could have a bad mother board or power supply.
Hope this helps
Posted on Jan 26, 2012
  • 85 Answers
SOURCE: dell dimension 5100, power button has turned orange
If under warranty contact Dell? I had this same problem, a new motherboard and fan assembly fixed this problem. Bad capacitors on the motherbard.
Posted on Apr 12, 2008
Rasmick
  • 13 Answers
SOURCE: Dell Dimension 8400 PC won't boot
http://www.computerhope.com/beep.htm
Here's a list of Boot Codes .....start with one stick of Ram
Posted on May 28, 2008
pagebor
  • 2785 Answers
SOURCE: Dell Dimension 8300 flashing amber power light and dead pc
it seems *********** board is having problem plz send it for servicing
Posted on Aug 08, 2008
dragon_rag27
  • 89 Answers
SOURCE: Dell XPS fan come on but nothing else powers up.
most likly a hardware issue i would recomend taking it into a shop what is your computer experience?
Posted on Jan 08, 2009
rahulgaikwad
  • 137 Answers
SOURCE: My Dell Dimension 4600 will not turn on. Steady Amber Light
Disconnect the Power cable / A/c adapter/Battery from computer.
Disconnect External peripherials.
Hold down the power button on the computer for 10 seconds.
Reconnect the power cable or A/c adapter and battery or the computer
Try to turn on the computer
check for Led's on the computer
If still no display ,shut down the computer,disconnect power cable.
Open the computer tower,remove memory modules,reconnect power cable and turn on the computer.If you get a beeping sound after turning on you should be getting beeping sound suggesting the mother board is not bad.Turn on the computer and disconnect power cable from computer.
Reseat 1 memory at a time if you have 2 memory module or if single memory module reseat in different memory slot,swap memory module.
Reconnect the power cable and turn on the computer if it boots to desktop possible issue with 1 of the memory module.
Disconnect the harddrive ide cable from the harddrive .Turn on the computer.
If still unable to power on .Shutdown the computer and disconnect power cable.Remove video card,sound card ,modem card if any .Connect just the vga cable from monitor to the integrated video port.
Connect power cable and turn on the computer.
If computer turns on possible issue with one of PCI or PCI express card.
If still unable to power on.Disconnect the power connector pin from the motherboard and reconnect it back.Turn on the computer check power power led on motherboard,also check if the processor fan is spinning. if no go then issue with motherboard.
Posted on Sep 03, 2009
Testimonial: "Very detailed advice, thanks! I believe my motherboard is bad, after testing with your suggestions. "
Dell opitiplex 280 is not giving display. first of all his fan speed to much high and then after 4 or 5 day its display disappeared. its just picking now power and fan also start with high noise and...
OK, I use GX280s as home servers and ran into a similar problem with one of them...
The problem may be serious and not worth fixing (motherboard).
Turn power on
Fan(s) come on full power, sounds like a jet engine, or eventually gets that loud.
See if you power light has gone amber.
You get nothing on the screen, no Dell splash screen/post, nothing.
This is what I posted a while back concerning the above. Obviously I cannot bee 100% certain as I do not have your box in front of me. This a known issue.
See if the power light goes amber after power up. I had (have - still siting in my basement) one that did same. Power up, fans go full blast . Power light goes and stays amber. This is USUALLY caused by bad capacitors on the mother board. Known GX280 problem going back. If you look on the motherboard, the capacitors should have flat tops and not leaking. If the are rounded or leaking, the MB has probably gone bad. Bottom line this is usually a defective motherboard. Mine was a bad caps issue, you issue could be different, but it does sound like the motherboard.
You can google "gx280 solid amber light loud fan" and see the issues. Here is one link.
http://community.spiceworks.com/topic/111476-gx280-solid-amber-light-and-loud-fan
I just replaced one of my old 280s with a dual core Dell Precision 390 workstation for about $118, and that included shipping, off of ebay.
Sep 25, 2011 | Dell OptiPlex GX280 PC Desktop
Dell 8400 dead
Can you tell if your hard drive is running? You can here it or feel it spinning. Are the fans running? If no, I'm 99% sure you need to replace your power supply and/or motherboard. This kind of thing usually happens after a power surge.
Sep 24, 2007 | Computers & Internet
My Dell Optiplex 620 started rebooting itself every time Windows started up and then it just went dead. I push the 'ON' button on the front of the computer and nothing happens. I have no lights, no fan,...
I would suspect that the power supply has gone bad and has to be replaced. A simple task, really. var fctb_tool=null; function FCTB_Init_b10486e133b24d6ca38e4d39d69b43a1(t) { fctb_tool=t; start(fctb_tool); } var fctb_tool=null; function FCTB_Init_ee2e8b71ff554752b93d52dd01ec84ba(t) { fctb_tool=t; start(fctb_tool); }
Feb 03, 2011 | Dell OptiPlex GX620 PC Desktop
Nothing comes on picture blank
Ok
A few things to try
1.) Check the laptop on an external monitor, do you get a picture
2.) Is there power to the laptop from the battery and the charger? Try to see if the charger indicator lamp is blinking green rather than steady green
3.) Can you hear hard drive / fan noises and are there any lights on the laptop?
If the charger is blinking, indicates that power is not making the circuit, check tightness of charging port, if tight, assume fault on motherboard / blown main fuse
If picture on external monitor and not on laptop, assume backlight on screen dead or possibly the inverter
If no noises from HDD or Fan and No lights on laptop, then fault with motherboard
If you do get fan noises etc, but get BLINKING lights on laptop, assume possible fault with graphics chip, repost with details of blinking lights / colour and specific model of laptop
Jan 12, 2011 | Samsung Computers & Internet
Have a dell dimension 4700 with orange steady light?
Turn the machine off and unplug the AC power then hold the power button in for about 30 seconds to drain any residual power. Plug it back in and turn it on, when you see the Blue DELL word press CRL+ALT+D and this should run a diagnostic on the hard drive. If it runs ok you will get a pass or fail on the hard drive. If you cannot get the diags to run you might have a bad power supply or motherboad/processor. I would find a known good power supply and try it before the motherboard.
Mar 09, 2010 | Dell Dimension 4700 PC Desktop
Optiplex gx 260 steady amber light - done all things on dell website - still doesnt turn on. got a new PSU and it still has the same problem. theres a whirring sound which is the fan and the power supply...
Steady Amber Power LED generally indicative of a failed MB. Remove all Memory, Expansion Cards, peripheral items, if still same, replace the motherboard. If you get a Green LED with jusr RAM in system, then an expansion card or peripheral might be the issue. 95% sure it is mothebroard
Sep 15, 2009 | Dell OptiPlex GX260 PC Desktop
Dell dimension 5100, power button has turned orange
Apr 12, 2008 | Dell Dimension 5100 (D51L1) PC Desktop
Dell 2300MO NOT STARTING UP Problem
Try the remote control.  You may have a problem with the contact switch in the power button.
Oct 02, 2007 | Dell 2300MP Multimedia Projector
Dell Optiplex 755 Desktop Desktop Computer  Logo
832 people viewed this question
Alun Cox
