Question about Sharp XR-1S Multimedia Projector
When the projector starts all I get is a white screen. The lamp light is a steady green which is good. There are no red lights indicating there may be an issue. The sound works for all of my inputs. Please help Thannks.
  • Ergon Dec 21, 2007
    After a few minutes this Sharp XR-1S flickers and shuts off. The Bulb is still at 93% life. What seems to be the problem? Please HELP!
    Eric
    amcsmq@yahoo.com
  • klp04 Jun 10, 2008
    I have the same issue. When the projector comes on all I get is a white screen, and the lamp light stays green. No red lights indicating an issue.
Are you sure you have the appropriate settings on your computer? This kind of problem has appeared for me if I don't have the settings correct. My multiple monitor solutions have always required troubleshooting on the computer end -- not the projector.
Posted on May 18, 2008
The indicator of temperature is red, the indicator of the bulb is off and the fan after 3 o 5 minutes
PowerLite 7800p Multimedia Projector - Epson
www.epson.com/cgi-bin/Store/support/supDetail.jsp?...oid...
EpsonPowerLite 7800p Multimedia Projector. Support ... Indicator Light, Status, Description... Temperature, Red, The projector is overheating, which turns the lamp off ...
PowerLite 735c Multimedia Projector - Epson
EpsonPowerLite 735c Multimedia Projector ... Indicator Light, Status, Description ...Lamp/Temperature, Red, The projector is overheating, which turns the lamp off ...
Maintenance Indicators - ManualsLib
www.manualslib.com > ... > Notevision PG-F212X > Operation manual
The warning lights (power indicator, lamp indicator and temperature warning... ... Redon. Normal (Standby). Green on. Normal (Power on). Red blinks. Abnormal ... Sharpmultimedia projector model xg-mb67x-l operation manual (71 pages).
Dec 14, 2015 | Office Equipment & Supplies
Epson EMP 500 turning off
I believe that's an overheat problem. Check the fan if it's cooling properly. Make sure the unit is in a cool temp room.
Nov 01, 2008 | Office Equipment & Supplies
I have sanyo projector model PDG-DSU20E. Few white spots appeared on the right side of the screen. Gradually the spots has filled the right side about 1 feet is width till bottom of the screen. Now few...
1,white spots appeared on screen,means the DMD is broken,you need a new DMD.
2,the projector running off after only a few minutes,means the Inductor (Sensing element),near the Color Wheel. Use a cotton swab moistened with alcohol to wipe the Inductor.
Have a good day!
We supply original projector parts: lamp, bulb, Lcd, Lens, DMD,
motherboard, powersupply ... with high quality and competitive price.
Jerry China
Tel: +86 131788 67858
E-mail: lampdeng@hotmail.com
Skype: lampdeng.com
YM: lampdeng@yahoo.com
http://facebook.com/lampdeng
http://www.lampdeng.com
Sep 11, 2013 | Optoma PRO250X Projector
After a few seconds the lamp light began to blink red, its a panasonic pt-lb10svu, show no pic at all has a new lamp
Hi, Replacing the lamp in a Sharp LCD projector requires the lamp indicator to be reset. When the lamp needs to be replaced, the indicator becomes red. Resetting the counter for the lamp hours to zero will also reset the indicator to green.
  • Attach the power cord to the projector and plug it into an electrical outlet.
  • Step 2Locate the buttons on the top of the projector and simultaneously hold down the "Enter", "Menu" and "down arrow" buttons, then press the "Standby/On" button.
  • Step 3Continue holding all four buttons depressed until the lamp indicator light begins flashing green.The counter is now reset. Zero hours will now be displayed on the screen.
  • Aug 03, 2010 | Panasonic PT-LB10SVU Multimedia Projector
    No picture
    ballast is not striking the lamp and needs replacing
    Jan 10, 2009 | Sharp XR-10X Multimedia Projector
    TLP-B2 projector lamp problem
    my suggestion that unit is faulty and i recommend that you bring to the service center for repair that unit.
    Jan 28, 2008 | Epson LCD PROJECTOR, XGA, 3500 ANSI, 1024...
    No light come on from the projector
    Thats the projector telling you that you need to replace the lamp. Lamps usually lasts for about 2000 hours so if you had it for a while you may need to replace it.
    www.froogle.com and enter your make and model or go to www.projectorcentral.com and find a few retailers in the US that sells lamps.
    good luck
    smeags
    Jan 02, 2008 | Hitachi CP-X260 LCD Projector
    Projector lamp flashes and the temp red led lights.
    Purchased our76C in Jan, 2007. It is our second unit now that has had the same symptoms. When the unit starts up, the Power light is steady green as normal for a few minutes, but no image is projected. After a few minutes the lights do as you described. Both times Epson support authorized a new unit to be shipped out immediately. They said they had no known issues about it and didn't indicate what was causing the problem. Apparently it is not just the lamp wither. Also, the lamps both had under 20 hours on them.
    Jun 17, 2007 | Epson PowerLite 7500 Multimedia Projector
    Sharp XR-1S Multimedia Projector Logo
    105 people viewed this question
    Top Sharp Office Equipment & Supplies Experts
    Anthony Karuku
    k24674
    jasbo
    jasbo
    Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
