Question about Minn Kota Riptide Sp Saltwater 70 Bow Mount Trolling Motor With Autopilot
Prop will not engage just beeps
Full battery charge, moves left to right but when trying to engage trust from prop just beeps
I had same problem- Just press the + sign on the remote to move off of zero setting.
Remote most times resets to zero when power shut off unit. I found in manual on remote & hi lighted for futrure reference- Easy to miss -or not do
Posted on Nov 30, 2008
  • 3 Answers
Is it 12 or 24 Volt system and check to see if there is a com switch that has to be turned on and there should be a click (switch) wich activates and allows the prop to turn. and are you using a foot pedal or a wireless remote?
Posted on Oct 21, 2008
Batteries go flat if left in camera
your title says camera ? but your post is in pride mobility ? but this will apply for any rechargeable batteries. the batteries could be at the end of there life ( they only charge so many times ) but cold and other things can drain them. heres a fix to try and get the full charge to stay full. you might have to do it a few times. charge batteries over night untill fully charged,prop the scooter up and jam the throttle on and just let it run flat ( anything else with full charge do the same.power on and let them run flat ) once there flat recharge again but drain the battery so it wont even light the lights.try it to see if the next charge holds ? if not try the same thing again. this is called calibrating..you might find after the first try it will hold half of its charge but will get better the more time you calibrate it. if that dose not work you will need new batteries. also try leaving them out of the item not in use to see if they drain on there own,this could give you a clue as to something being left on when there inside ? hope this helps
Apr 29, 2015 | Pride Mobility Products Hurricane PMV...
Hoveround won't move.
Double check to be sure drive levers are fully engaged. Go down and up a few times. If problem persists have Hoveround come and check it out. One of the drive motors may have shorted out when you continued driving with gravel in the wheel.
Mar 29, 2015 | Hoveround MPV5 Electric Wheelchair - Used...
Hi we have just bought a Disability scooter and when using the battery indicator is moving from right to left - full charge to low charge is this normal?
Yes that is normal. As you move, the meter shows the amount of voltage being drawn down. If it drops too low or doesn't recover to the full right side, its a clue that it needs charged or the batteries are too low and should be replaced.
Sep 18, 2014 | Health & Beauty
Mobility scooter
Check the freewheel lever is not engaged.
Jun 03, 2017 | Health & Beauty
Jazzy 614HD will not move. Lights flash from right to left, then cuts off. Unlock instructions are not effective. Chair is fully charged.
If chair has a tilt, recline or lift seat on it it may be going into lock-out mode on its own due to a limit switch fault. If you don't have any of these options then I suggest you remove the joystick, controller and any wire harness between the two and send them to a shop like mine for repair.
The usual lock out light chase is from left to right - not right to left so this is suspect of a different issue.
Dec 28, 2012 | Pride Jazzy 614 Hd JAZZY 614HD
Gogo elitescooter lights indicate battery fully charged but scooter will not go
Make sure the free-wheel lever is engaged and the charger is unplugged from the scooter before you try to turn the scooter on. If the battery gauge goes up when you turn the scooter on and there are no beeping sounds you should be good to go.If the battery gauge drops to the red when you try to accelerate slowly, your batteries are shot. (Typical replacement in 24-48 months).If there is any beeping when the key is first turned on then there is a problem and the number of beeps indicates the problem found by the computer during the POST. [Power On Self Test]
Dec 26, 2011 | Electric Mobility Mobility Electric Power...
Where it shows the charge of the battery it keeps running across the screen and you can't use the wheelchair. It won't move. It does this every time after taking it off the charge.
Spot does the lights scroll from left to right or right to left? If they move from right to left then shuts down completely then the chair is in lockout or sleep mode. To unlock - turn the chair on and immediately press the horn button twice ( beep beep) This should get it out of sleep mode. Now if the lights are scrolling left to right then the chair still thinks it is being charged and the inhibit function is bad. You can call your local provider to have a tech check it or you can call Repair Xpress at 1-877-581-3733 to check it they have atech in your area to check it. Hope this helps
Aug 29, 2010 | Invacare Supply Group Invacare Pronto M51...
Wont move beeps several times battery dial shows full
Check the "neutral" lever just above the right rear wheel. It is probably not engaged. If the Go-Go rolls freely, that is the simple fix. If that isn't it, look at your manual on page 33 for the beep codes to tell you what's wrong. If you don't have the manual, here is a link to the free download site...
http://www.pridemobility.com/pdf/Owners_Manuals/US_Scooter/US_Elite_Traveller_om.pdf
Sep 02, 2009 | Pride Go Go Elite 4 Wheel Traveller...
How to start Mercedes C180 1999? Is it button start or key start?
i have a c180 merc petrol when starting the starter dosnt engage prop for afew turns then it engages and engine starts i have change the ring gear plus change the starter and still geting the same prob
Jun 28, 2009 | 1999 Mercedes-Benz C-Class
Minn Kota Riptide Sp Saltwater 70 Bow Mount Trolling Motor With Autopilot Logo
573 people viewed this question
Top Minn Kota Boating Experts
Mike Marcotte
Mike Marcotte
Andrew Taylor
Andrew Taylor
Colin Stickland
Colin Stickland
Are you a Minn Kota Boating Expert? Answer questions, earn points and help others
