Question about Kitchen Ranges
Wolf oven self-clean error 01
Hi!  I have a Wolf duel fuel range, 48" with 2 electric ovens, 3 yrs old.  The ovens get relatively little use.  I have used the cleaning cycle twice in each over 2yrs.   The smaller oven initiates the clean cycle just fine, the larger oven (which I use less frequently) now gives me an Err01 when I set it to "clean".  Normal bake/roast still works.   Is there some way I can troubleshoot this myself, or is it a "service rep only" sort of deal?   Thanks fixya I learn a lot on your site!  nnnn
  • OregonAndy Oct 31, 2008
    We just started having the same problem - except our larger oven self cleans fine but we get the ERR01 on the small oven.
  • mca56 Nov 05, 2008
    Same exact problem. Mine is on the large oven. Smaller oven works ok.
Well, ours is working now. We called Wolf, they said the Error 01 indicated a problem with the latching mechanism (that locks the oven during self clean).
We called the local repair outfit (they've been here several times before working on this range), they ordered a latch mechanism and arrived today to install it. The tech this time had worked at an electronic company that I also worked for about 10 years ago (I'm an electrical engineer). So we had a good time talking about the old days and working on the range - I'm always curious about such things. We removed the latching mechanism - its an assembly with a motor and a couple of switches that are used to start and stop the motor. We tested the switches and motor using a meter and power cord. Seemed to be OK. The next thing would be the control board - which we had replaced about 3 years ago - under warranty. Before removing the control board we reinstalled the latch mechanism - and, of course, everything worked fine.
We were both a little dismayed about the quality of the assembly of the range - the wiring looks more like a rat's nest than the tidy routing that we'd like to see.
So, bottom line, neither of us knows what the problem was. Could have been a food particle lodged in the switching mechanism, an intermittent connection or ???.
One thing I noticed as we checked out both ovens: We put the small oven (the one that was having problems) in self clean for a couple of minutes - was OK. Then we turned it off and turned the larger oven to clean mode - when we did that, "OPP" appeared on the display. The tech said that was because the latch of the smaller oven was not in its stop position yet. We gave it a few more seconds then tried clean mode on the other oven and it was fine. I mention that because OPP appeared on the small oven once or twice when we (my wife and I) were initially trying to figure out what the problem was. There's probably a hint in there somewhere as to what the real problem was.
At any rate, its working again ($115 later) but I'm not real confident that it will continue. Next time, I'll open it up myself (not recommended). <g>.
Posted on Nov 07, 2008
  • soulpiration Dec 26, 2010
    u have to wait for one oven to cool and unlock b4 you can self-clean the other side. fyi. that's why u are getting error messages.
Thanks Soulpiration! I had the error and your recommendation was RIGHT ON. Only one side of the oven can have the knob in CLEAN mode. After the oven cooled down, I turned the knob to OFF and the other oven stopped displaying the error.
Posted on Jul 22, 2012
How to reset error codes
Dual Fuel Range Error Code 07 ' FAQ ' Sub-Zero and Wolf
www.subzero-wolf.com/.../dual-fuel-range-error-code-07
Sub?ZeroCore Issue: Dual Fuel Range error code 7; ERR 07 displays on Dual Fuel; Error 07 on control panel of Dual Fuel ... Convection Steam Oven Error Code E75.
L Series Built-In Oven Error Code COMM ERR ' FAQ ' Sub ...
www.subzero-wolf.com/.../l-series-built-in-oven-error-code-co...
Sub?ZeroCOMM ERR displayed on an L Series Built-In Oven indicates a communication error.Reset the unit's power at the circuit breaker. Turn the unit back on to see if ...
WWD30 Warming Drawer Error Code 40 - Sub-Zero and Wolf
www.subzero-wolf.com/.../wwd30-warming-drawer-error-cod...
Sub?ZeroError 40 on a Wolf Warming Drawer. Steps to Verify Issue: With error 40 on WWD30 warming drawer try the following before calling service: ... x. PF Error Code on Warming Drawer ... Whether you're shopping for appliances or have questions about those you already own, we've got the resources you need. ... Wolf Cooking.
Wolf DF304 beeping after turning off the oven - The Kitchen ...
appliantology.org > ... > The Kitchen Appliance Repair Forum
Dec 25, 2015 | Wolf Range Kitchen Ranges
Error code FO5...oven dead
Duel fuel? Which one does the self-cleaning? I'd bet electric. If so, the gas mode must not be used, and it may be telling you that.
Apr 10, 2015 | KitchenAid KDRP407HSS Dual Fuel (Electric...
Wolf gourmet gas range/oven 36"--oven lights and
is this a duel fuel unit if so the the electric bake element is open
Sep 19, 2011 | Wolf Range KFS-0-27-SCB-36 Gas Kitchen...
On the self cleaning option of the above, error f02 appears and the cleaning wont start. Its a pyrolitic self cleaner, apparently and about 2/3 yrs old
Hi, Before you go working too hard to get you oven to go intothe self clean mode(self destruct)....check out this tip...
Self Cleaning Oven Problem
heatman101
" Wish I had read this first. I never would have used the self cleaningoption. Thanks for the info!!
Jan 04, 2011 | Ovens
I have a Wolf DF484CG Dual fuel electric oven that doesn't heat. Ideas on problem? Where can I get assembly drawings to see how to get to the heating element? Thanks for your help. Howard Gandelot
I HAVE A WOLF DUEL FUEL RANGE/OVEN. THE OVEN STOPS HEATING AT-TIMES , THEN RESUMES WHEN-IT-WANTS-TO !!
IS THIS A TIMER/THERMOSTAT/SENSOR ISSUE ? THANKS, JEFF
Sep 29, 2009 | Wolf Range Kitchen Ranges
My jenn -air self clean over just beeps when i hit clean
Before you go working too hard to get you oven to go into the self clean (self destruct) mode....check out this tip...
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
" Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!! "
May 31, 2009 | Jenn-Air JDR8895AAS Dual Fuel (Electric...
Wolf Double Oven
I had the same problem with a Wolf L-Series double wall oven (Model DO30) and called for service (under extended warranty contract). The tech told me that the F1 error is a latch problem (you know the one that grabs and locks the door during self-clean cycles). He cleared the error using a series of "secret" button presses on the control panel and the problem cleared. Now, when it happens (which isn't very frequently), I do the same thing he did ... press "0" and "Temperature" for the oven causing the problem and hold them for about 5 seconds. The oven will ding and the display will show some diagnostics, including the error event. Press "Cook Time" and "Stop Time" while in this diagnostic mode to clear the error register, then press "Off". I've also tried to keep the area across the top of the oven opening clean (with a little degreaser), especially around the latch, and I've sprayed a bit of WD-40 into the latch periodically for lubrication and cleaning.
Mar 26, 2009 | Wolf Range WKGD-2 Gas Double Oven
Self clean oven doesn't work
hi there,
does the keypad beep when you push the keys? if yes, the keypad is fine.
make sure that the keypad is plugged into the control board correct it. the control board is located behind the keypad
do you get any error messages? if yes, please tell me the #.
Nov 17, 2008 | Ovens
Wolf Oven
Use DeBruce Polish for the stainless steel and smooth cook tops. We get DeBruce at debrucepolish.com
Aug 07, 2008 | Wolf Range 18 in. SPR-100 Gas Cooktop
Kitchen Ranges Logo
2,241 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
