Question about Kenmore Elite 45986 Front Load Washer
Kenmore elite washer
First the washer was saying that the load was done when I would try to start a knew load. So I unplugged it and now it won't turn on.
  • 63 Answers
Need more infor any numbers or codes will check back
Posted on Nov 14, 2008
Maytag Front load Washer. "SUDS"
Clean the drain pump basket. http://www.youtube.com/results?search_query=kenmore+elite+front+load+washer+drain+pump+cleaning&oq=Kenmore+Elite+Front+Load+Washer+drain+pump+clean&gs_l=youtube.1.0.33i21l2.425000.427123.0.432800.6.6.0.0.0.0.410.1517.2-5j0j1.6.0...0.0...1ac.1.lQhVllMwg9M
Jan 27, 2013 | Maytag MAH2400 High Efficiency Front Load...
Kenmore Elite HE4t Washer won't start
Hello Ameliafaith,
E-Z job...
If you take your model on line... to SEARS
(I don't ordinarily recommend)... BECAUSE THEY COULD ACTUALLY ... decode your ABREVIATED part number...
110. blah blah blah... (45986??)
The other sites actually have helpful VIDEOS...
But I already wasted enough time on this floundering with your
erroneous number (wrong no.)...
You will see these parts are reasonably priced and
very popular.. meaning they INDEED FAIL ... alot.
Go here:
Washer Door Lock Assembly Part Number 8181700 Sears PartsDirect
Carnac the Magnificent
Jun 07, 2017 | Kenmore Elite 45986 Front Load Washer
I have a Kenmore top load washer (110-22642100) that will fill, agitate through entire wash cycle, but that's it.
HI THERE, IT SOUNDS AS IF YOUR PUMP IS BLOCKED, NOT WORKING OR SOMETHING MORE SERIOUS. START BY CHECKING THE PUMPS IS NOT BLOCKED, LOOSE CHANGE NORMALLY CAUSES THIS AND IS RELATIVELY EASY TO FIX.
Finding the pump on the Kenmore Elite top load washer is a fairly easy project that can be done in about a half hour. The Kenmore Elite is part of the GE line of appliances and shares many of the same interior mechanical parts and systems. The Kenmore Elite is a very streamlined exterior cabinetry design, but the interior can be accessed by removing just a few screws in order for you to locate the water pump.
things you'll need:
  • Screwdriver
    • 1
      Unplug the electrical cord of the Kenmore Elite top load washer from the electrical outlet before attempting to locate the pump.
    • 2
      Remove the end caps on the control console of the dryer by pressing in on the caps with your thumbs and pulling the caps forward to unfasten them.
    • 3
      Unfasten the screws on the ends of the control console in the front with a screwdriver and tilt the console back so that it rests on the back hinges.
    • 4
      Unplug the top lid switch from the rear of the lid that sits underneath the control console, pulling the switch straight up off the metal prongs by hand.
    • 5
      Pry the metal clips that sit on the top lid up with a screwdriver, lifting the clips to unlatch the top and pull the top lid cover off the washer base, setting it aside.
    • 6
      Locate the water pump at the base of the washing machine on the top of the motor shaft.
    • 7
    • take the cover off the pump and remove any blockage or debris.
thanks and good luck
iain
Read more: How to Find the Pump on a Kenmore Elite Top Load Washer ' eHow.com http://www.ehow.com/how_6304872_pump-elite-top-load-washer.html#ixzz1LQ4bdiFZ
May 04, 2011 | Kenmore Washing Machines
I have an HE2 Elite Kenmore front load washer. I
Sounds like a control board issue. Not much else for you to do but wait
Eric
Nov 19, 2009 | Kenmore Washing Machines
My kenmore elite washing machine has all the lights on but will not pause or start or anything with or without the door closed. should I just unplug the washing machine and plug it back in like a computer?
couldn't hurt to try it! could be the safety interlock that latches the door. on mine, there's a certain 'grace' period that allows adding more clothing before the water reaches a certain level. then the latch locks! stays locked until the load is done. mine's a fridgidaire. so, different.
Oct 31, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite HE3 has power but not starting wash.
Select PAUSE/CANCEL twice to cancel the cycle. Select
DRAIN & SPIN if there is excessive water in the washer.
Re-select cycle and press START. If the problem remains, call
for service.
Dec 16, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite won't start
First of all, make sure haven't inadvertently locked your control panel. Press and hold the DRAIN/SPIN button for 3 seconds to see if it clears. How long did you unplug the washer for? The manufacturer recommends unplugging the washer for at least 30 minutes to reset the computer. Try this first and let me know what you have. It could be you only have a minor glitch.
If these preliminary checks prove unsuccessful, you may have a control panel problem. Do you have any error codes deisplayed? Please reply and let me know what you have.
Aug 25, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
Sal DeAngelo
fordexpert
Ed Mac
