Starlogic M17ANA not turning on
I'm so glad I use dual monitors sometimes. When I turned on my computer this morning my Starlogic monitor didn't power on. It has no light on for power at all. The AC adapter for it is showing a green light and I've tried it in multiple outlets. I've reseated my graphics card and tried my secondary monitor in both ports and that works just fine. I'm really hoping my monitor isn't dead. I'm not sure when else I can try. I've rebooted numerous times and the power light doesn't even flicker. I've checked the connection between the adapter and the monitor and its snug not loose at all. Unfortunately I do not have another device I can test with this adapter, but since it's own power light is active im assuming it's working properly. Any ideas guys?
  • Anonymous Apr 15, 2009
    It sounds like the LCD backlight inverter is out on your monitor. I am working on finding the part for mine right now and am not having any luck.
I have the same problem on my optiquest q7.help
Posted on Oct 19, 2008
Its likely that the diode that acts like fuse in the monitor has crapped out, If thats not the case then you may have a burnt out power supply.
Posted on May 09, 2009
My Starlogic M17ANA Monitor suddenly gave a screen that was 3/4 white with a lot of vertical thin colored lines. The part that is clear shows normal monitor image. I even took some pictures of it that I...
That is the failing LCD panel, nothing you can do.
See example of failed LCD panel in my guide and in my albums.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Dec 31, 2010 | Star Logic 17" LCD Monitor
My Starlogic monitor fails to power up. We had a recent power outage. Everything else on the computer seems to work properly however when I power up the pc the monitor will not turn on. Have manually...
Not sure if you have done this so give this a try.
* If possible, plug your Starlogic monitor into another working computer. If the Starlogic monitor works then it is the port on the original computer that has gone bad. The solution would be purchasing a new video card such as PCI or AGP video card. (Assuming all other aspects of your PC are working fine)
*However, if the monitor does not work then you know your monitor is dead. You will need to buy a new or used monitor. **You may want to barrow someone's monitor and test your original computer just to make sure the port on that original computer is fine.
Jun 16, 2010 | Star Logic 17" LCD Monitor
I own a StarLogic M17ANA Monitor...The screen is not working properly, displays "out of range". the monitor worked fine for nearly 2yrs., nothing has changed yet the monitor has stopped working. I was told...
hi there, the pro you talked to may be wrong in the first place as viruses tend to damage software programs(such as windows)
and not hardware(such as your monitor)
the problem maybe a different one, i am afrais you will ahve to see a tech about it...
good luck
Sep 06, 2009 | Star Logic 17" LCD Monitor
StarLogic M17ANA Monitor just flashes briefly and won't turn on.
Have you tried flexing the board. Maybe one of the line filter caps is open. probly don't have to worn you but when powered up you should have about 160 volts on these caps. Good for melting misplaced probes. This being a switching supply it will not power up unless it sees the correct voltage here. (128-340vdc depending on line voltage)
Aug 13, 2009 | Star Logic 17" LCD Monitor
Monitor turns on, but only flashes once and no screen appears
You have a monitor with a common problem. After a few years some LCD monitors will blow a power supply. The problem is caused by parts called capacitors overheating in the confined space of he monitor. If you are good at electronics repair/soldering you can usually fix he problem. Check out a few pictures on my web site www.ccl-la.com/badcaps.htm You can take the back cover off your monitor and look for the bad parts, replace any that look like the pictues and your monitor should work fine. The capacitors do need to be installed with the correct + and - connections, note the stripe on the old one and insert the new one the same way. If you don't want to try the repair yourself we offer a repair service for $35 plus shipping. I hope this helps, if so please rate my solution.
Buddy
Corporate Computer
Over 21 years of computer and printer support/repair
Jun 10, 2009 | Star Logic 17" LCD Monitor
Starlogic 17'' as dual display not clear
Check and see if your NVIDIA drivers are up to date. Then try changing the resolution on your laptop to match the native resolution on the monitor and see if it works. If it does then you will need to look for the option to set custom resolutions on each monitor so that you can have both devices working at diferent resolutions if 1 is wide screen and the other is not.
Let me know if this does not work and you need more help.
Apr 20, 2009 | Computers & Internet
How to covert Starlogic M17ANA into tv screen.
yes a dvi to VGA converter is available they are available online and over the counter at an electronics or computer store
Feb 05, 2009 | Star Logic 17" LCD Monitor
17'' monitor whte screen power light on
have a 17'' starlogic flatscreen monitor and i opened a game and it went to white screen and stayed there.
Jun 19, 2008 | Star Logic 17" LCD Monitor
Starlogic LCD Computer Monitor
I can't find a website for StarLogic anywhere, so either they have gone out of business (not likely as there should be some reference to them somewhere) or they are imported from a foreign manufacturer and rebranded with the StarLogic name.
May 13, 2008 | Star Logic 17" LCD Monitor
Problems with monitor
Are sure you plug into the right socket jack.
Try plugging different socket and listen.
Jan 19, 2008 | Star Logic 17" LCD Monitor
Computers & Internet Logo
1,316 people viewed this question
David Payne
David Payne
