Question about MPMan MP-FUB26 MP3 Player
Blacked out screen
I was adjusting the back light on my 512mb ki mpman and it went black from the top bit down. I can't see anything to re-set it. Help.
  • 513 Answers
Have you been messing with the actual backlight, or with the backlight settings through the player? In case you haven't messed it up, you might be able to reset it by resetting the firmware, use this link http://mpmaneurope.net/download.aspx?file_id=163 Good luck ;]
Posted on Jun 12, 2006
Why my seiki 32 in has 2 inch line going across top
on the remote look for a button called apex and push it 3 times while looking at the black part od the set.
Terry
Jan 16, 2015 | Seiki ki SE32HY10 31.5-Inch 720p 60Hz LED...
Toshiba TP50f50
unplug the set for a half hour and start over. As long as you did not save the settings, all should be ok.
Sep 14, 2007 | Toshiba 50H13 50" Rear Projection...
My Acer AL2216W monitor this morning went blank. I woke up, turned on pc and went to sleep like an hour more, when I woke up, the screen was black and light orange, as usual, when pc is not used for a...
Go to Control Panel, (top right View Small Icons). Then look for Power Options. On this page, you'll have the option to leave the monitor on. You should also check "Advanced Power Options". Don't be afraid of the word, "Advanced." It only means "customizeable"
If your mouse isn't waking your monitor, try the keyboard's space bar. I found it works better than the mouse at waking a sleeping computer
Apr 04, 2017 | Acer AL2216W LCD Monitor
The picture is oversized and the printing as in the stock ticker or in the sports scores can only be seen a little bit on the bottom. Can't find anyway to resize the picture.
Zenith sets, like most others now, are adjusted electronically through a service menu. You'll need your original remote control (or a Zenith-brand universal replacement with a MENU key) to access the menu. Press and hold the MENU button until the channel number and time display goes away, then press 9, 8 , 7, 6, ENTER. This puts you into service mode.
In service mode, CHANNEL UP and CHANNEL DOWN move through the different settings, and VOLUME UP and VOLUME DOWN change the values. Make sure you write down the original value of anything before you change it so you can put it back if necessary. One of the reasons the manufacturers hide the service menu is because the set can be damaged by incorrect settings to some of the parameters.
On some models, you can't get to all the parameters unless you change one called F MODE from 00 to 01. You might need to do this on yours.
The list of parameters varies by model and features. I haven't worked on a Zenith in a long time so I don't remember exactly what yours says, but you want to find two settings for V SIZE (vertical size) and V POS (vertical position). Adjust the size first by lowering the value until the top and bottom of the screen are black. Then adjust the position so the picture is centered (black strips close to equal size). Finally, increase the size until the picture fills the screen again. It's normal to adjust for a little overscan, meaning you push the top and bottom a little bit out of view. If you stop too soon, on some channels you might see flashing lines at the top of the picture.
When you're finished adjusting, turn the TV off to exit service mode. If you needed to change the F MODE setting, put it back to 00 first. Your picture should be properly sized after all this.
Mar 19, 2011 | Zenith SY2772DT TV
I just downloaded a book and changed the screen from white to black. Then I dimmed the brightness all the way down and now I have a black screen. I cannot see the settings to adjust the brightness back...
It all depends on the generation of Kindle you have. On mine I swip down from the top of the screen an the lighting an settings come up. Maybe this will help. Mine is 5 generation. On my earlier one it was different.
Jul 22, 2017 | Amazon Kindle 2
Screen dim, black has green in it, contrast and brightness = shin
Since you have replaced the Color Wheel, it sounds like you have not adjusted the Index Delay in the service menu. First reset all of the picture settings you have adjusted back to original factory settings. Then on your Samsung TV Remote and with the TV OFF, Press Mute,Power,123. This will turn on the set and put you in the Service menu. Look for the top setting and select or scroll to the OPTION setting and select and look for INDEX DELAY and select that. Once you have the Index Delay selected use the right and left buttons on the remote to adjust for a picture the has no abnormal coloring and while looking at a program adjust for when the blacks look black with no abnormal coloring. Once that is done, turn off the set then turn the set back on. Now the picture should look normal.
Apr 03, 2010 | Samsung Televison & Video
I'm having a problem with my screen turning black as soon as I make a call or recieve a call it comes back on when I plug it in. I can't hangup from a call or anything when it does go black can someone...
The screen on the droid shuts off to conserve battery power. The amount of time that it remains on can be adjusted in the settings menu, under sound and display, screen timeout. The screen can be turned back on after a timeout by pressing the power button on top of the phone momentarily (quickly, dont hold down). Also, the screen will go black when you hold the phone up to your ear, and then light back up when you remove it from your ear. Hope this solves your problem, if not just let me know.
Jan 18, 2010 | Motorola Mobility Droid (2 GB) Cell Phone
Black screen
yes, its the light. Its called screen bulb. The bulb is burnt, that's why the screen cannot be lighted up.
The solution is to take it for repairs. There is not settings or adjustment required.
Best regards.
Jan 14, 2010 | Dell Inspiron 1525 Laptop
Black Screen
do a master reset press the menu button go down the left hit the middle buton then go down 5 select...then go up twice select the put in ur security code if u havent changed it it is 000000 hit the top right buttton twice and jus wait for a minute it should work and dont worry nothing wi be erased
Dec 19, 2008 | Motorola Mobility RAZR V3
Phillips plasma tv MDL 42PF9966 Black Line across screen
The ribbon cable to the drive has either came loose of the drive itself went bad. You can open up the back if you are confident and see if adjusting the cable gets the line back. If not you will need to replace the Upper Y Drive.
Thanks
Josh
Sep 27, 2008 | Zenith P42W34P 42 in. EDTV-Ready Plasma...
MPMan MP-FUB26 MP3 Player Logo
214 people viewed this question
Top MPMan Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a MPMan Audio Player and Recorder Expert? Answer questions, earn points and help others
