Question about Water Heaters
Siemens central heating control
I've lost the instructions for my Siemens central heating control. At the moment, I can't get heating only on timed, only heating+hot water. I can get hot water only. Help!
I have a Siemens "Radio" Room Stat - the receiver has switched itself off. How do I restart it. I have pressed the restart button and the reset - nothing happens except for red light flashing and then off. I do not have the instructions. Where might I get them?
Posted on May 01, 2009
My central heating turns off when i turn the hot water tap on. when i turn it off the central heating doesn't come back back on until i turn the power off and on.
Combi-boiler-turn hot water tap on/off and the heating stops for ...
Combi-boiler-turn hot water tap on/off and the heating stops for 20secs ... hot watertakes priority over central heating so when you run the hot tap, heating is ... Yeah onmy worcester combi there is a diverter valve - it feeds either the heating or ...
My central heating works but I have no hot water - 24'7 ...
Diverter valves switch heat between the hot water and the central heating. When youturn your hot tap on, the diverter valve temporarily shuts off the water supply ...
Does your boiler keep switching itself off? Here's why ...
Jul 7, 2015 - ... Bathroom Suites, - Showers, - Wet Rooms, - Taps and Accessories, Information and ... Low water pressure can cause your boiler to turn itself off. ... boiler is not turning off, you aren't getting the amount of hot water you require. ... If there is air in your central heating system, then your boiler may shut down.
Feb 09, 2016 | Water Water Heaters
When I have central heating on, why do I also get very hot water in taps even though water heating switched off?
This could be due to incorrect installation, incorrect wiring of controls, or an unintended consequence of combined central heating and hot water supply.
Nov 27, 2015 | Water Water Heaters
My hot water light wont go out,my central heating wont come on either but I do have hot water
I'll need to know what make--model--- age of this unit is and if it's electronically controlled to help you----your question is too vague do to the enormous variety types of heating systems----I'm going under the info provided that this is a boiler with domestic hot water coil----you say central heating so this throws me off---do you heat with hot water--hydronic-----or forced hot air----if hydronic---it sounds like your circulator in not functioning----a bunch of reasons circulator has failed---aquastat's "circulator control" has failed---thermostat has failed----broken wires----plugged lines----it goes on and on----this is the best I can do with this info sorry Happy Rabbit
Apr 02, 2015 | Water Water Heaters
How to use Central Heating only on an IDEAL W2000 CF50 boiler
you should have a programmer that will let you have the hot water and heating on or off . You could have a motor rised valve on the system which controls both . depends on what system you have . Fully pumped of just pumped on the heating side .
Jun 14, 2017 | Water Heaters
Can I put my central heating on a different time from my water horstmann didam 425
It appears there are 4 trippers on the daily time dial that control all timing. 2 On and 2 OFF
On the right side are override switches for Hot water and Heating
You can only separate Hot water and Heater programming a little bit.
You can choose to have Hot water ON all day, or turn on-off once per day or turn on-off twice a day. Or OFF all day.
The Heater has the same options and the same on-off times as the Hot water.
For fully separate programming, where Hot water and Heater can each be programmed differently, you would need a 2-channel controller like the Grasslin QE2
Oct 11, 2014 | Water Heaters
Hi, I've a fagor feb20e Eco plus combi boiler in
There is a flow sensor in the circuit and it is not sensing the lower flow from just the hot water. When you put it on heat though it does.
May 31, 2013 | Water Heaters
No central heating back boiler
back boiler run from a gas fire? check the instructions to operate the gas heat to the back boiler not just the fire
I presume that this a fully pumped system - air lock doubtful There maybe on/off valves on the pipes to and from the back boiler [situate close to cylinder] make sure they are on - anticlockwise turn
or there could be a blockage in the outlet from header tank usually in the loft. or If there is no water in it maybe the mains cold feed it is off.
Note if no water in it DO NOT USE the back boiler
May 03, 2009 | Bosch & Power Vent Water Heater
Hot water only for a brief time
From what I read on the documentation from siemens, I believe it is the valve as well. Here is the documents for it just in case you might need them. I would call a plumber or a heating specialist. Either one should know about this valve and be able to trouble shoot it for sure.
Mar 21, 2009 | Water Heaters
the boiler should modulate to controll the radiator temperature but the central heating will go off whilst you are drawing hot water
Nov 13, 2008 | Water Heaters
Water Heaters Logo
1,437 people viewed this question
Top Water Heaters Experts
Paul Carew
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
