Question about Samsung Yepp YP-T7JX MP3 Player
YP-T7 Working fine for a long time but started getting HOLD indications on screen - even though the switch was in normal position. Over time, it became increasingly difficult to use/turn on because it was always stuck in HOLD mode (even though switch was in normal position) HOLD Switch felt normal from the outside. I opened up the unit to test the switch with a DVM and it appears to be working normally. What I noticed with the unit disassembeled was that by slightly twisting the PCB, I could get it to toggle between hold and normal. Problem appears to be a bad solder joint or defect in PCB but difficult/impossible to fix without schematic. (If I knew the pin number of the MCU I could just hard wire the hold inpuit to the MCU to normal operation.)
  • Anonymous Jun 24, 2008
    well i think i have the smae problem when i connect my mp3 to charge on the screen it says usb connected but does not charge then when i take it off it turns off
  • Anonymous Jul 15, 2008
    My YP-T7 has been working great for years, until last weekend when it, too, began displaying HOLD when it was clearly not on hold. At times it flashes HOLD repeatedly, as if someone is quickly flipping the HOLD switch on and off. I can't choose any options in any menus, and can only shut it down (it registers a hold on the PLAY button in between HOLD screens).
    Have you found a fix to this?
    Thanks!
Thanks!
Posted on Jul 15, 2008
  • 175 Answers
Cant really help you with that one , but try check on the net.
Posted on Jun 25, 2006
Samsung YP-U2J Mp3 Player is Locked. How can i Unlock it? When i press On button, Locked screen appears.
My samsung YP-U2 has HOld on it when i turn it on,when it lights up theres a lock piture showing ,can enyone help me with this,please,cant get to play my songs,
Feb 10, 2011 | Samsung YP-U2 MP3 Player
My YP-T10 sliding power switch feels looser. Sometimes when I turn it on the touchscreen buttons won't work as if it were on hold, and when it does work sometimes it turns of randomly if I don't put it on...
Hi, not a solution but that is exactly what is happening to my T10 as well. It just started working this way yesterday and I don't know how to fix it. When I want to change a song, I have to slide the power switch so that I'm nearly turning it off to change a song. As well as that, I can see the 'lock' symbol on my screen even when I don't put my T10 on hold. Someone please help?
Jan 31, 2011 | Samsung YP-T10 Digital Media Player
Resetting is not solving the problem
I am sorry to say that your best bet is to get a new one because the cost of repair is not worth it.
Jul 01, 2009 | Samsung YP-T7 MP3 Player
Parking Brake Alarm
inset the key and switch on to position 2
Scroll through the warning display untill you get the service indicator apears
Press and hold the reset button on the left of the dash apnel for about 4 mins
You will be asked if you want to reset
Press anh hold the reset button again until you hear an audible warning
It should now show the new interval to a service
Jun 13, 2008 | 2008 Mercedes-Benz Mercedes Benz C Class
My YP-Z5F was working fine until last week, only the On-Off button is working to control On and Off but other buttons won't respond. Even when I switch to hold mode, it doesn't show a lock icon on the...
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
May 30, 2008 | Samsung Audio Players & Recorders
Can't delete or copy files ?
yp-t7 is builded w protected switch,to prevent loss data,
u can switch that by click reset button when u is connecting on usb port
Apr 25, 2008 | Samsung YP-T7Z MP3 Player
My computer won't load samsung yp-u2jzw
I have the same problem with my player same model....
Mar 24, 2008 | Samsung YP-U2X Digital Media Player
DSC-T7 Locked up "USB Mode Normal" Second user with exact same problem!
I went to the technicall service.They fix it. They told me i had water inside (humidity) they have clean the chips, formated again (they said)
90 minutes of hand work= 72 euros.
You may try to open it and with a hair dryer?¿?¿?¿
Now is working properly, but I have 70 euros lessin my pocket..
Good luck
Jul 29, 2007 | Sony DSC-T7 Digital Camera
I am a user with the exact same problem as you desribed for my DSC-T7. My problem started when I splashed two drops of water need the battery door and then the camera would not power up. I removed battery and card for a day and camera worked fine for another day. The following day, I left my camera in my sun visor of my car for the day (>90 deg F outside) which I forgot that I put it there. The next day my camera did power up in the locked mode exactly as yours. I do not know if it was the water drops or the heat but it is doing exactly as you desribe. However, here is something that I have discovered while trying to get the camera to work: 1. I plugged the adapter into the side of the camera since I am concerned that the USB port is the issue. 2. I plugged the USB cable into my portable printer and powerer the printer up and then turned on the camera in all three modes to see if anything changed and it did not. 3. I have found if you turn off the printer with the USB cable still in the printer and the adapter, the camera then enters a mode that shows thw word "ACCESS" and then the camera works perfectly. All modes of the camera work fine. But as soon as you power up the printer or remove any of the cables or remove the adapter the camera reenters the locked mode. This is not a solution but an indicator that the USB port is possibly causing the problem but not sure why the printer being off causes the camera to work fine. In addition, have all of the cables hooked up and to the printer does not allow the camera to be used with any mobility but wanted to let you know what I have discovered and hopefully maybe this may lead to a potential solution. Steve
Mar 05, 2007 | Sony DSC-T7 Digital Camera
Samsung Yepp YP-T7JX MP3 Player Logo
136 people viewed this question
Top Samsung Audio Players & Recorders Experts
Electric Dime
Electric Dime
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
