Question about Kenmore 24032\24036 Top Load Washer
Washer has spin problem
I have a Sears Kenmore elite washer modle 11024952300 the first sign of problems was it would sometimes not spin, this I could correct by reaching into the tub and turn a little by hand then close the lid. then it would not spin out so we could run through 2 spin cycles and get the water out of the cloths. Now it woun't get up to high speed it runs at a low spin to middle speed, will not get up to high. this causes the water to remain in the cloths any ideas. I had an appliance business and worked on washers in the 80's and 90's, I'm not a novis, but I'm not up on the new stuff with direct drive and all the circuit board controls.
  • 242 Answers
Sounds like there is a problem with the clutch , they go out often on whirlpool washers and are not too much money. its located right above the trans. and you must pull everything out of the bottom.
Posted on Dec 30, 2008
Kenmore Elite front load washer (model: 110 42936200) won't spin. It makes a buzzing/humming sound when it should be spinning. Any suggestions?
F2 mean that you have a drainage problem and could be that the pump is clogged. I believe the pump can be accessed from the front of the washer. Also make sure electrical connections are secure. Make sure no hoses are clogged or kinked anywhere.
Jan 23, 2014 | Sears Kenmore Elite 4.5 cu. ft....
My kenmore elite washing machine ( TOP LOAD) is not agitating or spinning". is it the belt or the clutch. Modle # 11024952300
there's no belt in the kenmore washers,they have a motor coupling.take out the two screws that hold the top console down.flip up the console it's on hindges,next with a screw driver pop the two metal clips and unplug the lid switch harness that's in between the metal clips,then open the lid and grab the frame,pull the frame to you and up and remove the whole frame.on the bottom you'll see the pump,with a screw driver pop the two metal clips and slide off the pump.take out the two screws and pop the metal clips and slide off the motor.on the back of the motor you'll find the coupling broke,it sounds like alot of work but it takes around 20 minutes to do
Aug 30, 2010 | Kenmore 24032\24036 Top Load Washer
I HAVE A KENMORE WASHER MODLE#110.22642100, AND THE CLIP TO THE TOP THAT MAKES THE WASHER SPIN BROKE OFF. I NEED A NEW ONE .
See the Sears Parts site for your washer:
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=110.22642100
Opening the appropriate diagram will show you a list of all component parts, Sears (alternative Whirlpool ) part numbers and the Sears Cost.
Jan 30, 2010 | Kenmore 24032\24036 Top Load Washer
My kenmore elite oasis runs fine but wont go through spin cycle
Try replacing the motor coupler between the motor and pump three small pieces about 18.00 dollars at sears parts store.
Jan 13, 2009 | Kenmore 23822 Top Load Washer
Kenmore top load washer spin problem
its possible you have a bad clutch assy, or perahps something stuck between the outer and ineer tub(i.e. sock) preventing free spin of unit, the clutch is mounted on top of the transmission assy and requires a little bit of work to acess, im sure you can find a video on you tube as to how to acess that
Oct 18, 2008 | Washing Machines
Washing machine
I was told by 3 technicians that my washer had shot bearings and this is a common problem for the Kenmore Elite Front loader.
Sears knows it and it costs $800 to replace the unit with the bearings. They will not do anything about it except try to sell you a new washer.
I will not buy this washer again (especially from Sears).
Jan 14, 2008 | Kenmore Elite 45986 Front Load Washer
Clanking noise during spin cycle
Sears knows it and will not do anything about it except try to sell you a new washer since it costs $800 to replace the unit with the bearings.
Jan 02, 2008 | Kenmore Elite 45986 Front Load Washer
Spin cycle problem
Which machine exactly do you have ?
Aug 31, 2007 | Kenmore Elite 45986 Front Load Washer
KENMORE ELITE MODLE 110 20082 992
We have the 11020092991, same washer. Ours has had all kinds of problems. We kept renewing our extended warranty and finally in August 2007, Sears concurred and called it a lemon and gave us credit for a new washer.
Mar 31, 2007 | Kenmore 20092
Kenmore 24032\24036 Top Load Washer Logo
137 people viewed this question
Sal De
fordexpert
Robert Rankin
