Question about Samsung PCL545R 54" Rear Projection Television
The picture went fuzzy (color alignment).
When I try and correct using perfect focus or do it manually I get a message showing no data available. Can you let me know what they problem may be? and the procedures to fix.
Thank you
Craighirman,
try going to the antenna input from the menu screen, then trying to do the auto focus, or manual focus. My Samsung won't let me do the auto focus unless I'm looking at the antenna for some strang reason.
Posted on Nov 02, 2008
I have arear projection Hitachi big screen that has an unlevel picture. Crooked a bit. How can I manually fix this?
Very common problems for DLP tvs,will get worst as times go by.Tv probally have a problems known as a convergence problems,it is dead.Tv have colors lines R,G,B unlevel on the pictures?Crooked pictures have mis colors alignments?Yes.There is no way manually to do an adjustment to fixed for this.Try push the tv remote button that said Magic Focus button.If the tv have data processing never completely done and have a error message and stop.Ur tv 100% have a dead tv convergence board,the tv convergence board must have it parts to be replaced like 2 STK convergence ICS and some or all of it resistors too.Than tv will be able to run the tv remote Magic Focus again to have a 100% data processing with no error message,tv to fixed this problems.The shop will cost u like $300-350 for parts and labors.
Jul 17, 2011 | Hitachi 61SWX10B 61" Rear Projection...
Our tv just started having a fuzzy image and the auto focus function aborts during the red color alignment. is there a manual alignment I can do to fix it.
What does this fuzzy image look like? Does it have ghosting shadows. Of course it is possible to align red manually from the convergence menu. But first lets confirm that it is indeed a convergence related problem.
Aug 18, 2010 | Samsung HCL552W 55" Rear Projection...
Picture is unclear color are off
there are a few things you might be able to do. First I would try the auto focus or alignment feature of the set. there should be a option in menu to realign the lamps.
May 24, 2010 | Sony KP-51HW40 51" Rear Projection...
Fuzzy picture
never adjust the tubes themselves( No-NO) these are affixed to the chasis in one position and not to be moved. no adjustments should ever be attempted to anything directly attached to the tubes. this will throw off centering, soft-focus, & convergence alignments. it can be corrected but a huge burr on the bottom of the foot! what you have are faulty convergence ic's and maybe sme low-ohm resistors that are bad. repair in-home should not exceed 350.00. parts and labor. mch
Mar 09, 2009 | Panasonic PT-53TW53 53" Rear Projection...
Screen Out of Focus with Wavy Lines - Perfect Focus Will Not Corr
This is a common problem. Its called a convergence failure.
Problem #1) Convergence
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Video may look distorted
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Halos around objects
  • Red/Orange looking video
You can see some examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Mar 06, 2009 | Samsung HCM4215W 42" Rear Projection...
Samsung self focus
BY FUZZY IF YOU MEAN STILL HAS COLORS OUT OF ALIGNMENT THEN THE STKS NEED TO BE REPLACED ALONG WITH ONE OR MORE RESISTORS.
Nov 14, 2008 | Samsung HLN5065W 50" Rear Projection...
Blue color problem
same here, fuzzy blue when trying perfect focus, all other colors are sharp. I have the 2 STK392-040 package
Feb 24, 2008 | Samsung HCN4226W 42" Rear Projection...
Samsung HC-P4752W No Color
Do not automatically think you need to go into the service menu. I bet you 100 to 1 that you pulled out a plug or a connector somewhere OR one is not seated into the plug all the way. If the set worked with color before you messed with it, there is not a problem in the service menu. The service menu is not the fix all thing. it is there to make fine alignments and adjustments, and as a matter of fact, messing with a service menu even with the service manual is very dangerous. I have seen peeps ruin TV sets by messing around with the service menu alignments. STAY out of these alignments. they are not going to fix a problem that all of a suddenly comes up. Repair the problem in the circuit first. Good Luck
Sep 18, 2007 | Samsung HC-P4752W 47" Rear Projection...
Convergence
Im trying to install that same board on the same tv how did you do it?
Apr 06, 2007 | Samsung HCL4715W 47" Rear Projection...
Wierd problem
HD projection televisions have seperate convergence alignment for 480i-1080i thus your problem when you use your XBOX360. The "No sensor data" that shows up is due to the fact that the sensors need to be initilized after doing the convergence in 1080i mode. You will probably need a technician to do the alignment because if it is out that much then a template needs to be used to get it corrected. For now you can put your XBOX in a lower display mode until repairs are done.
Jan 30, 2007 | Samsung HCN4226W 42" Rear Projection...
Samsung PCL545R 54" Rear Projection Television Logo
59 people viewed this question
Henry  Thomas
Henry Thomas
