Question about RCA P52926 52" Rear Projection Television
RCA P56926 - Picture Rolling- no problem when playing Playstation
The picture has a vertical roll on all channels. Does not happen when playing Play Station or viewing t.v. setup menus.
  • 3 Answers
I had this same problem with my big screen, it may be your connections.  make sure they are all tight and make sure your cable wire isnt defective.  you may also need a signal ampifier, like if you have to many tvs plugged into cable throughout your house.  in my experience, 4 is about all you can have without messing with signal strength
Posted on Oct 29, 2008
Besides the horrible animation of Bob's Burgers, why is my screen rolling like that on the lower half?
If this happens on one channel only call your cable or satellite provider.
If this is happening on all TV channels locate the vertical hold button on your TV and turn the button slowly until the picture stops rolling, if it increases turn it in the opposite direction.
Jan 07, 2013 | Televison & Video
My picture keeps rolling
Vertical sweep problem. Check vertical output section circuits to rectify this fault.
May 05, 2012 | Sony FD Trinitron WEGA KV-32FS120 32" TV
The picture on my TS-4573 rear projection tv has started to roll vertically at a fast rate. How can I make this stop. On old tv's there was a vertical hold adjustment on the back that you could play with...
this fault is caused by defective electrolytic capacitors in the vertical deflection circuits, they need to be changed out, do this before it causes more problems, there are no adjustments for this anymore.
Jan 30, 2010 | Televison & Video
Is there a simple fix for my projection rca P52929 ? It wont hold a channel and the picture rolls after about 15 minutes
is the reception clear? if yes only rolling picture. check the vertical section for leak capacitor or change value resistor.
Aug 11, 2009 | Televison & Video
Video tapes played through VCR experience vertical 'rolling'
unfortunatly no. the vert hold is set by black bars at the top/bottom of the video signal (outside of the viewable area). it sounds like your VCR or tape is damaged.
Dec 04, 2008 | Sony KDF-42WE655 Television
Vertical rolling on Hitachi 60SBX78B
It ended up being the Verizon Fios box. We recycled it and the picture stopped rolling. Thank you for being here to help. If I have any future questions, I'll definitely use your site.
Mar 07, 2008 | Hitachi 60SBX78B 60" Rear Projection...
When viewing images on TV the picture is vertically rolling.
Check the video setting in the set-up menu. It may be set to PAL if you are on the NTSC system, or vice versa. Also check the TV input to ensure your're on the correct channel.
Mar 02, 2008 | Canon PowerShot S2 IS Digital Camera
Vertical rolling
Does you set have PIP (picture in picture)? If it does then the PIP module has a bunch of capacitors that have gone bad (dried out and leaked) causing you to loose vertical sync. Vertical synchronization is what locks your picture keeping it from rolling. Even if you don't have PIP then still you have a vertical sync problem. The set would have to be checked by a tech to find exactly what's happening. Stargazer
Mar 04, 2007 | Mitsubishi WS-55807 TV
Toshiba Rear Projection TV 42WT29B
This is a problem with the low voltage condition in the main power supply or the sweep supply, or there is bad capacitors in the vertical driver circuit, or the PIP circuit if there is one. the best way to troubleshoot this would be with a schematic, measure all the voltages and see if there are any lower then normal levels. In the vertical and PIP circuits, you will need an ESR type capacitor meter. if you dont own this equipment, or have had no experience working on solid state electronics, play it safe and call in a tech to assist you in this repair. Good Luck Please dont forget to rate this thread.
Dec 11, 2006 | Toshiba 42H83 42" Rear Projection...
Akai DHT300 screen rolling
The picture is rolling because there is no sync signal in the composite output. Are you using the RCA jack or the S-video output? Is there another small TV you could hook up for a test to see if the problem appears there? If it does, then the Akai has the issue and needs to be examined further. If not, the TV input may have an issue. You didn't say what the TV is but there is the possibility the video input is looking for external sync from the DVD but that's a bit of a stretch. Can you feed a different source into the video input of the TV to see if you get the same result? Hope this helps.
Nov 01, 2006 | Akai DHT300 System
RCA P52926 52" Rear Projection Television Logo
56 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
