I have a slimy sandy substance coming through the water pipe to my washing machine causing diminished water flow and destrying the filter
    President:
  • Washing Mach... Master
  • 2,651 Answers
Thasts no issue with the washer, i would call in a plumber sounds like you got an issue there, im sure you know already but that aint normal at all
Posted on Oct 19, 2008
Kenmore washing machine 2 year old is now flooding my floor every 20 loads happiend 4 times. Please help.
Is the water flooding coming from the top of the washing machine?
Check the drain pipe in the back to see that it's not loose. Also, look inside the drain pipe and make sure there is no algae. Algae might cause low flow through the drain pipe and it will overflow.
Hope this helps.
Feb 07, 2014 | Washing Machines
What are the benefits of undergoing therapeutic massage therapy?
Benefits of massage:
  • Relieves muscle tension by enhancing blood flow, which causes muscles to relax
  • Decreases inflammation by activating genes that naturally reduce swelling
  • Reduces pain intensity by diminishing bodily substances that create and prolong pain
  • Improves recovery by stimulating mitochondria, the "energy packs" driving cellular function and repair
Nov 06, 2013 | Furniture
The hot water comes out but the cold water just trickles.
Hi from retired Englishman in SW France, Fri 13;29,
A quick suggestion/check- turn off the cold water feed then remove the cold water pipe from the back of the machine. Inside the piece fitted to the machine you are likely to find a filter. Make sure that is clean and not obstructing the flow. Check at the same time that the water IS coming out of the supply pipe at the right rate before putting it back of course!
If neither the supply nor the filter is the cause the cold water inlet valve in the machine could be at fault.
Hope this helps,
John C
Feb 18, 2011 | GE WBSR3140DW Top Load Washer
It wont drain the water away after a wash we
sounds like your pump may be gone, or could be pipe blocked. to check pipe fill machine take outlet pipe at rear of machine and lay this into a bowl. If water flows ok then all pipes are clear. As water is coming through just put machine onto spin cycle and raise hose to see if water will then pump out.
Feb 17, 2010 | Zanussi FS1255S Front Load Washer
We get a gritty / sandy residue. what can I do?
The cause may not be your dishwasher.
Especially hard water may leave the residue. If you don't have that problem when you hand-wash, then check your pipes. Homes more than 40 years old may have galvanized pipes that eventually rust on the inside. The grit could be grains of rust from the pipes. If you do have galvanized pipes (rather than copper) then you may need to replace them. You could put in a filter as a temporary work-around, but that will eventually clog with the gritty material.
Feb 16, 2010 | Bosch Dishwashers
Cold water flow seems blocked. It comes out very slow.
in the inlet pipe is filter ,remove the water inlet pipe and have a look should be thumb size filter that comes out for cleaning
Dec 27, 2009 | Whirlpool LSR5132PQ Top Load Washer
Hotpoint Aquarius WF740 My washing is coming out with dirty marks and bits of slimy dirt. I wonder if it is from the door seal as this is dirty or could it be something else? I used the persil gel filled...
Your pipe to the water pump exit is probably blocked with bits of old fluff or missing sock, i found that the clothes had slimy bits on mine, i tilted it up and removed the rubber water exit pipe from under neath, cleaned out all the rubbish and works a treat now.
Oct 19, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
I have an old Kenmore washing machine. Model#
It's coming from something deteriorating in your water heater,there were some heaters out there that had a thermostat housing that was breaking down and doing what you describe.check with the company that made it,they may still be doing repairs on them for free.
Sep 21, 2009 | Washing Machines
Washing comes out smelling horrible! Any ideas?
It is not the washer that is causing the prob, more likely to be coming from waste pipe, and or sink if the pipe is connected to the sink waste pipe.
Check and clean filter in washer if it has one, and remove waste pipe from washer and check outlet is not partially clogged up with sediment and other substances.
If pipe goes into sink waste, then pour a sink pipe cleaning fluid of some description down sink waste.
Also make sure you are not doing too many low temp wshes, as this can cause a prob as well
Do a boil wash at least once a month without clothes in but with powder in.
This is called a maintenance wash, and helps keep the inside of washer clean, and free from smells.
Please rate my solution.
Thanks.
May 16, 2009 | Hotpoint Ariston Aquarius WD420 Front Load...
Hi, I have a whole-house heavy duty water filtration unit from GE. When I go to replace the filter, it and the entire inside of the filter system is coated with a purplish slimy substance that stinks. I...
do you use liquid soap or fabric softner,if so change to small amount of powder.try filling the machine with really hot water and let it soak for an hour or so.hope this helps.
Mar 24, 2008 | Washing Machines
Washing Machines Logo
Top Washing Machines Experts
