Question about i-Bulldog IMP-90 MP3 Player
IVE TIRED FORMATTING, BUT IT WONT WORK!!!!!!!!!!!!!!!!!!!!!!!
I've tried, and it wont let me
  • 20 Answers
On the CD there is a program called MTSN firmware update You can format the player via that program
Posted on Sep 04, 2007
  • 513 Answers
First of all, when you have an on going issue, just comment again on the same thread. There's no need to open another one, and if anyone else besides the one that already answered you reads your post he wouldn't be able to tell what was already suggested or tried out. when you think of it, Ipods are the same, when you update your playlist, you have to include in all the old songs you want to keep as well. it's still working after all. Good luck
Posted on Jun 11, 2006
  • yoav kleinfeld
    yoav kleinfeld Jun 11, 2006
    I looked for a manual for your player, and couldn't find anywhere. If you still have it there should be an instruction on how to format it, or else I can't say good things about it. If you don't have a manual, search all sides of the player for a little hole you can insert a needle or a pencil tip through, and if you find one, press into it for a few seconds.
    If that didn't work well, try all sorts of key combinations, it might be that you have to press a certain button for a few seconds while the player is turning on, or volume up and stop at the same time, something like that. Play with it like that, you might get lucky.
SOURCE:
I have a Mercedes c280 1999. the truck wont open there is no battery in the trunk. I,ve tried jumping it from under the hood. the key sword won,t work on the truck lock. when I connect the power to th
HI IVE GOT A CLK HAD THE SAME PROBLEM THE TROUBLE IS YOU DONT USE THE KEY AND THE LOCK SEIZES UP I HAD TO GO IN THROUGHT THE FIRST AID KIT AND CATCH THE CABLE THAT OPERATES THE REAR SEATS THEN CLIMB INTO THE BOOT AND THERE IS TWO BOLTS AT THE LOCK UNDO THEM THEN TAKE THE LOCK OUT AND REPLACE IT OR PERCIVERE WITH PLENTY WD 40 AND TIME
Sep 25, 2014 | Mercedes-Benz C-Class Cars & Trucks
My presario cq57 wont boot to windows and there are no recovery discs, how can i reformat the hard drive?
the only way to format is using the CD,before formatting download the network drive from HP so the you can download other softwares after formatting
Jan 27, 2013 | Compaq Presario Cq57 Notebook Pc
My ipod touch wont turn on?
ive got the same problem so if u find out will u let me know how to fix it id greatly appreciate it thnx
Dec 30, 2011 | Apple iPod touch
This is my final cry: My mp3 sansa wont turn on, i made the mistake of dropping it a week ago and it wont turn on. Ive tried the reset the method(15-30secs) but it doesnt work...... at all. it wont turn...
You could try the Updater program and see if you can un-brick the chip. Go to the SanDisk site and download the Updater program, follow all instructions. That is the only thing that might work, as it may have broken an internal circuit.
Apr 04, 2010 | SanDisk Sansa Fuze MP3 Player
How do I remove the tire from a dodge journey? The lugnuts are off but the tire wont budge.
the wheel is just stuck, try kicking the tire by putting your back to the vehicle and flat foot kicking the tire.with the bottom of your shoe.
Oct 21, 2009 | 2009 Dodge Journey
Avalanche alarm goes off and key wont start
Try disconnecting the battery cable for a few minutes. This may clear the security code and allow the normal key to operate. The sensor in your tire may have gotten damaged when it was repaired (this is not uncommon). The solution, take it to a tire store, they can change the sensor if needed.
Jul 06, 2009 | 2005 Chevrolet Avalanche
Bluetooth
Back up first files on your memory card on your computer. then format the memory card on the pc. Then put back the formatted memory card and format it again on the phone. Take out your memory card then put it back again on your pc to copy your previous files. This should work.
Memory cards need also formatting same as HDD's
Hope this helps...
Jul 24, 2008 | Nokia 6131 Cellular Phone
Bad track error. songs arent deleting after reformatting and resetting multiple amounts of times.
There are 2 ways to format an mp3 player - if you were formatting the mp3 player from "My Computer," then try reformatting from Windows Media Player instead - I have a "tips and tricks" entry on How to Format an Mp3 Player for details
If that doesn't work, then double-click on My Computer, double-click on the Sansa player, and go to the various folders that it lists - music, voice, etc. Delete the songs ONLY - do not delete the dat, bat, ini, inf, or other system files
Jun 08, 2008 | SanDisk Sansa e250 MP3 Player
Power on/off problem
format ur phone by using code * + 3 + Call key + On/Off key till formatting appears, if this does not work u have to flash ur phone
Dec 14, 2007 | Nokia 7610
i-Bulldog IMP-90 MP3 Player Logo
29 people viewed this question
Top i-Bulldog Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you an i-Bulldog Audio Player and Recorder Expert? Answer questions, earn points and help others
