Question about Frigidaire 24 in. GLD2350RC Energy Star® Built-in Dishwasher
My dishwasher runs for bour 10 minutes. Then stops, and flashes PF?
MY DISHWASHER RUNS FOR ABOUT TEN MINUTES. THEN IT STARTS FLASHING PF POWER FAILURE.
  • ktaylor532 Jan 02, 2009
    If you don't know at what point the dishwasher started flashing PF, does this mean that it hasn't gotten through the full cycle and we should start over?
  • Anonymous Mar 16, 2014
    at times this PF appears, but no circuit breakers are tripped. this is one a fridgedaire dishwasher model number FDB4315LFCO
Mine does the same thing. I'm confident that the problem lies in the "computer" which is essentially the buttons for selecting the various wash cycles. That strip is basically a thick band with adhesive on the back by which it is glued to the top of the dishwasher door. There are wires connected to it. The wires run down into the door and connect to a terminal that is built into the door. The inside door panel must be removed to install a new button strip or "computer." Mine was replaced twice in the first year. Now it is three years old and needs to be replaced again. I'm going to look around on the net to see if I can find one.
Davey
Posted on Nov 04, 2008
  • yevad878 Nov 04, 2008
    PF posting had incorrect descripton. I said wrongly that the "computer" was on the top of the door. It's actually on the front of the door at the top. It has the buttons for start/cancel and favorite cycle.
    Davey
I currently own a BOSCH Dishwasher approx 2.5 years old. It just runs for 3 minutes then stops and starts again - red LED light by Tap icon flashing
Hi, that sounds like you have a fault in the water inlet valve. Best get checked or replace the water inlet valve.
Mar 27, 2016 | Bosch Dishwashers
Frigidaire dishwasher pf dims and stops
Hello Colton Rawlings, thank you for your post!
Based off what you are describing "PF" stands for power failure on a Frigidaire dishwasher. If the lights are dimming then your appliance flashes "PF" it could possibly be an issue within your panel or your appliance is not getting enough power to it. I would recommend contacting a professional to come and diagnose your appliance properly. I hope this is helpful. -Matt
Sep 06, 2014 | Frigidaire Dishwashers
FDB4315LFC2 runs then stops and flashes pf ?
Good Morning Friend,
I understand that your Frigidaire dishwasher, model# FDB4315LFC2, starts and then stops, and flashes a "PF" code when it stops. The "PF" code is stating that there has been a power failure. There could be a possibility that your dishwasher is losing power mid-cycle. I suggest checking your home's circuit breaker, the wiring to your dishwasher, and if you have a cut-off switch, checking that as well. I also suggest resetting your appliance, by shutting the power off at your home's circuit breaker, for 20-30 minutes. Restore power and start any cycle. If further troubleshooting is needed, I ask that you please let me know the error codes displayed on your appliance. Hope this is helpful.
-Best Regards-
WP
Jun 09, 2014 | Frigidaire 24 in. FDB1050REC Stainless...
The CLEAN light is flashing on my Kenmore QuietGuard3 , but it won't clean anything. It starts a cycle for a few minutes, stops and starts flashing clean again. Any suggestions?
You will have to reset the dishwasher. First try and turn off the mains power and back on after a short time. If the clean light flashing starts again then you go through the hard reset procedure.
press NORMAL WASH then HEATED DRY buttons one after the other until all the lights on the board lit up (3X's). The dishwasher will enter into a cycle; Press Cancel. This should stop the flashing.
If you are supplying dishwasher from hot water inlet then make sure the inlet water temperature stays within the recommended range of 145 deg F.
Apr 21, 2013 | Dishwashers
PF, high temp wash and air dry lights blinking. Reset main breaker but no help.
Hello babe_dog01 - PF typically appears in window when dishwasher is first installed, or when power has been interrupted. HI-TEMP WASH, SANITIZE and START/CANCEL backlighting will also flash. To clear, touch START/CANCEL pad or resetting the unit by unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes. Since you have already done so and it was ineffective contact a professional to move forward accurately. Dishwasher could possibly be experiencing a communication error, wiring failure or faulty control board.
Jan 05, 2013 | Frigidaire FGHD2433KF Builtin Dishwasher
Dishwasher runs for about ten minutes
There may be a heating problem,if the water doesn't heat, the cycle can't progress further.
May 30, 2010 | LG 24 in. LDF 7811 Stainless Steel...
My dishwasher starts and runs for 3 minutes then shuts off and flashes PF?
PF IS POWER FAILURE / LOOK AT CONNECTION IN HOOK UP BOX . SOUNDS LIKE THERE GETTING AN CAUSING AN OPEN . WHEN COOL THEY WORK ..MM MAY BE THE CONTROL BUT I DON'T THINK SO ..
Dec 06, 2009 | Frigidaire 24 in. FDB1050REC Stainless...
Kenmore Elite Dishwasher clean light ind flashing and won't start
You will have to reset the console. To do this, close the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
...all the lights will turn on briefly and the machine will start a diagnostic cycle. You can press cancel or let the diagnostic cyle finish (1-2 minutes).
You should now be able to run the dishwasher as normal.
Feb 17, 2009 | Kenmore 24 in. 15142 Built-in Dishwasher
Frigidaire 24 in. GLD2350RC Energy Star® Built-in Dishwasher Logo
551 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
