Question about Brother MFC-5840CN All-In-One InkJet Printer
Yellow color does not show
Everything works, the yellow does not work, I cleaned using the system cleaning, put new cartridge still yellow doesn't work
  • 1 more comment
  • hussko Oct 27, 2008
    I tried it, unfortunately it did solve the problem, so i am thinking to replace the head, any easy way to take out....I opened the printer, could not see any screws attached to the printing head, any special way. thanks
  • hussko Oct 31, 2008
    I appreciate your help, but I need to take the whole printing head out, I would like to know how to do that.
  • RaleTrail Dec 14, 2008
    Yellow is not working on my MFC printer. I am not using Brother cartridges. The Red looks pink. E-mail is
    An expert who has answered 20 or more questions within one hour.
  • 145 Answers
Put new original cartridge and off the printer. Turn on after 2-3 days. If printhead clogging,original inks can unclogg....
Posted on Oct 18, 2008
Cannon Pixma MG5520 printer
Remove all cartridges, clean the ink from where the cartridges make contact with cloth,(paper towels can leave trash in there) be sure all is clean then replace the cartridges and print something. Those streaks shouldn't be there any longer.
Sep 09, 2014 | Office Equipment & Supplies
Printer wont print the color brown
Try cleaning nozzle with dry paper towel, cartridge should leave 3 streaks: Yellow, Cyan, Magenta.
If colours on paper seams to be tinted or mixed the cartridge needs to be reclamated, there is no other solution.
If there is an lack of one or more colours try to wipe nozzle with wetted paper towel in window cleaner. After few wipes, 3 colours sholud apper
Oct 21, 2012 | HP 60 Tri-Color Ink Cartridge
The colors do not print correctly.everything is blue/green/yellow. the ink cartridges are new. black prints fine. the troubleshooting optin only lets me select to remove lines, it wont let me adjust the...
The magenta cartridge isn't working correctly. This is why you're only getting the other colors (blue is cyan, green is cyan and yellow, and then yellow).
Try removing and reseating the magenta cartridge. If that doesn't work, use a new magenta cartridge (the cartridge itself may have been defective).
I wasn't able to view a manual for this machine, as it's been discontinued and Lexmark no longer offers the PDF on it. If you have a "clean print heads" option, use it. It may require more than one try. If you don't have that option, then all possibilities have been covered.
Hope that's helpful.
Jan 01, 2011 | Lexmark X1150 All-In-One InkJet Printer
Magenta in tricolor not flowing
unplug printer cables, replug in
take cartridges out, put back in making sure sure nothing is obstructing the ink dispensary on the cartridges and that they're clean
look in the printer where the cartridges go, making sure nothing is blocking the ink
check the rollers to make sure no paper is caught inside the printer
turn on printer and try this
hope this works and good luck
Apr 30, 2010 | HP DeskJet 810c InkJet Printer
One of the 3 colors will not print
This problem may be due to blocked nozzles, faulty cartridges or a faulty print head or main board. The first thing to do is eliminate the cartridges. Do a proper cartridge change on both printers, but swap the yellow and cyan (blue) cartridges between printers rather than fit new ones. If either (or both) of the missing colours now appear, you know the problem is the cartridges; replace it (or them) with new ones.
For example, take printer A, with yellow missing. Do a cartridge change procedure on printer A, but instead of fitting a new yellow cartridge, put in the yellow cartridge from printer B (since you know this yellow cartridge works). If yellow now prints in printer A, you know the cartridge you took out is faulty - put a new yellow in printer B, and throw away the cartridge you removed from printer A. Repeat this process for printer B with the Cyan cartridge.
For one or both printers where the above does not solve the problem, then you can try soaking the print heads for 24 hours (or more), as follows. Turn the printer on, and as soon as the print head moves pull the power cord out of the back, or turn the printer off at the mains. You may now carefully move the print head by hand over to the left hand side out of the way. Look inside the print head parking area on the right and you will see a small rubber cup that comes up to cover the print nozzles when the head is parked (to stop it drying out). Use a syringe or dropper to fill this cup with head cleaning fluid or distilled water. DO NOT USE TAP WATER. Carefully push the print head across fully into its parking position on the right, so that the cup full of fluid comes up over the print head. Leave this for at least 24 hours, then try a head clean or two. If the missing colours now start to appear, try another clean or two. If still not perfect, leave for 24 hours and try again. If still nothing, report back.
Feb 08, 2009 | Epson Stylus C62 InkJet Printer
Shows catridge empty
If you want to use this non-
HP print cartridge, press
(Cancel Job) to continue printing.
Dec 16, 2008 | HP Color LaserJet 2550n printer + HP Color...
Despite installing new cartridges,cleaning and priming, my HP Deskjet 710C prints pink only. Using Windows XP test page shows no blue, or yellow.
do you installing both cartridges (black and colour)?
if you do so, my advice is to reinstall the driver for your printer.
if you install ONLY the black cartridge, and the color cartridge remain the old one, (which in my opinion is the present case), your problem is from the color cartridge.
The color cartridge have 3 colors and this are: cyan (some kind of blue), yellow and magenta (similar with a pink color, but more intense). The problem is simple: in your color cartridge has left only the magenta color, cyan and yellow tanks are empty.
have 2 options:
1. buy a new color cartridge
2. refill the color cartridge.
Sep 23, 2008 | HP Office Equipment & Supplies
Poor color
try to put your cartridges with warm water
Sep 13, 2008 | Canon PIXMA iP1500 InkJet Photo Printer
Printing wrong colors
Put in original inks and do a few cleans, if that doesn't work replace the head.
Jul 29, 2006 | Canon BubbleJet i550 InkJet Printer
Brother MFC-5840CN All-In-One InkJet Printer Logo
83 people viewed this question
James Cagle
James Cagle
Jim Keysor
