Question about Whirlpool LSR5132PQ Top Load Washer
Whirring clik In spin cycle, loud whirring, clicking noise (like a stripped gear) and no spin. Cannot figure out how to even get the back off to take a look. Whirlpool model S49 LSR 8233EQ 1(L) cheers, Boom
  • Anonymous Mar 16, 2014
    I have a Whirlpool type 111 LSR 8010 PQ0 that the spin cylce doesn't work any more.
    President:
  • Whirlpool Master
  • 2,651 Answers
Sounds as if you have a bad motor coupling( this machines equivilent to a belt), i would try to search through you tube for a video as how to replace , easier to watch someone then try to explain it, its def there ive seen it and its not a real bad repair, parts probably $25, a servicer will get 150 to 200 to do it
Posted on Oct 19, 2008
Loud constant noise (metal on metal clicking / whirring / grinding) during spin cycle
renault laguna 2006 diesel. unlock code for radio... modell renrdw100-10 .
n874 security...
pls..
thanks
Nov 22, 2013 | Whirlpool Washing Machines
Noisy during agitate cycle whirlpool washer
Originally posted as solution to Kenmore 24992300 failure to agitate and loud whirring noise during spin cycle.... Hope this helps:
The problem as I noticed it was that the washer would start making a super high-pitched and very loud whirring noise during the spin cycle, and that when I would open the lid, the drum would not be spinning, but when I would close the lid, the drum would start spinning. I was okay with this during that load but after reading here and taking it apart, I realized what had happened:
The agitator dogs are supposed to have a 3-toothed profile on each one, but they become worn over time due to being made of a soft plastic. The dogs should "throw out" into an inner ring gear during normal operation, turning the entire drum. But when they became worn enough to slip, they would still throw out, grinding them at very high speed into the inner ring gear. Since they are made of a softer plastic than the gear, they were just getting more and more worn.
I assume the way this was supposed to fix itself was that when the outer tooth on the dog became worn, the next one would engage, but that didn't happen.
Because the dogs are made of such a soft plastic, I was able to cut a new tooth profile into each one, so that when they were put back in they would function correctly. It takes very little effort and a few minutes with an x-acto knife to cut the right profile.
I'm going to buy the replacement dogs, which being a manufacturer substitute will hopefully be made with a better tooth profile, from harder plastic, or both.
As another note, who knows how long the dogs weren't engaged correctly during agitation, causing clothes to sit without really being washed, but without the high pitched air raid siren. So probably a good idea to replace or repair them immediately, even if you can get it to work intermittently.
Sep 12, 2013 | Sears Parts Direct Whirlpool 4313896...
Kenmore 500 washer wont agitate.
Aug 07, 2013 | Kenmore 500 6952 Dryer
Kenmore 70 Series washer - agitates and drains but does not spin
my kenmor washes and drains but does not spin, help
Jun 17, 2009 | Washing Machines
Kenmore 90 series loud whirring/howling noise during spin cycle
Sounds like you have a broken motor coupler. They are inexpensive. Can be a little tough to replace but I can walk you through it. You can purchase a coupler here.
http://www.shop.washermd.com/product.sc?categoryId=1&productId=1
Dave
Dec 18, 2008 | GE WBSR3140DW Top Load Washer
Loud spin cycle
OTHER THEN CHECKING THE WATER PUMP I THINK YOUR RIGHT THE BEARING ARE GOING,IT WILL WORK FINE TILL THEY LOCKUP THEN THE BELT WILL BURN OFF,BUT I WOULD CHECK THE WATER PUMP ALOT OF TIMES IT JUST THAT,LET ME KNOW -MIKE
Nov 03, 2008 | Frigidaire FTF530ES
Water does not drain, strange noise while in spin cycle
sounds like something is stuck in your drain system. Most likely just in front or even in the pump
Please check this
Apr 22, 2008 | Kenmore 94812 Top Load Stacked Washer /...
Spin cycle
  Did it make this noise just when it stopped spinning.  Just for a couple seconds?  If so,  it's only brake noise and not a concern.  If it does this all during spin you probably have a bad tub bearing.  Is it a roaring noise?  This is what the bearing will sound like.
Oct 28, 2007 | Maytag PAV2300 Top Load Washer
Whirlpool LSR5132PQ Top Load Washer Logo
102 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
