Question about Samsung DVD-R155
Region code accidentally changed and no idea how to set it back
I found a post a couple of weeks ago on the internet somewhere how to check your region code on your dvd player. I did this and now when I try to play any disk it tries to read the disc and then says "This disc cannot be played, please check the disc" Discs recorded by the player work, but nothing else does. Please help
  • 4 more comments
  • kleopatra Oct 18, 2008
    I don't have a setting button on my remote. What should I press?
  • kleopatra Oct 19, 2008
    Can anyone help please?
    I pressed the menu button and checked the setup but you can't see the region there.
    I don't have the option to change it between pal, ntsc or auto. The settings menu is limited. I have also tried reading the manual and there appears to be no option to restore factory settings. Is anyone else able to help?
    The error I am getting trying to play discs tells me to "Please check the regional code"
  • kleopatra Nov 05, 2008
    I still have this problem. Is anyone able to help or provide instruactions on updating firmware?
    New Friend:
  • 109 Answers
Power on your dvd and press setting as you can view on your tv monitor then check the displayed carefully look for dvd regional settings and change it where you live.
Posted on Oct 18, 2008
  • 2 more comments
  • Robjac puensula
    Robjac puensula Oct 19, 2008
    press menu on the remote you can view features of set ups for your dvd.
  • Robjac puensula
    check the dvd settings shows pal, ntsc, or auto then put on auto.
  • Robjac puensula
    one thing i forgot, please read your product manual carefully so that you can reset to default settings.
  • Robjac puensula
    Robjac puensula Nov 05, 2008
    is it possible for you to reverse your entry of how you change it.
    or better log onto the product website of your dvd and then there a guide for you to reset to default settings where most of manucfacturer installed in their product. so far this is the best remedies can aided you in your quirries.
    Thanks for your interest with us.
Incorrect disc region code
Look at the region code of the DVD that plays on the vehicle DVD if it is the same of the others that do play it's not a region code issue. If the others are a different region to the DVD that plays or the disc says it is region free. Then you might have a problem with the region code settings on the machine. You can look up the model number of that player to see if you can change the region code.
Otherwise check out the player to see if it needs cleaning or is faulty.
Aug 14, 2016 | Televison & Video
Apex ad-1201 multiregion reprogramming question
Open tray
press 8 4 2 1 (you will see -'s appear top left of screen)
Menu appears for region and Macrovision
Use up/down keys to select Region/Macrovision
Use Enter to change region/Macrovision on/off
A PAL region 2 disk played fine when switched to region 9 (Really region 0 , ie region-free)
Have not yet tested Macrovision
Aug 31, 2008 | Apex Digital AD-1200 DVD Player
I bought a Samsung GALAXY Tab 4 7.0 tablet several weeks ago and it has worked beautifully until this week. It will no lomger access the internet or even attempt to scan for internet access. How can I
Have you tried turning it off, letting it sit for a minute or so, and then turning it back on? You need to turn your tablet/phone off and reboot periodically or it "forgets" how to do things - just like a computer, because that is what it is. Another thing you can check for (under Settings) is, have you accidentally turned off the Wi-Fi button? Or have you accidentally put the tablet in Airplane Mode (also under Settings)? Either of those two things will make your tablet unable to search and connect to available wi-fi networks. Hope that helps.
Oct 20, 2014 | Samsung 8GB Galaxy Tab 4 Multi-Touch 7.0"...
DVD Format Problem in Bose LS 48
Follow this button sequence press when the error message appears"
Right Navigation - Up Navigation - Shuffle - Stop - Mute
this is make is play all discs.
Jul 27, 2009 | Bose Lifestyle 48 System
Changing to multi region dvd
There are a couple sites I found that offer the codes for that player and the BD-P1000. I am not sure if I am allowed to post the links for those sites but the link to the site zimcloud posted is one of the places I saw it listed. You can google the model and region code and a list of sites come up.
Cheers
Jun 27, 2008 | Samsung BD-P1400 Blu-Ray Player
Can't access the preferences tab
Pls try a full master reset which if done correctly would revert the unit back to factory default:
1. Power on the unit;
2. open the front panel lid to have access to the controls;
3. simultaneously press and hold the channel up and down buttons;
4. wait till "BYE" is displayed;
5. wait till clock switches off;
6. power on again and re-configure.
You may need to restore "Region Free"
1. Power on the DVP 3005.
2. Bring up the System Menu.
3. Navigate to the Preferences page.
4. Press the following combination of keys on your remote in this order to bring up the secret menu showing the Region Code.
1 3 5 5 6 6.
5. Use the arrow keys on the remote control to change the Region. To make it region free, set the Region code to “0′ (zero).
6. Exit the System Menu.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
May 23, 2008 | Philips DVP-3005 DVD Player
More...
online region codes just put in internet explorer model of player i already found couple sites
May 07, 2008 | Samsung HT-DS610 System
Wrong disc message displayed on screen for dvd-2026
I found these posts. I have only been able to get the fix to work once, though. :(
I found a "hack' to make mine work :)
1. Open the tray
2. Press "Setup": Menu Screen should appear
3. Press "8-8-8-8" ( if you changed the password, you might have to change it back to 8888 ) The region number should appear on upper right corner. No other notation. Typically just the numeral "1".
4. Use the right (->) or left (<-) arrow keys to change the region to 255 for all regions.
5. Use the up or down button to go to 3001 and 4000. I had to change 4000 to 4001 to get mine to work,
6. Press "Setup" to exit.
It was a big relief to find this hack, because I misplaced my receipt and thought I was simply out of $30.
Region code hack posted by jeff777, December 15 2004:
This works.
1) With remote control, power the DVD player on.
2) With remote control, open the DVD tray.
3) With remote control, select SETUP.
4) With remote control, press the VOLUME UP button, then the VOLUME DOWN button, then the VOLUME UP button again and finally the VOLUME DOWN button again.
5) You should now see a number 2 on your screen. If you do not, this hack will not work on your system or you have done something wrong. If you do see the number 2 on the screen, proceed to 6).
6) Use the LEFT and/or RIGHT arrow to select the number 255.
7) When you see the number 255, press the SELECT button.
8) Press the SETUP button again to end procedure.
Region code hack posted by RayH, May 18 2005:
Newer Sungale 2026 players are a bit easier to set up:
1. Open the tray
3. Press "8-8-8-8" Region number should appear on upper right corner. No other notation. Typically just the numeral "1".
4. Use the right (->) or left (<-) arrow keys to change the region. "255" all region.
5. Press "Setup" to exit.
Tested Region 1, 2, 3, 4, and 5 PAL and NTSC disks. They all work just fine on an older US NTSC TV. It's a little bigger than the Cyberhome, but works much better. There is no jerking at chapters with either factory or homemade discs. Plays VCDs just fine.
Sniff around the internet. This machine is availabe as of 5-18-05 for about $29 plus shipping ($11). Arrived in two days.
Other hack posted by Hurricane, January 23 2006:
If you do the Setup>8888 thing you get a region code 1-6 & 255.
Well if you press up and down on the directional pad you also get 3001 and 4001 these can be changed to 3000 and 4000, I know that one of them is a Macrovision on/off flag but I don't know what the other is.
Region code hack posted by Streetmedik, March 25 2006:
I have the Sungale DVD2026 I have tested this with DVDs from various regions. It works.
1. Power on
2. open the tray.
3. ON THE REMOTE press the VOLUME up, down, up, down.
4. ON THE REMOTE press SETUP
5. ON THE REMOTE press the up and down arrows to go between the macrovision/region codes.
6. ON THE REMOTE press the left and right arroes to change the values.
Macrovision
3001 on
3000 off
Regions
1,2,3,4,5,6 = individual regions
255 = all regions
7. ON THE REMOTE press setup again and you are set.
You can change these values again and again If you just want to play around.
Mar 22, 2008 | Sungale DVD-2026 DVD Player
Samsung DVD-R155 Logo
546 people viewed this question
Henry  Thomas
Henry Thomas
