Question about Fuji FinePix F401 Digital Camera
Trouble with lcd screen
I haven't used this camera in months. It's been charging a new battery for about 3 hours. When I turn it on, the images on the lcd screen appear as light blurry images.This is the case in shooting or playback mode when the media card is empty. When it's in playback mode with a card full of pics, old pics I have taken show up fine. Does it need to be charged longer ? Any ideas ?
  • 513 Answers
Have you tried it with another card? might help to narrow it down. Post back
Posted on Jun 12, 2006
SOURCE:
Troubles Turning Camera On
What kind of camera is this? I suggest calling the company such who will take time on the phone and work with you to fix the issue. Didn't have the same problem but have a Nikon and they assisted me over the phone almost an hour working with me to solve the issue.
Mar 25, 2017 | Cameras
I have a Canon ZR85A where the LCD screen as well as the eye viewer is a cloudy screen, not being able to see actual image to record. I thought I fixed the problem as I replaced the backup battery. The...
Any battery will lose the ability to take a charge if left unused for over a year. Replace all the batteries, charge them fully, and re-charge them at least once a month.
Mar 17, 2017 | Canon ZR85 Mini DV Digital Camcorder
3/4 of my camera screen is all white and i don't know what could have happened to it because i haven't dropped it, but it has been in my purse for a long time, but nothing in my purse is heavy...
Possible that the LCD screen has failed. You can take images and load them to the PC.,If the images are clean then the LCD is a suspect. remove the battery for sometime and reset. If the fault occurs as a blank screen then the LCD must be taken out and checked for possible damage.
Jul 11, 2011 | Cameras
I purchase s10-3 netbook. i had problem with its battery which only runs 2 hours if it is fully charged. please assist!
How long have you been using the netbook? If it's brand new, then your battery life is too short. First of all, remember the following for ensuring that your battery performance is optimal:
1. A new battery pack must be fully charged before it is put into use.
2. A new battery pack needs to be fully charged and discharged a few times before it starts performing at full capacity.
3. Batteries discharge when left unused. If you intend to store the netbook for a while, make sure that the battery is fully charged before you do so.
4. Fully drain and fully recharge your batteries every few months.
If your netbook is new, then try one or more of the following and see how your battery performance gets affected: 1. Turn down the LCD brightness of your portable device.
2. Use built-in power management on your portable device.
3. Turn off LCD or other unnecessary accessories when not in use.
4. Set screen saver blank to 1 to 2 minutes of your netbook.
5.. Add more RAM if you can, as this will reduce the usage of the hard drive which exhausts the power quicker.
Hope this helps.
May 24, 2011 | Lenovo Computers & Internet
My camera shows that battery is low even if battery is new
Clean the battery terminal connections with rubbing alcohol and a cotton swab
Sep 29, 2010 | Nikon COOLPIX L20 Digital Camera
I am in Pune 411004 in India and have purchased Samsung digital es 15 camera recently. Original 2 aa Alkaline batteries have been completely used up.when I replaced these with 2 new eveready batteries...
Solution: As digital cameras become more advanced and include more features, the power needed to keep them functioning has also increased. That means that typical alkaline batteries likely won’t do more than power your camera for a few shots before running out of juice. Sometimes, your digital camera may not power on at all if the inserted alkaline batteries aren’t fully charged or powerful enough. Rather than carry along dozens of alkaline batteries for a single photo shoot, you can save money by purchasing rechargeable NiMH (nickel-metal hydride) batteries. Rechargeable batteries can be purchased with a charger that you plug into a wall outlet, and they fully charge in one to five hours depending on the charger and the type of batteries you’re using.
If you’re already using rechargeable batteries but are experiencing short battery life with your digital camera, it’s likely time to replace your rechargeable batteries with new ones. Depending on the number of charging cycles you perform (how many times you discharge and recharge your batteries), rechargeable batteries typically last for two to three years before they no longer hold a full charge. You may also ensure that you’re charging your rechargeable batteries directly before use. As batteries sit unused for extended periods of time, they automatically lose some of their charge.
There are many ways you can conserve battery life while using your digital camera, too. For starters, if your camera has a viewfinder in addition to an LCD, use the viewfinder to frame your shots and turn the LCD off because LCDs draw a lot of power. If you prefer to use the LCD, you can still conserve battery life if you refrain from looking at each picture on the screen after you take it.
Jun 13, 2010 | Cameras
NO IMAGE ON MY MONITOR WHEN ON.
This sounds like it might be a defective CCD imager. If so, Canon should fix this for you for free worldwide, and may also include free shipping both ways (free shipping varies with countries). This is regardless of your camera's warranty status. Please check this link for more info.
Applicable cameras include: A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110, IXUS V2/V3/300/400/430/500/II/IIs, IXY Digital 200a/300a/320/400/450/500/30/30a
Jan 24, 2010 | Canon PowerShot A95 Digital Camera
Canon XSi not powering up
if it has a view finder make sure in the settings that the image is set to show up on the LCD screen also make sure the batteries have a FULL charge which means at least 8 hours of uninterrupted charging before use.
My guess is that with most nice digi cams it is set to not show the image in the LCD viewfinder but rather the actual real time with your eye view finder. look around the menu if you can and see what you can change as far as view finding and if i didn't help please specify the problem a little more and i will be glad to do whatever i can to help.
Jun 01, 2009 | Canon EOS Rebel XSi Digital Camera
Fuji FinePix F401 Digital Camera Logo
105 people viewed this question
Top Fuji Cameras Experts
Steven Wander
Steven Wander
Azam Ali
Level 1 Expert
KJ Soni
Level 1 Expert
Are you a Fuji Camera Expert? Answer questions, earn points and help others
