Question about Canon Pixma MP800 All-In-One InkJet Printer
How to Clean the inner part of the glass for scanning
During scanning, I now see white dots on the photos. I could see dust on the inner part of the glass. How do I clean the inner part of the glass? I am quite technical guy so hopefully someone could point me in the right direction.
  • royyusi Nov 13, 2008
    Hi scrounger. There is no glue holding the covers together. There are some interlock within the cover that makes it difficult to remove. What I did was I googled for service manual for MP800 and manage to download it. In the manual, you will have photos and detail instructions on how to remove the covers.
  • Alex Turley May 11, 2010
    I have read your report jamie and must have the later 2005 model mp800 because when I undo all of the screws to get at my stuck printer tanks, the panels wont come away. Are they glued in somehow?
    I'm still chasing my 6A00 fault.
    turleyal@gotalk.net.au
    Scholar:
  • 32 Answers
Generally you should not have to clean the underside of the glass unless you are in a high dust environment. This would require disassembly of most of the printer itself. The glass is held in by double-sided tape or a bead of glue, so don't try to remove the glass sheet itself.
The easy part is the beginning, removing the scanner cover. Next you will have to locate screws around the outside and start taking panels off. Keep note of the panels and the screws. After the side panels are off, there should be a set of screws around the scanner itself that hold the scanner and plastic casing with the scanner glass. Once those are removed, the scanner glass with its frame should be able to be removed. From there you can use whatever you would like for glass cleaning, make sure it is streak free.
Older scanners make this easier. Most of them are 4-6 screws and the top half pops off and can be easily cleaned. A multifunction isn't so fun in this sense.
Hope this helps!
Posted on Oct 18, 2008
While printing, red turned to pink on printed sheets. All cartridges have ink.
Try
Clean the Scanning Area sikaku.gif Cleaning the Platen Glass and Document Cover i_expl.gif Caution
Be sure to turn off the power and disconnect the power cord before cleaning the machine.
i_important.gif Important
bullet_s2.gif The inner side of the Document Cover (white sheet) (C) is easily damaged, so wipe it gently.
bullet_s2.gif If the glass of the ADF (A) is stained with ink, correction fluid, or the like, black streaks may appear on the printed paper when the document is loaded in the ADF. With a clean, soft, lint-free cloth, wipe the glass of the ADF.
With a clean, soft, lint-free cloth, wipe the Platen Glass (D), the inner side of the Document Cover (white sheet) (C), the glass of the ADF (A), and the inner side of the ADF (white area) (B) gently. Make sure not to leave any residue, especially on the Platen Glass.
sikaku.gif Cleaning the ADF i_expl.gif Caution
1. Open the Document Tray.
2. Open the Feeder Cover.
3. With a soft, clean, lint-free and dry cloth, wipe off any paper dust from the inside of the Feeder Cover (A).
4. After wiping, close the Feeder Cover by pushing it until it clicks into place.
5. Close the Document Tray.
6. Reconnect the power cord then turn on the machine.
Oct 27, 2010 | Canon PIXMA MX850 Multifunction Printer
I have lines in printed material
If a print result of faxing, copying or scanning has uneven print density, or when copies and scans you make have vertical black lines, cleaning the platen glass may solve the problem.
  1. Turn off the power and disconnect the power cord.
  2. Prepare two clean, soft, and lint-free cloths.
    Note:
    Do not use tissue paper or paper towels as they may damage the machine.
  3. Open the document cover.
  4. Wipe the platen glass (D), the inner side of the document cover (white area) (C), the glass of the ADF (A), and the inner side of the ADF (white area) (B) with a clean, soft, lint-free cloth moistened with water
    (A) ADF Glass
    (B) ADF White Reference Area
    (C) Document Cover White Reference Area
    (D) Platen Glass
    Note: If you have trouble wiping dirt, use diluted mild detergent (for dish washing).
    Caution:
    * Never use volatile liquids such as thinners, benzene, or alcohol; these can damage the machine.
    * The d
    ocument cover white reference is easily damaged, so wipe it gently.
  5. Carefully wipe away moisture from each part with another soft, dry lint-free cloth. Do not leave any residue, especially on the platen glass.
  6. Close the document cover.
  7. Reconnect the power cord and power the machine back on.
Oct 26, 2010 | Canon MP830 All-In-One Printer
When I scan a photo, my Brookstone IConvert photo scanner has white lines all over the pictures.
The reason it has white lines is because the glass is dirty in the inside. If it has one speck of anything inside the scanner it turns into a line because it stays in that one place as the picture slides over it. So that line is actually a dot that is covering the picture throughout the scan. The solutions don't work. I don't suggest taking yours apart. I took mine apart and cleaned the glass. The pictures scanned fine and then the lines show up again. The real solution is to get your money back if you can. It will do this over and over. It's a design flaw in the scanner. The picture is actually squeezed as it it scanned. As pictures are squeezed against the glass... residue builds no matter how clean your pictures are.
Jul 30, 2010 | Office Equipment & Supplies
How do I clean under the scanner head or glass? I get dust on scanned color photos at 300dpi and the glass is totally clean.
use a lint free cloth with a touch of rubbing alcohol or buy a tin of dust-off. The glass is nothing more than glass so don't be afraid of keeping it clean. You just need to be careful not to use anything that can scratch the surface. Be sure to leave the lid open to allow it to dry before scanning.
Jan 23, 2010 | Canon PIXMA MP530 All-In-One InkJet...
Cleaning between oven glass
You must unscrewed inner door,there is screws around edge door inside,try it.
Feb 17, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Poor quality scan? Tips for cleaning this device
You can clean the scanner glass with warm water and a dust free cloth. Is the line always in the same spot in your scans? Could be something else other then dirty glass.
Aug 26, 2008 | Lexmark X1240 All-In-One InkJet Printer
Vertical white lines in scanned image
Did you try cleaning the little glass strip where the documents go in? Lift the button panel and wipe the glass with rubbing alcohol and cotton swabs or lens paper if you have it. Mine does this sometimes when dust or white out or little bits of paper get stuck on the glass.
Apr 25, 2008 | HP OfficeJet 4315 All-In-One InkJet...
White spots on scanned photos
There's probably nothing you can do for dust under the glass, but in the Advanced settings for your scanner, there is an option to turn on "Reduce Dust & Scratches", with three different 'strengths'. You may want to try this to see if it helps.
Apr 21, 2008 | Canon PIXMA MP530 All-In-One InkJet...
Dirty scans
Small white dots would indicate progressive failure of the CCD[sensor] or perhaps ingress of dirt to the inside of the glass. hard to say exactly with out seeing the machine.
Jan 13, 2008 | Epson Perfection 3200 Photo Flatbed...
Vertical lines through scanned images.
You should clean the small glass under the top lid. Chances are there is some white out or ink or mark on the glass. Look carefully because usually it is just a small dot>
Dec 01, 2007 | Canon PIXMA MP830 All-In-One InkJet...
Canon Pixma MP800 All-In-One InkJet Printer Logo
566 people viewed this question
old marine
old marine
