Question about Hitachi UltraVision 55HDS52 Television
How do I adjust the picture, I lost my remote..
The picture on my tv looks distorted and off balance. (only way I can describe it is the picture looks like it squished inward) I don't know if this is because the tv is starting to get old or if something got pushed on the tv. We lost the tv remote a long time ago, but use our dish network remote to adjust the tv volume or channel. I tried to push the magic focus on the tv several times, with no luck. I also tried turning the tv off for awhile with not luck.
    President:
  • 3,130 Answers
Sorry Bud you cant. An original remotes available at http://www.remotes.com or 1800-remotes for about $61.00 + shipping. Without seeing a picture Im not even sure if thst will help ya man. If you wanna try to see if an alighnment will help then get the remote. I would advise you against doing any sort of technical alighnments as this set has high voltage around inside even afterv its been disconnected for a while. Good Luck
Posted on Jun 09, 2006
SOURCE:
I have a 52'' Magnavox Projection screen tv and the colors are messed up. The best way to describe it is that it looks like your looking at a 3D movie without the glasses. Can you tell me what's going on?
The most likely cause is shorted convergence chips and possibly a few pico fuses.
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2
Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
You can see some more examples and find a fix herebb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Apr 17, 2010 | Philips Magnavox 51MP392H Rear Projection...
54inch Hitachi TV has double figures and colors red, yellow-not normal. Set approximately seven -eight years old. Lost remote control and direction book in moving. Is the set worth getting fixed? Generally...
Convergence problems are very common on all Projection TV sets including Sony2_bing.gif,Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer2_bing.gif, Hitachi, Zenith, and others. You can get a convergenece repair kit wiith instructions from the links below.
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted or warped
  • No Audio/Video - makes a chirping sound.
Problem #2
  • Dull looking picture
  • White looking picture
  • Halos around objects
  • Red/Orange looking picture
Apr 11, 2010 | Hitachi 57F500 57" Rear Projection...
Akai PT5499hd that has suddenly lost color alignment
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer2_bing.gif Hitachi,Mitsubishi,Zenith and others.
*Screen Looks 3-D
*Colors wont align
Problem #2
You can see some more examples and find a fix herebb0cf99.png http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Dec 23, 2009 | Akai PTH5498 54" Rear Projection...
Picture stretched on samsung ws32z409t tv
Sometimes on a remote theirs a zoom button or HD zoom if you pressed that the tv will do what you describe if you press it again it will go back to normal view.
Jul 27, 2009 | Samsung WS32Z308P 32" TV
Convergence is scrambled due to power outage. how do i use remote control to get into service mode to do a "course convergence adjustment" ?
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony,Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit wiith instructions from the links below.
  • Screen Looks 3-D
  • Colors wont align
Problem #2
Your TV may have one or more of the following symptoms....
Dec 10, 2008 | Panasonic PT-47WX53 47" Rear Projection...
Picture all distorted cold warms up ok
Projection sets have two very common problems.
The first common problem is convergence
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
*Screen Looks 3-D
*Colors wont align
Problem #2 - Another common problem is dull or washed out video.
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Dec 06, 2008 | Toshiba 57H82 57" Rear Projection...
DISTORTED PICTURE
*Screen Looks 3-D
*Colors wont align
Nov 02, 2008 | Akai PT4298HD Rear Projection Television
TV turns on and then, after a few seconds, picture changes to "double vision".
*Screen Looks 3-D
*Colors wont align
Oct 25, 2008 | RCA P46921 46" Rear Projection Television
Toshiba 32 inch tv picture is distorted
have you tried pic size on the remote to adjust the image. normal is the factor default.
Jan 29, 2008 | Toshiba 32AF43 32" TV
Problems with TV
Our 37 inch Sanyo LCD HDTV has a problem with the picture distorted by being too wide. This has beenia problem for the duration since we bought the TV about three months ago. The PIX Shape button on he remote does not adjust this problem. We need help in solving the problem. Thank you.
fred_story@cpmcast.net
Oct 24, 2007 | LG LRSC26980 25.2 cu.ft. TV Refrigerator...
Televison & Video Logo
71 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
