Question about Canon PIXMA MP150 All-In-One InkJet Printer
Copyer problem my canon pixma mp150 cannot copy A4 paper. if i copy A4 document the result always cut in letter
  • Canon Master
  • 5,568 Answers
Go to the Control Panel, open Printers and Faxes, right click on the icon for your Canon, choose Properties.
Since the offered settings can differ from one model to another, you may have to look at any tabs shown to find the default setting for paper type but it will probably be under 'Advanced.' Check through the various settings and you should find settings influencing which paper size the printer should use and expect.
Posted on Oct 18, 2008
Can I scan legal size paper with the Canon MP 240
Hi
You can scan the largest size of paper that will fit on the glass area of the scanner (the platten).
If your legal paper fits in this area or, at least the text printed on it fits well within the borders of platten, then you can scan it.
Your scan will show you a preview of the image scanned so you can see if all the text has been scanned from the original document before you save the scanned image on the computer or copy print it.
Legal Paper Size is: 8.5" x 14" (216mm x 356mm)
A4 Paper Size is: 210mm x 297mm
Letter Paper Size is: (8.5" x 11") 216mm X 279mm
This printer's Scanning Width is: A4/Letter
This printer's Scanning Length is: A4/Letter
I hope this helps.
Aug 28, 2011 | Canon PIXMA MP240 All-In-One InkJet...
A few letters are cut off on left side
it could be a software problem. Please make sure that in the software where your printing originated, the paper size is set exactly as compared to the actual paper you use for printing. Example, if you are printing using an A4 paper, make sure that the document is laid out using the A4 setup with correct margins not exceeding the paper's printable area.
Nov 10, 2009 | Canon PIXMA MP470 All-in-One Printer
I Have a problem with my canon MP 150 Printer
From Canon Support: "Please be advised that if the MP 150 is displaying the letter E followed by number 3, this would indicate a paper jam. "
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=238&modelid=16981
Jan 17, 2009 | Canon PIXMA MP150 All-In-One InkJet...
How to print envelopes on my printer
Use The Recommended Print Area For the best printing results, adjust the top and bottom margins of your document to within the recommended printing area shown below. Click on the paper size listed for the recommended print area settings: A4 / B5 / A5 / 4 x 6 / 4 x 8 / 5 x 7 / Credit Card, Letter and Legal, Envelopes (DL / COM#10)
Caution: When printing is performed outside the recommended printing area, the top and bottom edges of the paper may curl, the print quality may deteriorate, or the printed side may be smudged.
The printer has both the recommended print area and the printable area, according to the paper size.
05sj00144_01.jpg Recommended print area: This indicates the recommended print area.
05sj00144_02.jpg Printable area: Although this indicates the printable area, degradation of print quality may occur.
Note:
  • Set Borderless Printing to print without margins.
  • In Duplex Printing, the printable area of the paper's header is approximately 2 mm narrower than usual.
05sj00084_03.jpg Letter / Legal
Envelopes ( DL / #10 )
Nov 22, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Canon iR1600-2000 PCL6 does not want too copy a standard A4 document.
A4 is not a standard document !!!!!!!!!!!!!!!
It is European. LETTER & Legal are standard.
change paper size
Sep 08, 2008 | Canon Office Equipment & Supplies
Paper size repeatedly returns to "Letter" when I want A4size
go to control panel and choose printer and fax option, right click and select printing preferences. select page setup tab, adjust the paper size to your wanted dimension, then finally click apply and ok. this changes is permanent.
Dec 19, 2007 | Canon PIXMA iP3300 InkJet Photo Printer
Not print or copy
posible a small piece of paper jam in the senzor. check please the entire paper path
Oct 17, 2007 | Canon PIXMA MP150 All-In-One InkJet...
Canon PIXMA MP150 All-In-One InkJet Printer Logo
49 people viewed this question
old marine
old marine
