Kenmore top load washer spin problem
I have a Kenmore elite model 11024952300, 4 years old. When the problem started there was no spin. I was able to reach into the tub and turn the tub, then it would spin out this malfunction only happened from time to time. Now the washer goes into spin but will not get up to full speed. The spins just doesn't spin fast enough to get all the water out of the cloths. There has been occasions when you would have to spin cloths 3 times. Now that doesn't work.
  • sonessimo Apr 15, 2009
    The spin cycle is not working machine is about 6 years old
    President:
  • Washing Mach... Master
  • 2,651 Answers
Its possible you have a bad clutch assy, or perahps something stuck between the outer and ineer tub(i.e. sock) preventing free spin of unit, the clutch is mounted on top of the transmission assy and requires a little bit of work to acess, im sure you can find a video on you tube as to how to acess that
Posted on Oct 19, 2008
My kenmore 800 washer is off cycle for example when i start a load of clothes it starts agitating before filling, and doesn't always spin all the water out of the clothes
I have the exact same problem with my Kenmore 800 top loader, Model # 110.29822800. It is only 1.5 years old. Any suggestions?
Jan 19, 2011 | Kenmore 22422 Top Load Washer
My kenmore elite washing machine ( TOP LOAD) is not agitating or spinning". is it the belt or the clutch. Modle # 11024952300
there's no belt in the kenmore washers,they have a motor coupling.take out the two screws that hold the top console down.flip up the console it's on hindges,next with a screw driver pop the two metal clips and unplug the lid switch harness that's in between the metal clips,then open the lid and grab the frame,pull the frame to you and up and remove the whole frame.on the bottom you'll see the pump,with a screw driver pop the two metal clips and slide off the pump.take out the two screws and pop the metal clips and slide off the motor.on the back of the motor you'll find the coupling broke,it sounds like alot of work but it takes around 20 minutes to do
Aug 30, 2010 | Kenmore 24032\24036 Top Load Washer
Machine will not switch to drain and spin cycle
If you take the front off in the lower right you will find a pump motor that controls the drain flow. This may defective. Use a shop vac to empty the water in washer if needs be. But remove and test this pump.
Apr 16, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Kenmore Washer Grinding Sound - No spin or agitation
sounds as if oyou have a bad motor coupling, you can search you tube for keywords, whirlpool motor coupling, far easier to watch someone perform the repain that try to explain it, easy to do!!! part number 285753
Feb 23, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore elite front loading wash & dryer-5 yrs old: should i buy?
all kenmore named washer will have 110 as first 3 digits of model #..the he washers are usually good washers..like all front loads they have their quirks ..if you read reviews from other consumers they indicate problems ..most of which are easily remedied by reading owners manuals..mold /mildew usually a bleach clean every few months ..vibration need real solid floor..oversuds use HE detergents only..just a matter of changing mind set from top loads with 25 gals of water each fill to a front load with 5-6 gals each fill..top load with 750-850 rpm spin speed to front load 1000-1200 rpm ..if willing to learn proper use and what to expect they can best investment..just don't let opinions of those unwilling to adapt affect your decision
Dec 16, 2008 | Kenmore Elite 45986 Front Load Washer
Washer has spin problem
Sounds like there is a problem with the clutch , they go out often on whirlpool washers and are not too much money. its located right above the trans. and you must pull everything out of the bottom.
Oct 18, 2008 | Kenmore 24032\24036 Top Load Washer
KENMORE TOP LOAD WASHER - MODEL # 11022422100
hi. thanks for the question . i would check the lid switch ,on that washer. it could be the problem thanks. the appliance doc
Oct 05, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore elite top load washer
error code with this? f11 or f22 are control board related commucation errors.
Jun 02, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore elite washer top loading 6 years old clothes still wet after spin cylce
Click on 'washing machines', then brand name (below FIXYA) on this website, type in your model number & search. You will get a shortlist; click on your model,below the page u will get Manual/Guides. Click on the blue, you have your manual on line. Possible your filter is clogged after these years.
And dont forget to rate me on this great site.
Jan 21, 2008 | Washing Machines
Washing Machines Logo
285 people viewed this question
Top Washing Machines Experts
