Question about Hitachi 43GX01B 43" Rear Projection Television
Half Pictur During a storm our tv obtained a pink wave like line at the top and only the top portion of the tv has a double image. When I change the input the top left idenification numbers are slanted and overlap each other. What can I do and will it be worth it??
    President:
  • 3,130 Answers
Sounds like theres an upper area convergence problem and the only way your gonna get this fixed is with a pro assiting you with this repair as there really are no user serviceable parts in this set. This repair could be a major replacement of the convergence ICs or capacitors . Complaints that occour during a storm are non common as anything can and does happen.Sorry could\'nt be of more assistance. Good Luck 1.888.426.5214 for the factory service peeps
Posted on Jun 09, 2006
SOURCE:
RCA TV older big back 36" went out during power outage storm, back on with good volume but pictur only a thin line in middle of screen across
People are giving away their older TV's as they upgrade to new wide flat-screens nowadays. That makes your TV not worth fixing. Keep checking Craigslist and your local thrift stores for one that's cheap or being given away.
Jan 03, 2015 | Televison & Video
I'm noticing all my pictures have a pink hue to it, and pink bar on top
Hello,,,
Your Canon A80 has problem of defective CCD Imager Sensor and this part need to be replaced.
Good news is that Canon will replace CCD Imager free of cost as per announced free of cost repair scheme.
Click on Canon CCD Advisory for details how to obtain free repair facility.
Good Luck....
Jul 14, 2008 | Canon PowerShot A80 Digital Camera
Philips SAA7130 TV Tuner/FM... Problem
(Have u got a small cable with both side 3.5mm pin like head ph cable cord if not buy it) NOW FoLLOW THE STEPS1)plug the cable between tv card jack(green slot) to line in jack (computer pink slot)2)plug ur spker to line out jack(green slot in computer)3) double click on small spker icon (left side to ur screen near clock)4) click options menu>Properties>chose audio out option 4m drop box(see image)
11_2_2011_5_27_42_am.jpg5)click rear pink in >okAnd all done have fun
Jun 26, 2008 | Philips SAA7130 TV Tuner/FM Radio/Video...
Concave Images with pink and green colors
you can get it your tv fix the problem is in the IF amp and video circuit.a convergence will also be neeeded.the tv is old but can give you some more life call a tech they will be your tv doc.
Apr 03, 2007 | Sony KP-57HW40 57" Rear Projection...
During dark images on my TV, several green lines are visible across the TV.
You may have an arc in the screen and focus circuits. Water may have gotten into these circuits causing a delayed reaction. (Circuits Corroded). These circuits at least part of them are a part of the high voltage transformer (flyback). Your picture tube socket has spark gaps inside of it too which may be arcing. You need to have it checked by a tech to find out just what is arcing. Stargazer
Mar 11, 2007 | Samsung TX-R2765 TV
White Horizontal Lines near the top of my Screen
this symptom is what we called vertical fold-over. vertical fold-over is characterised by a white horizontal bar on the bottom or top of the raster due to the concentration or compression of the trace lines. it an image is present, the bottom or top portion is fold over. this is caused by a vertical deflection current with poor linearity, which compresses the trace lines at the bottom or top of the screen. this symptom is is caused by a defective sawtooth wave genetator circuit, or improper biasing or defective feedback circuit of the vertical drive or vertical output transistor/ic. the negative feedback circuit in vertical deflection circuit compensates for the linearity of the trace portion of the sawtooth wave. a decrease in the capacitance of the sawtooth generator capacitor is usually the trouble. but if you do not understand anything what i have written here, better bring it to a qualified tv technician for your own safety also. good luck!
Mar 01, 2007 | JVC TM-2703SU 27" TV
Sony KP-57WS500
the unit needs the convergence ic's replaced and probably a couple of safety resistors.average repaire are about 300 from a tv shop
Mar 04, 2007 | Sony KP-57WS500 57" Rear Projection...
Hitachi 43GX01B 43" Rear Projection Television Logo
37 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
