Question about Maytag 24 in. MDB5600A Jetclean II Built-in Dishwasher
Maytag quiet series 200 won't start
When i press touchpad, there are times it works fine & others when it won't startup at all
  • 3 more comments
  • Anonymous Nov 29, 2008
    my stupid dishwasher wont start either i have fiddled with the metal thing tried to push it closed hit every single button and i cannot get it to work either but the lights turn on..
  • allanmarcil Dec 20, 2008
    Maytag Quiet Series is probably fine for single person who eats out most days. For a family, this machine is not up to the job. Digital panel fails (three times, buy the extended warranty.) Dishes don't get clean because spinning things inside get clogged, have to poke clean with a tooth pick -
    Go Bosch - twice as much money - but, you get what you pay for...
  • tuffyh10k May 17, 2009
    MY MAYTAG QUIET SIERIES 200 WILL NOT START THE OTHER BUTTONS WORK BUT NOT THE STATRT BUTTON
  • AnotherLemon May 19, 2009
    I have a similar problem that just came out of nowhere. When you try to start up the Maytag MDB-8 dishwasher (which by the way is JUST BARELY two years old). The START button and the DELAY button don't work. All other buttons work on the control panel. The door is in all the way and latched.
    Thinking it may be a glitch in the electronics, I even turned off the AC power to the dishwasher. That didn't do anytning. Sad state of affairs when you pay $400 for something that barely lasts two years. I bet the Maytag repair man isn't fat and rolly poly anymore. He can't be, because he is constantly on the run fixing the junk Maytag makes.
    Jim B
    Fair Oaks, CA
  • Anonymous Mar 20, 2014
    Fills but won't wash
Does it help to push it more tightly shut...or fiddle with the latch.
Mine is not running consistently unless we push the door shut tightly. Others here also report problem with the safety latch causing this washer to quit. May have to replace the part.
Posted on Nov 10, 2008
Maytag Quiet series broken?
Check the door switch.
May 03, 2013 | Dishwashers
I have a Maytag Quiet Series 200 dishwasher. The 3 symbol on the face control panel light is on and starts flashing anytime you push any other button and it won't run. What is the problem?
Hello & Welcome to FixYa
You can press and hold the RINSE ONLY/AIR DRY/HEATED DRY button for 20 seconds to reset the control. Please get back to me if you have any other questions.
Kevin
Mar 07, 2011 | Maytag Dishwashers
My maytag quiet series 200 wont do anything when I press the start button. there are no lights. I have tried tripping the circuits?
Mine would not start, and could not set any options. I read online to try resetting by pressing Heated Wash, then Heated Dry, then repeat both. I did it and my machine cleared and worked fine. Give it a try!
Dec 13, 2010 | Maytag 24 in. MDB5651A Built-in Dishwasher
I have a maytag quiet series 200 type 777-0 when i push the start/cancle it will not start?
We had the same issue with our Maytag quiet series 200 dishwasher. The Start/cancel button would not work all the time. We ended up removing the front panel from the machine and on the backside of the panel there is a plastic ultra thin ribbon cable that runs from the computer box to the push button control panel. We wiggled the ribbon cable and the start button began to work, but only if the ribbon cable was held in a certain position. So we super glued the cable in that position and it's been working consistently now.
Upon closer inspection the ribbon cable appeared to have 3 or 4 very tiny dark spots on the wires.
That would indicate to me that somehow moisture slowly eroded the tiny wires and bending the cable made the connections touch again, but for how long it will work like this is anyone's guess.
Also, it appears that the ribbon cable is permanently attached to the push button control panel. So you can't replace the ribbon cable itself without buying the hole front panel.
Aug 19, 2010 | Maytag Dishwashers
Maytag Quiet Series dishwasher won't start
Sounds like you have a bad Control Board
http://www.partstore.com/Part/Maytag/Maytag/MDB6600AWW/Maytag/Maytag/99003160/New.aspx
But with the price it cost, you might be better off buying a new dishwasher, preferably a different brand, cause that washer has some bad reviews
Oct 12, 2009 | Dishwashers
Keypad does not work
Time to buy a new one I guess.
Go check the fuse braker, it tripped probably.
Did you close the door properly , push it hard with a slam. It will start working. Jiggle the float inside the up and down.
Vitally
May 11, 2009 | Maytag MDB7100AWB Dishwasher
Maytag Quiet Series 200 Electric Dryer
I also had a similar problem with my maytag dryer which is 3 1/2 years old. It was the idler lever assembly with pulley. The part number is 11222607JG and the cost is about $20.00. Hope this helps.
Apr 04, 2009 | Maytag Dryers
Maytag quiet series model #:MDBH950AWB
The dishwasher lights are all blinking, it starts randomly, like one in every 50 times you press the buttons. I have unplugged it to reset several times. Nothing is working. I'm looking for a solution to blinking lights and it not starting. is there any other way to reset the controls????
Jan 13, 2008 | Maytag 24 in. MDBH950AWS Built-in...
Maytag legacy series 3 yr's old
I had a similar problem where slowly specific buttons stop working. Moisture was getting into the control board and slowly killing buttons. I replaced the control board and that worked for another year, until the buttons began dying again.
For now, there are other ways to start the machine, but you just have to let time expire to stop it. It is probably a control board issue.
Dec 12, 2007 | Maytag MDB7100AWB Dishwasher
Maytag 24 in. MDB5600A Jetclean II Built-in Dishwasher Logo
3,161 people viewed this question
Top Maytag Dishwashers Experts
Charles T Nevin
Charles T Nevin
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
