Question about Pioneer SD-643HD5 64" Rear Projection Television
How to get to mirror and lenses on a pioneer SD-643HD5?
Can anyone post detailed instructions on how to get to the mirror and lenses on this tv?
Unplug tv. Remove 4 screws from bottom of tv in front right below speakers on right and left side. Bottom panel slides up and out. Don't disconnect just rest panel on front of tv. Remove two screw at bottom of trim strips on each side of screen. Each one of these strips will slide down and remove. Last piece to remove is trim strip at top of screen. There are no screws to remove. The whole piece simply slides to the right about 2" to 3" inches then will unlock from mount brackets. Pull towards you and slide up and off screen. carefully lift screen up and out of bottom brackett. Top trim piece may be a little tight. Just tap on it with the palm of your hand and have somone pull on strip from other side.
Posted on Nov 10, 2008
What size mirror pioneer sd-643hd5
All the mirrors are of special construction: a normal mirror will not function or produce a good picture.
Consider looking online (GOOGLE) for one of the several vendors who sell replacement mirrors by brand/model number or contact Pioneer to see if mirror available.
There are also people parting these sets out on Ebay from time to time.
Good luck and if you have questions let me know.
Steve
Feb 29, 2012 | Pioneer SD-643HD5 64" Rear Projection...
Tell me how to clean my bulbs and mirror of my pioneer SD-643HD5
You will have to remove the Front Screen ,First remove the bottom Panel and then the screen.
Jun 29, 2011 | Pioneer SD-643HD5 64" Rear Projection...
How do i clean the projection screen and projector.
unscrew the back off and there should be 3 lenses, get a microcloth from the dollar store and some rubbing alc and wipe the lenses and then you can wipe the mirror and inside screen. just dont touch the bottom electrical panels or tubes they carry an electrical current.
Jan 03, 2010 | Pioneer SD-643HD5 64" Rear Projection...
I have a Pioneer SD-643HD5 that was working and then just turned off? Now the tv won't turn on
CK for Blowed Fuse will be in middle of chassis 6amp fuse if it is blowed set will not come on.
Dec 30, 2009 | Pioneer SD-643HD5 64" Rear Projection...
My tv is not as bright as it should be
no don't use window cleaner it will cause bad streaking. Just use water with a damp soft cloth and dy with soft cloth.
Dec 30, 2007 | Pioneer SD-643HD5 64" Rear Projection...
Pioneer sd-643hd5
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Sony Convergence
http://www.techlore.com/blog/entry/19694/Sony-Convergence-Repair-My-Sony-TV-has-a-distorted-picture-/
http://www.techlore.com/article/19631/Sony-Convergence-Procedure/
Nov 03, 2007 | Pioneer SD-643HD5 64" Rear Projection...
Pioneer SD-643HD5 does not power on
i had the same problem and it was the flyback transformer on the power supply board.it cost me $375 for the board.just make sure you ground yourself because the static electricity could fry it all.when unplugging the cables mark them and be careful.use a jewlers flat head scewdriver to unlock the cables.use a can of compressed air to clean off the dust.
Aug 26, 2007 | Pioneer SD-643HD5 64" Rear Projection...
HELP TO FIND IC's CONVERGENCE GENERIC NUMBERS
STK392-180 http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
Aug 01, 2007 | Pioneer SD-643HD5 64" Rear Projection...
Pioneer SD-643HD5 64" Rear Projection Television Logo
265 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
