Setting WebServer On Linux
I want to set web server on Linux Box. I successfully Installl & run the one SIte me, but the another site i want to add are not working . Explain How to perform? Is DNS is require, if yes On same machine multiple server can be work?
    Sniper:
  • 135 Answers
Hello,You can try this http://www.goresellers.com/ site's more DNS ,here you can make your self as a reseller and get your expected DNS are very very cheap rate, also you got an internet business opportunity ,visit this site for more details.
Posted on May 26, 2010
    Problem Solver:
  • 8 Answers
Here are some answers :
Whether you plan on using multiple domains, you have to work with apache vhosts to get where you want.
Your domain seller usually can host the DNS for each of you domains so having yourself a dns server is not mandatory
The vhost configuration is in your apache config file (apache.conf or httpd.conf) which is usually located in /etc/apache2 (or /use/local/apache or /usr/local/apache ... depending on your configuration/distro
You'll see in it that there are some examples to help you with that, basically, vhosts are used for apache to know which site it's gonna display when he's called, which is definitely mandatory if you plan on using multiple sites
Posted on Nov 07, 2008
Can i use linux as server software
Yes definitely, linux is mainly used as a server these days.
You can find much more information regarding Linux on Dell machines on the following web site: http://domsch.com/linux/
Hope it helps.
Dec 18, 2011 | Dell PowerEdge 2600 Server
Server being too much slow
Hi
Follow to mention below instruction to Increase the speed in you server.
  1. Up grading the Hardware - The most important factor of getting better speed is by upgrading the existing hardware such as your hard drive, RAM and CPU.
  2. Cache Settings - There are multiple things that can be cached on a webserver, that includes the sites as well. Starting at the minimum level with application caches and climb up to the Db cache, server cache, and web application cache. If the files are already cached in the system it will take less time to load the files the next time they are accessed, as compared to the files that are newly accessed.
  3. Tool to check cache- Linux Drop Cache,etc.,
  4. Find and disable unimportant Services - There may be some services that are running even when the server is in the idle state. Such processes would not only consume RAM but might add to the CPU cycles as well. So disabling the services that are unnecessary or are not that important can further increase the speed of the server.
  5. Compiling applications from the Source - Optimizing the services and applications so that it they get compiled at source instead from the generic binaries can help you increase the speed of your web-server.
  6. Optimizing the web and Db server - It is recommended to optimize your web server and the database server on a regular basis. This would help the web-apps to operate faster and with a much more efficient manner.
If my solution make you happy then give me 4 thumb
Thank
Aug 24, 2011 | IBM x3400 Server
Whether i should host my webpagescreated using php into internet to send mail
Hi,You can host your web pages created with this site's best hosting plans, I am also using this http://www.thewebpole.com/ site only for my website site publish at just $1.99 per year .
Mar 09, 2010 | The PHP Group PHP
Can't find the website for setting up my repeater
Hello there,
That may be an insecure site. Hostings plans for your site here http://www.goresellers.com/ makes you feel secure..
Cheers!
Jan 29, 2010 | Computers & Internet
Can't get site to publish
Hello kindly try this steps and links in publishing your site on net.
  1. Understand the basics. To publish a web site, you should know what a web site must have to be published. A website has a unique web address like www.google.com or www.yahoo.com. This is called a domain name. Each domain name is registered with a DNS (Domain Name Server), which identifies a domain name with a unique ID i.e. IP address (A bunch of 4 groups of 3 digits each). Then, a web site must have a webspace allocated to it. This is provided by a Web Server maintained by many companies.
  2. Look on the web if the name you want to register for website is still available i.e not registered by anyone. You can search for this on many websites like http://www.networksolutions.com etc. If the name is available, then go for it, or think over a new name.
  3. Note the following. If the name is available, then you should go to an Internet Service Provider and get the name of your website registered. You'll get a unique IP address and domain name from the same Internet Service Provider or another buy a web space for your web site. A normal and usual website can be designed with 5 MB of Web space. Depending on your requirement buy web space. There may be generally two options one on a web server using Windows hosting or Linux hosting. Linux hosting is generally cheaper. Also consider the design of your web site and tools you are using to develop your web pages. These should be available on the hosting web server.
  4. Get your web pages designed and working on your own or by a professional web site designer.
  5. Upload the contents of the web pages (files, Folders etc.) as it is to the web server with FTP address, login and password provided by hosting service provider.
  6. Give yourself a pat on the back! Now your website is ready and running over the Internet. You can see it using http://www.yourdomainname.com
If you need more assistance just reply to this post.
Thanks
Jul 16, 2009 | Microsoft Office Publisher 2007 for PC
Uses of apache web server in open suse
Well, when using apache web server in open suse linux it is more secure and it is easy to manage than using apache in windows.
May 05, 2009 | Computers & Internet
2nd printer on print server
Hello Kawena66,
There may be an ip conflict as the error suggest.
what is the ip address on your XP system?
Sep 16, 2008 | D-Link DP-G321 Print Server
Http access
Router cannot forward tcp requests to linux box if it has a http server already running on the same port. Make the router's web server listen on a different port.
May 22, 2008 | Siemens SpeedStream 2604 Router (obss2604...
Asp
Hi, Have you checked your security permissions on the 2003 IIS ?
Are the users using it as Intranet or Internet?
Is the site internal/external or possibly firewalled with rules restricting correct port operation and access permissions?
x-b-m
Feb 19, 2008 | Microsoft Windows Server Standard 2003 for...
Web Server Crashes on port 80.
A couple of questions for you...
1) What do you mean by 'crash'? How do you know its crashed?
2) Can you look in the Windows Event Viewer to see if there are any warning/error messages in the Application or System logs around the time of the starting or crashing of your web site on port 80? If so, anything that suggests the issue. If you don't understand the errors, try posting some of them here.
3) Is there any other web server running on port 80? If your running Internet Information Server, open the Internet Information Server Manager (mmc) console and click on "Web Sites" and it should list all the sites in the right pane. If you have anything 'running' on port 80, it will conflict.
4) Are you running Apache or any other web server on the system? If so, you're going to need to look at those configurations as well.
5) How about any other applications that might have a built in web server?
Let me know.
Jan 14, 2008 | Computers & Internet
Computers & Internet Logo
189 people viewed this question
David Payne
David Payne
