Question about Philips 170C4FS 17" LCD Monitor
Power switches off
I am working on the computer sometimes on the internet some times not , when the power switches off on the monitor. The computer is still running even though the power to the monitor switches off
  • Romerlyn Feb 15, 2008
    I only have the switch off problem in relation to some games. In normal use - no problem.
    Typically, 10 or so minutes into a game (eg Brothers in Arms or GTA) the monitor switches off. LED goes out. By serially switching on again (& again) video will resume for another 5/10 mins. Then I give up. Didn't use to happen & Flight Simulator seems OK! Mystery! Will try refresh rate/ res solution suggested by Silly Girl!
I have a pro view 17 inch lcd desplay that shut down after about half an hour but powewr light stayed on. i noticed it was getting warmer than normal so i fitted a 12v fan from an old mobo i had lying around.. the desplay is now working better than ever.
Posted on Sep 26, 2007
  • 513 Answers
Try changing refresh rate or resolution. You might be using one that your screen can't work with. good luck
Posted on Jun 12, 2006
  • yoav kleinfeld
    yoav kleinfeld Jun 12, 2006
    Either that or a bad power supply.
Monitor works sometimes and sometimes not
Reboot pc until you have a picture, then try updating the drivers for the monitor and your gpu if applicable, outdated drivers can cause erratic and intermittent behavior. Navigation to drivers access varies slightly based on operating system.
Sep 02, 2017 | Computers & Internet
Osd volume control won't go away
bad switch i monitor.
fix switch
or new monitor.
its just a switch, it closes and OSD pops. on demand by said switch, OSD is a timing processor in the display that has the OSD code in it , "program"
Mar 25, 2017 | HP Computers & Internet
Monitor does not switch on every time.
WOW! That's a VERY NICE WORKHORSE MONITOR ~ even if it IS a CRT!
SOMETIMES it's the POWER SWITCH itself! Spray it with contact cleaner ~ WITH silicone...
Power transistors get QUITE hot in the power supply itself... double-check those joints!
The eraser-end of a PENCIL is a great tool for 'tapping around' for "sensitive" areas.
Have you tried a can of FREEZE SPRAY with a THIN/LONG nozzle? It's great for spot-testing...
SUSPECT larger resistors with CAPS at the ends... a WONDERFUL source of intermittent(s)!
LAST choice ~ a TV shop.
A
Dec 13, 2017 | Samsung SyncMaster 753S 17" CRT Monitor
When I switch on computer monitor fails to stay on .
change capacitors c10 and c11 on inverter board
Dec 15, 2008 | Xerox XA7-192i 19" LCD Monitor
LG FLATRON L1732S Problem
Hi...there,
Well, It's time to retired this LCD... Your panel it busted! Treat yourself a new monitor... Happy holidays!
Dec 05, 2008 | LG Flatron L1750S 17" LCD Monitor
OSD Main Menu
because of moiture pushbutton switch were conduct there for replace pushbutton switch and see result
Aug 15, 2008 | HP Pavilion F1703 17" LCD Monitor
KDS monitor screen turns black
So how long have you had it, and try to blow it out. Sometime they just need cleaning. If that don't work send it back before warranty run out
Sep 27, 2017 | KDS Visual Sensations 190 (White) 19...
Dell E173FP - After sometime the screen switches off
Sorry not a solution - but I have started experiencing the exact same problem over the last month although sometimes, on switching on again, it will run for 10-15 minutes before the problem re-emerges. Initially I put it down to the v. hot weather in July but it still continues. So I would also appreciate any solutions!
Aug 06, 2006 | Dell E173FP 17" LCD Flat Panel Monitor
Philips 170C4FS 17" LCD Monitor Logo
578 people viewed this question
Top Philips Computers & Internet Experts
micky dee
Steve Allison
Steve Allison
Are you a Philips Computer and Internet Expert? Answer questions, earn points and help others
