Question about Extreme Networks (45210) Networking Switch
Managable switch problem
If my switch does not start then what can be happen
  • santosh98916 Oct 18, 2008
    i will try it for removing these problem
    thank u for this solution
    Scholar:
  • 32 Answers
I can assume that you mean it does not power on. If that is the case, remove the power supply (or supplies) and re-insert them to make sure they are getting a good connection to the backplane. Make sure the power supply (or supplies) is locked in to place and make sure it is turned on (if applicable, like my Cisco 5509).
If there is more than one power supply, try plugging them all in. In my experience that is the trick to getting a multi-psu enterprise switch to fire up. Once up, one of the power supplies can be disconnected, but may set fault status to the switch.
Hope this helps!
Posted on Oct 18, 2008
Bike wont start, turn the key n everything lights up as normal, press the start button n just nothing
It could be the link from the starter button to the ignition coil. If you can check this for a current it should give an indication of the problem.
Jul 11, 2015 | 2005 Yamaha XVS 1100 Dragstar
My 1996 Lincoln Town Car will not start, as if a kill switch was set. the car runs fine for days and for no reason it won't start, I though it was the anti theft circuit, but have not been able to...
Your best bet , take it an have some testing done . Fuel system , engine management system , electrical system test etc.... Could be any number of thing's ,guessing an just replacing parts doesn't work . Won't start how ? When you turn the key to start does the starter spin the engine ? Crank - no - start ! Or you turn the key an nothing happens ? No crank no start .
Testing Electric Fuel Pump Problems with Voltage Drop Test
048 Engine Hard to Start or No Start Scan Data for Starting Problems
Sep 07, 2017 | 1996 Lincoln Town Car
I cannot connect to my wireless network ( I can connect ONLY by wire) and my Internet provider suggested me to try and find a new driver. Can you find one and notify me?
I think it would be better if you check first the Switch of your wireless and see if its turn ON. If happens that the switch is ON, you have to check the Device Manager on your machine and see if the wireless card is listed under Network Adapter. Here's how you can check the wireless card.
Windows 7 and Windows Vista
Start->Control Panel->Hardware and Sound->Device Manager (in Category View)
Start->Control Panel->Device Manager (in Large or Small Icon View and for Vista Classic View)
Windows XP
Start->Right Click on My Computer->Properties(it will open a window)->Click Hardware->Device Manager
Under Device Manager just double click on the Network Adapter and it should give you list, just check if your Wireless Card is listed, if its not most likely the card is not working or faulty. It would be better to call the manufacturer for more assistance.
Apr 15, 2011 | Computers & Internet
When I power off my LCD monitor, the screen goes all white, but once I turn the monitor back on it goes right back to displaying whatever it should on the screen. Or when I shutdown the computer it also...
If this has happened to two monitors on the same computer, then i dont think the problem is with monitors, i think the problem is with the graphics on the computer, i suggest uninstalling the driver for the graphics card in device manager and then restart the pc to see if that makes any difference. The divice manager in in the properties of my computer icon, just right click and choose properties, then device manager.
Feb 06, 2010 | Sylvania L181 18.1" Flat Panel LCD Monitor
Can't connect to wireless router. Had internet till router changed. All other laptops in the house work fine. Diagnosis says windows is not managing the network, what happened?
when you try to connect to the wireless network, you are getting the message " windows can not configure the wireless network" or windows is not managing.
What is the Operatig system on the computer ?
If it is windows XP then you can switch over to windows utility.
for this you will need to start the wireless zero configuration.
If it is WINDOWS VISTA / 7, then windows will manage the network.
Click here for more information about routers and wireless network.
Jan 24, 2010 | Computers & Internet
Car shuts off while driving. usually while its still moving, I can put it in neutral and restart. In the beginning, it only happened when I hit a bump in the road. Now it just happens.
I had a similar problem. When I was driving on highway with 70 mph, the car suddenly stalled everything went off. I managed to get off the road then I tried to start the car, it did not start. After 5 minutes I tried again and it started running but after several hours it stopped while driving again. Took it to the dealer, had the ignition switch changed and it solved the problem. Costed $300. ( There is also a recall on all 99 Acuras for the switch. Mine had been replaced so they did not treat it as a recall. If yours was never replaced you can have it replaced for free)
Jun 07, 2009 | 1999 Acura TL
Compaq Presario R4000 Notebook won't boot
Seem to be a problem with your power switch doing malfunction or bad motherboard connector or your computer has been setting at hibernate mode. Check those settings going to >> Start >> Control Panel >> Power Options..........Set your droplist to "never: and also UNCHECK the hibernate mode.
Another tip, take out the battery, and see what happen (only connected with AC)
Oct 13, 2008 | Compaq Presario R3000 Notebook
Dell latitude CPx pentiumIII
you shoud not have switched off the system,you should have tried accessing task manager then terminating the program
Jan 03, 2008 | Dell Latitude Cp, Cpi, Cpx, C600, C800,...
Extreme Networks (45210) Networking Switch Logo
291 people viewed this question
Top Extreme Networks Computers & Internet Experts
David Payne
David Payne
Are you an Extreme Networks Computer and Internet Expert? Answer questions, earn points and help others
