Question about JBL Car Audio & Video
CAR AMPLIFIER - GTO 4000 (600 W)
My sons car amplifier doesn't work!
It would appear that there are 4 resisters/capacators(?) that seem to have burnt out.
On the circuit board they are at positions R261, R461, R161 & R162.
Can you tell me what these items are (ie resistors / capacators Etc,) their exact values, and where replacments can be obtain from?
Cheers
Mike
  • 631 Answers
These are resistors.
I don't have the schematic but if there is an R361, it may be the same as the other Rx61 components.
Mouser and Digikey are good sources if you're in the US.
If you send me a good quality photo of the internals of the amp, I may be able to provide more information.
babin_perry@yahoo.com
Posted on Oct 19, 2008
Power but no sound
If you want to repair it ,Take it to some one that no what in the hell there doing,
Nov 05, 2012 | Jl Audio 500/1 Car Audio Amplifier
The fan switch only works a 5. It will not come on at 1,2,3 or 4
had the same problem with a nissan truck, son had the same issue with a chevrolet p/u found in both cases it was the heater motor resister, It appears like a small circuit board, normally behind the glove compartment very easy to get to, May find the exact location from Auto Zone thats where you can purchase the board
Dec 08, 2011 | GMC Envoy Cars & Trucks
The mixer simply doesn't turn on. Worked fine yesterday. Today it seems like it's just dead
HI.Let me jusk ask if yiou also tried to connet to another socket.Let me just clarify that the motor itself did not work /rotate as well.Prior to that situation,have you tried to mix more than what is the capacity of your mixer.If possible motor was overworked/that's why its coil was burnt.There. are possibilities then. First might be that the mixers terminals inside will no longer engaged properly that's why it opens the circuit.Second the motor isn't working because the rotor and armatures coil was burnt because it runs beyond its maximum wattage capacity that's why it draws much current beyond the rotors coil capacity.Did you mixed something heavy.the motor works heavier the last time you used the unit?
Jul 23, 2011 | KitchenAid KSM150PS Artisan Series Stand...
The car got wet ,and disassembly and inspection revealed a burnt item on the main circuit board . can i get a replacement board ? the car is near new and in excellent condition otherwise .
If the part is the same one that overheatd on my sons Ricochet after it got wet, it is a UTD408 power mosfet. Essentially a switch. You can desolder it and get a new part or equivalent and it may work again
Jun 08, 2011 | Hasbro Tonka Ricochet 4 x 4 Radio Control...
I recently revisited my car after a few weeks out of my hands, and seconds after turning the key and the unit powering up, the sound of popping and shrapnel in the amp was heard and the smell of smoke...
What has probably happened is a short somewhere in the amplifier. Here are some possible scenarios:
1. When the new capacitors were installed, make sure that no solder shorted any pads on the circuit board to anywhere else.
2. There is probably a resistor upstream of the capacitors that has shorted but still appears to be fine. Look at the circuit board & follow the traces that connect to the 2 terminals of each capacitor and follow them to other components. Examine them very carefully. Pull on the wire terminals of upstream & downstream components to ensure they are solid. Check each side of the component with an ohm meter. If a zero resistance is given, or no (open) resistance is given the component could be in question. To properly check it out, one side of the resistor must be pulled up from the board, then check the resistance again. If out of spec, it would need replaced & then it would properly voltage limit the capacitors, keeping them from going up in smoke.
3. This can be a very tricky problem without a schematic. See if you can get your hands on one, it makes circuit tracing much much easier
Mar 17, 2011 | Kenwood KAC-9104D Car Audio Amplifier
I've opened the back of the amp case and see no visual problems or obviously burned components, there are no burnt smells and I really just need this exact amp working again as I have a custom rack and...
follow the power circuit on the board if it is burnt up u will see solder a wire from where it is burnt up it will work as a jumper understand? if it is not burnt u have a connection problem
Feb 13, 2011 | Car Audio & Video
Sony xplod 1200 watt amp quit no kind of protect lite on please
short answer yes... Long answer... Amp Failure: There are many different ways that an amp can fail but the two most common failures are shorted output transistors and blown power supply transistors (< those are not blown). There are several types of protection circuits in amplifiers. The most common are over-current and thermal. The over-current protection is supposed to protect the output transistors. Sometimes it doesn't work well enough to prevent the failure of the output transistors but it will work well enough to shut the supply down before the power supply FETs are destroyed. If the amp remains in protect mode, goes into protect mode or blows the fuse as soon as the remote voltage is applied, shorted output transistors are almost certainly the cause. If the fuse protecting the amp is too large, if the protection circuit doesn't respond quickly enough or if the power supply is poorly designed, the power supply transistors may fail. If you see a lot of black soot on the power supply transistors (near the power transformer), the power supply transistors have failed. Soot on the board doesn't necessarily mean the transistors have failed. Sometimes, technicians don't clean up the mess from a previous failure. Transistor Failure/Checking Transistors: In general, when a transistor fails, it will either short (common for output AND power supply transistors) or open (common for power supply transistors). Transistors act like valves. They control the current flowing through a circuit. A shorted transistor acts like a valve that's stuck open (passing too much current). In the case of an output transistor, the shorted transistors tries to deliver the full rail voltage to the speaker output terminal. If you've ever seen a damaged amp that pushed or pulled the speaker cone to its limits when the amp powered up (common on some Rockford amplifiers), that was almost certainly due to a shorted output transistor. When checking transistors, you most commonly look for shorted connections inside the transistor. You do this by using a multimeter to look for low resistance connections between the transistor's terminals. Note: I used the terms short and open on the previous paragraph. A short (short circuit) is a path through which current flows that should not be there. An open (open circuit) is a break in the circuit. It is most likely the power supply that has taken a ****.
Jan 01, 2009 | Sony Xplod XM-1652Z Car Audio Amplifier
Kenwood KAC-9152D problem
It sounds to me like you may have burnt a trace off of the bottom of the circuit board inside the amplifier. If you know how take the amplifier apart and look carefully at the traces. To be clear the traces are the lines on the bottom of the circuit board not the component side. Look carefully they can sometimes be hard to spot. If you find one solder a jumper wire across the two points. If you take the amplifier apart take care in treatment of the output transisors along the sides.
Jan 17, 2007 | Kenwood KAC-9152D Car Audio Amplifier
Car Audio & Video Logo
233 people viewed this question
Top JBL Car Audio & Video Experts
hoyzee1
Rob Beech
Mark Skinner
Are you a JBL Car Audio and Video Expert? Answer questions, earn points and help others
