Question about RCA P46924 46" Rear Projection Television
Rca rear projection tv about ten years old
The power doesnt go on i checked the fuse
    President:
  • 3,130 Answers
This problem is a hard one to diagnose as it could be 1 or a combination of things . It could be a bad solder connection or a power supply problem or a horizontal =sweep problem . need more info man . BUT if your not a tech its highly advised to you that you seek a pro to assist you as theres very high voltage in these sets even when they are un plugged and off for a while. There are no used wserviceable parts inside this set. Good Luck
Posted on Jun 09, 2006
When tv comes on it says replace lamp and reset timer i replaced the lamp but how do i reset the timer have a 56;; sharp rear projection tv
unplug your tv and hold the power button for ten seconds then plug it back in if that doesnt work leave it plugged in and then hold the power button for ten seconds.
Jan 13, 2011 | Sharp 56DR650 56" Rear Projection HDTV
I have an RCA M50WH72syx12, 50" DLP.
Yeah could be expensive if it isn't the lamp.
Mind you could be a little easier, might just be a fuse on the video relay. If you are confident in being able to open it up, check the relay that runs from the video input to the power capacitors and there should be a small fuse along that circuit.
If the fuse has a broken capsule then you may just be in luck. Failing finding a broken fuse, then I would agree with you on the bulb. But check the blub for any markings or cracks because they usually only make noise when the vacuum fails.
Hope this helps and good luck mate! :D
Nov 23, 2010 | RCA HDLP50W151 50" Rear Projection HDTV
Rca projection tv wont stay on but about 1 min then powers off and wont turn back on for about ten minutes then shuts off again after a min or so
Possibility Fan Cooler Issue Check at the back if your hear the fan going if not your fan cooler is burn out .... The Thermistor will shut off the TV automaticly to the unit for Over Heat
Sep 22, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA 61 INCH REAR PROJECTION MODEL # P61929 PUSH
The first place to start is the outlet and check to be sure it has power. The next is to check / replace the main internal (to the tv) fuse - it's a 5A 250V GMA fuse (google image of GMA fuse). To find the fuse, unplug the set and remove the back cover of the TV - follow the power cord to where it enters - the fuse is located to the right and slightly ahead of where the power cord is attached to the board.
Nov 08, 2009 | Televison & Video
Free 2-3 year old rca prjctn tv needing convrgnc chip
I had this problem with my Proj. tv also it cost me $135. to have the convergence chip replaced. i would call a tv tech. to get the true cost.
Sep 19, 2009 | RCA P46920BL 46" Rear Projection...
RCA D52W26 rear projection. 2 years old. 3 times and powers out.
Try replacing CP150, CP114 and CP120 first cost about 12.00 with free instructions available at the following link under the RCA parts category
http://servicemanuals.vstore.ca/
Feb 10, 2009 | RCA P56923BL 56" Rear Projection...
Rca tv wont turn on
What is your Chassis# and what year is TV??
Nov 18, 2008 | RCA P56950 56" Rear Projection Television
Rca 56" rear projection tv
GO TO THE BACK OF THE SET NEAR THE BOTTOM. FIND THE BLUE DRIVER ADJUSTMENT AND TURN IT COUNTERCLOCKWISE.
Jun 15, 2008 | Televison & Video
Rca tv will not power on
Check the horizontal output transistor. This may be shorted.
Mar 12, 2008 | RCA D52W19 52" Rear Projection Television
RCA P46924 46" Rear Projection Television Logo
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
