Question about Hotpoint Aquarius WF000 Front Load Washer
Please help my WF 540 hot point is currently flashing 6 lights out of 11 flashing ones are: wash enhance reduced creases rinse hold mini load final spin on/off but the no extra rise, dr lock prewash, wash, rinse and spin dnt flash. last week it stopped flashing and i was able 2 use the machine but know it wont stop flashing. Many thanks
5 Suggested Answers
  • 1314 Answers
SOURCE: Wont start... all temperature lights flash and the Prewash,rise,time save, crease care lights flash too
try unpluggit then plug it back in is it giving any trouble codes
Posted on Dec 30, 2007
  • 3 Answers
SOURCE: hot point wf541. have top 2 lights on wont pump
I have encountered a similar problem. The following lights were flashing on and off:
  • On/Off.
  • Reduced creases.
  • Mini Load.
I also found that previously one of the 'lifters' inside the drum had broken off and someone had tried to put it back in place and continued to use the washing machine. After a short period of time the above mentioned flashing lights began.
I first suspected the pump, but this was fine. I then disconnected the hose which connects the hole from the drum to the pump and I found a child's sock blocking the hose. I removed the obstruction, put it back together and the machine worked perfectly. I also replaced the lifter (apparently these break quite often) and the machine has been working perfectly ever since that day.
I hope this helps. Good luck.
Posted on Jul 02, 2009
SOURCE: lights flashing on WF320P
i'm having same problem people have said empty filtter but i have done that and the water is running out but still flashing
so sorry wish i could help.
Posted on Sep 11, 2009
SOURCE: wash enhanced, reduced creases and
my washing machine has done the same and my pump was blocked. hope this helps.
Posted on Nov 28, 2010
Hotpoint fault codes
try a different store.
Oct 31, 2013 | Washing Machines
My hotpoint washing machine WF560 mini load and reduced creases lights are flashing and also the on/off light is also flashing, please help. Thanks
Heating eliment or PCB, is this when doing a prewash? or a normal wash excluding pre wash?
if you can manualy pump out and manualy rinse and spin, my guess is heating eliment is broke £20-£30
Jan 27, 2011 | Washing Machines
Hotpoint wf540 stopping on a rinse and spin and
check pump/filter/outlet hose for blockages. if ok, check pressure switch (disc shaped item at top of machine with 4? wires and a tube) by blowing into it gently - should hear clicks, then blow into tube to pressure chamber - should be clear.
Oct 26, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Rinse cycle gets stuck
Most models have a timer relay that times out when a cycle is over. It may be located behaind the front panel - It's worth a shot
Oct 15, 2009 | Washing Machines
Lights flashing on WF320P
Sep 05, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Water will not drain - rinse hold/mini load lights flashing
You might have to take the pump off and clean out the debris in the line theres probably lint, change and other things in the line. Take the lines off and run a piece of wire through the lines to make sure their clear.
May 05, 2009 | Hotpoint Aquarius WD640 Front Load...
Hot point wf541. have top 2 lights on wont pump
Hi.
The sequence of flashing lights is in fact indicating an error condition on your m/c.
It indicates that the m/c has failed to drain, possibly because the pump filter is blocked.
Your m/c is fitted with a filter system for the pump,
The filter may have become blocked, see care and maintenance in your handbook, in your handbook for details on how to check and clean the filter.
Also make sure the door is shut properly.
If after you have checked all these points, and it still does not work properly, then I suggest you have someone to look at the m/c, or replace the pump if it does not appear to be working.
Hope this helps.
Please leave feedback.
thanks.
Nov 30, 2008 | Washing Machines
The 3 buttons
button selection : To select an option press the button and you will see a light come on above the button. Press again to cancel and the light will go out. You cannot alter the options once the machine is running. Note : remember to cancel buttons after use!
As you look at the machine
Left hand button... Rinse Hold.. use this option to Help reduce creasing of delicate or synthetic fabrics by holding clothes in the final rinse water. The rinse hold light will flash to indicate that the programme is holding final rinse water. Complete the final spin by pressing the Rinse Hold button when light is flashing.
This is not available with Wool or Spin only programmes.
Middle Button.... Energy Save... use this option to save money and time on lightly soiled loads. This is not available with the Quick Wash, Rinse and Spin, or Spin Only programmes.
Right Hand Button .... Super Rinse... use this option for Large Wash loads and items for young children or people with sensitive skin. This option increases the water level for the first two rinses. This is not available with Cold Wash, Rinse and Spin or Spin Only programmes.
Copied from my Hotpoint FEW12 user instruction sheet.
Hope it helps.
Sue
Jul 31, 2008 | Hotpoint First Edition FEW12 Front Load...
HOTPOINT AQUARIUS WF 250 ON/OFF LIGHTS FLASHING
The lights are set off by the balance sensors.And if your balance sensors are  stopping    it from spinning than you first have to make sure the washer is level.You  could have bad Shocks and a bad electronic control board,.
May 05, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Wma54
will help type this into a search engine it the user manual !http://imagebank.indesitcompany.co.uk/brochures_online/pdf/Hotpoint/Laundry/WMA50_WMA52_WMM53_WMA54_WMA56_WMA58_WMM59_small.pdf
Feb 15, 2008 | Hotpoint Aquarius WMA56 Front Load Washer
Hotpoint Aquarius WF000 Front Load Washer Logo
53 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
